Old 12-01-2006, 06:11 PM   #1
-Greg72
-Greg72's Avatar
Axle ID Needed (pics).....easy for the experts here!!!
OK,
Here's what I know:
71 or 72 Panel
5-Lug
2WD
Here are the pics....
View from back cover
View of Pinion Side
I want to guess "12-Bolt", but I don't know enough about this type of vehicle to be 100%. I have seen the Eaton rears before and they are a lot "rounder" and the cover is almost a perfect half-dome shape, which this one clearly isn't.
Anyone? Lots of good emoticons for whomever knows....
1972 K5 - 502BBC/4L80E/Magnum205/Mog-9s/5.26s/38" BFG KM2s
Find me on INSTAGRAM @MIGHTASWELLK5
'72 K5 - Greg's "Might As Well™" Build
-Greg72 is offline   Reply With Quote
Old 12-01-2006, 06:22 PM   #2
zeusflash
zeusflash's Avatar
Re: Axle ID Needed (pics).....easy for the experts here!!!
That is indeed a 12 bolt. Be aware if you ever have to get parts for it that you do need to specify TRUCK 12 bolt because the pinion shaft diameter is not the same as a car!
'69 3/4 ton 427 CST Pickup
'71 CST Blazer
'72 GMC 3/4 4x4
zeusflash is offline   Reply With Quote
Old 12-01-2006, 06:34 PM   #3
-Greg72
-Greg72's Avatar
Zeus:
I am a man of my word, so here you go:
Is there any reason why I couldn't do the same sort of mods like the car versions???..... specifically adding a selectable locker, and most importantly some sort of positive retention method for the wheels if an axleshaft was to ever break?.... some sort of C-Clip retainer or "full floater hub" type idea.
I am planning to use this axle to do some towing from time to time, and can't be having wheels spitting out from under the rig!
Thanks again for the help!
Old 12-01-2006, 07:37 PM   #4
vtblazer
vtblazer's Avatar
Originally Posted by -Greg72 View Post
OK,
Here's what I know:
71 or 72 Panel
To clarify, it's a 67 with a 71/72 front clip and same year front disc's.
vtblazer is offline   Reply With Quote
Old 12-01-2006, 09:13 PM   #5
7387chevys
/\How can you tell trailing arms??????
Shane
edit or the number of lugs?
7387chevys is offline   Reply With Quote
