Old 10-18-2007, 01:47 AM   #1
jugernot
Life, Be In It.....
jugernot's Avatar
Power Steering Bracket for an Inline 6
How hard is it to get a complete power steering bracket for an inline 6? A buddy at work just bought a 72 long bed with an inline 6 and wants to put power steering on it.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 10-18-2007, 03:37 AM   #2
rwgregory
Re: Power Steering Bracket for an Inline 6
If the motor is a 194, 230 or 250 they are around, but a little hard to find. Those engines also came in cars so there are more of them out there. If it is a 292, GOOD LUCK!! Those motors only came in 3/4 ton and up trucks and vans and power steering setups for those are rare. Start checking "big truck" junkyards for bobtails, step vans,etc.
rwgregory
67 GMC 2500 ,2w/d wide box
305 V-6, 4-speed
rwgregory is offline   Reply With Quote
Old 10-18-2007, 05:43 PM   #3
jugernot
Life, Be In It.....
jugernot's Avatar
ttt
Old 10-18-2007, 08:23 PM   #4
Brad
Out of the carpool lane.
Brad's Avatar
I just listed one on the parts board several weeks ago. Unfortunately, it's only 1 of 3 pieces needed, but perhaps you can come up with the other 2 somehow.
http://67-72chevytrucks.com/vboard/s...d.php?t=256257
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 10-18-2007, 09:05 PM   #5
msgross
msgross's Avatar
I found one in a mid 70's (i think) Chevy van with a 250 at the Junkyard. Sold it on here for about $100
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 10-18-2007, 11:43 PM   #6
wibilly
wibilly's Avatar
are the later model 250s the same as our trucks? i have a 79 gmc with a 250 and power stearing
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 10-18-2007, 11:53 PM   #7
ksjh1316
ksjh1316's Avatar
The 292 was avail in half tons as well mine has one with ps and the brackets will be on the parts board in a few months as I am doing a 350 swap. Just curious what is a complete set worth?
ksjh1316 is offline   Reply With Quote
Old 10-19-2007, 11:35 AM   #8
msgross
msgross's Avatar
i've seen 292 brackets go for $200+ (higher on Ebay)
The Garage:
Old 10-19-2007, 01:54 PM   #9
2bits
2bits's Avatar
I think in 79 they were all using the integrated head and those are supposed to be different. I am using one from an integrated head on mine, which is not an integrated head, but I had to get the water pump pulley as well and move the balancer slightly because it sits 1/4 inch off, but after that it is perfect.
Ebay is the best source for these brackets. Expect to pay at LEAST $75 tho, otherwise hit the yards if you have any around your area.
_______________
Thomas
'78 Silverado
'74 Monte Carlo
'47 Teardrop Trailer
East Texas Classics Local Club
2bits is offline   Reply With Quote
Old 10-21-2007, 04:42 AM   #10
jugernot
Life, Be In It.....
jugernot's Avatar
Can anyone post some pictures of the brackets so we can look for the correct ones?
Old 10-21-2007, 08:26 AM   #11
OhNoJoe
OhNoJoe's Avatar
I have a set for a 292 if that's what you're looking for. I'll be using them on the burb. 250 set up is different.
I'll try to get some pictures posted. BTW I paid $20 for my set-up including the pump SCORE!!
OhNoJoe is offline   Reply With Quote
Old 10-21-2007, 08:27 AM   #12
msgross
msgross's Avatar
Here are the one's that I sold...
http://www.67-72chevytrucks.com/vboa...d.php?t=252137
The Garage:
Old 10-21-2007, 12:36 PM   #13
Brad
Brad's Avatar
Here's the top bracket:
Old 10-21-2007, 07:28 PM   #14
2bits
2bits's Avatar
Here is a pic of the bracket installed, but not the pump:
Here is a pic with the pump installed, this also shows what happens when you use a bracket from an integrated head 250.
_______________
Thomas
'78 Silverado
'74 Monte Carlo
Old 05-19-2012, 03:50 PM   #15
gunner33
I have a 69 chevelle that has the problem that is pictured on the bottom it has a head on it off of a newer engein what do I need to get the power stearing pump strate.
gunner33 is offline   Reply With Quote
Old 05-19-2012, 07:55 PM   #16
hugger6933
There is a guy on E-bay that makes and sell those and a/c brackets as well. I have a 64 C60 that I'm planning on adding power steering to
hugger6933 is offline   Reply With Quote
Old 05-19-2012, 09:16 PM   #17
DPowers
One foot in front of the other
DPowers's Avatar
I still have these.
http://67-72chevytrucks.com/vboard/s...d.php?t=517527
DPowers is offline   Reply With Quote
Old 05-19-2012, 10:12 PM   #18
1972RedNeck
1972RedNeck's Avatar
I would use one of THESE.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 05-20-2012, 12:18 AM   #19
ole dollor
ole dollor's Avatar
yes davis speed shop sells inline six power steering ,alt and a/c brackets.you can find him on ebay.he makes them his self i just put one of his on my 1970 1/2 ton 292 this week, very good set up. but you will need to see what pump you are going to use, he has the setup for several . hopes this helps. the power steering bracket was 156.00 shipped. it is very well made.
ole dollor is offline   Reply With Quote
Old 05-20-2012, 06:56 AM   #20
NC67Chev
NC67Chev's Avatar
What did the set-up originally come off of? Did you use the pulley's from the donor? Is your power steering pulley out of alignment by a full groove with regards to the WP pulley? A pic would be helpful.
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside
Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar
NC67Chev is offline   Reply With Quote
Old 03-02-2014, 04:24 AM   #21
sambudo
sambudo's Avatar
My power steering pulley is out of alignment, like you staded above. What do I need to do to correct it?
1968 C10, 250, L6 4spd OTF, Fleetside
Upgrades: Power Steering
.......................____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
sambudo is offline   Reply With Quote
