Old 12-12-2006, 10:13 PM   #1
Rokcrln
Rokcrln's Avatar
One-Man Cab & Bed Lift
New From
Lewis Fabrication Design Inc.
I finished the plans and they are ready to ship out Just like the "Tip & Flip Cab Dolly" it comes with material lists, cut lists and step by step build pic's with details. It is designed for standard cabs of all years and fleet side beds. It uses your engine hoist/cherry picker and is truly a one man job. How many times have you needed a hand and no one was around to give you a hand! When you are done it all slides inside it self for easy storage in the corner out of the way.
Plans are $19.95 and this includes shipping and tax. You can order you plans from the link in my Signiture below. If you have any questions please ask!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 12-12-2006, 11:03 PM   #2
classicchev
classicchev's Avatar
Re: One-Man Cab & Bed Lift
Are you able to lift the box high enough to get the frame out without the wheels hitting the bottom of teh box?? I had built one of these setups, and the box was a challange, had to lift from the rear without the tailgate.
Darren
67- 72 Parts collecter
classicchev is offline   Reply With Quote
Old 12-12-2006, 11:17 PM   #3
tom71
what happened to flint mi
tom71's Avatar
hey rok just bought one ,cant wait, thanks tom
71 swb 2wd fleet frame off in progress
72 4x4 blazer daily driver
70 olds cutlass s mint condition owned by a grandma
56 gmc 2wd project waitng
97 fiance mobile
tom71 is offline   Reply With Quote
Old 12-12-2006, 11:59 PM   #4
timcos
Chief Honcho In Charge
timcos's Avatar
I just got one. Can't to buy my welder so I can build one.
1992 1500 4x4 Shortbed
1984 Ford F250 Supercab Longbed 6.9L Diesel
1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
1967 C10 SWB (1980-1981)
1971 C10 LWB (1998-2004)
timcos is offline   Reply With Quote
Old 12-13-2006, 07:24 AM   #5
72freak
Rottenwood Garage Member
72freak's Avatar
Here are a couple pictures of my "one man cab and bed lifters" so I think $20 is a bargain!!!
72freak is offline   Reply With Quote
Old 12-13-2006, 08:14 AM   #6
bowtiehotrodder
SIX BANGER
bowtiehotrodder's Avatar
good ideal
http://www.cardomain.com/ride/2597018(NN)
1979 chevy truck swb 454 w turbo400 with buckets
1977 chevy truck swb soon to be 454
1976 chevy dually 454
1969 chevy truck six shooter
bowtiehotrodder is offline   Reply With Quote
Old 12-13-2006, 10:07 PM   #7
Rokcrln
Rokcrln's Avatar
Thanks guys 6 sets went out today! You should have them in a few days.
Kevin
LFD Inc.
Old 12-15-2006, 02:01 AM   #8
layinrocker65
layinrocker65's Avatar
wish i had one of those when i took my cab off. 6 people and the ones in the back couldnt handle the weight and hit the bed putting hella dents in the rear of the cab. dammit
layinrocker65 is offline   Reply With Quote
Old 12-15-2006, 10:04 AM   #9
Rokcrln
Rokcrln's Avatar
I have been stuck with just 3 people before and it is not safe for anyone that way, plus you might hurt your self. Most of the time I would be waiting for friends to get home to come over and give me a hand so I made this and it works alot better. Best part is you can set it 2" above your frame and then slid all your body mounts in place and drop the two front bolts in to line things up. Then just lower teh body untill it just starts to touch the rear mounts and slide under to install the rear bolts and if you need you can move the cab a bit to get it just lined up right and you are done. I don't know about you guys but my friends can never seem to just move it a bit to the left. It always ends up 1-2" to the left once it finaly breaks loose
Kevin
LFD Inc.
Old 12-15-2006, 03:43 PM   #10
Rokcrln
Rokcrln's Avatar
sent~
Williams Wa.
Debbie Il.
Robert Or.
Kevin
LFD Inc.
Old 12-16-2006, 01:30 AM   #11
smbrouss70
smbrouss70's Avatar
Rok, have you figured out how to use this on a stepside?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 12-16-2006, 10:02 AM   #12
Rokcrln
Rokcrln's Avatar
Yes and No! It can be used but their is a good chance you could warp the side rails because they are not as stronge as the fleet sides. The steps are just rolled and not welded on the bed side tops and this is were you could run into trouble. If you want a set just let me know and I can add the step info to the regular package and you can take of this part on your own.
Vidal V. Both are sent out to you!
Kevin
LFD Inc.
Old 12-16-2006, 06:19 PM   #13
Rokcrln
Rokcrln's Avatar
See I am not only the President I am also a Client Got my cab all set on today for mock up. My buddy wanted to clim in for a pic But I did lift the cab with th eseats still in as well as the drivers door in place. All you have to do is shift the center point over a bit to make up for the doors weight and away you go!
Kevin
LFD Inc.
Old 12-17-2006, 02:53 PM   #14
Rokcrln
Rokcrln's Avatar
Darren
Sorry it took so long to get to your question but I had to put my bed on my frame to make sure. Yes you can depending on two things, 1) how high will your lift go and 2) is your truck lifted! I had to jack the back of my truck up some because it is so low that my lift would not clear my tank or trailing arms but it all cleared the tires and frame with no problem. I do know what you are saying about having to go from the tailgate end and it may need to be done depending on the above factors. Also if you are in a one car garage you may need to lift from the back and not the side. But how ever you need to do it, it sure is easy this way instead of with 4 friends! I just lowered it about 1/2" above teh mounts and then dropped in the bolts thru the mount holes and lowered it the rest of the way
Kevin
LFD Inc.
Old 12-17-2006, 07:49 PM   #15
lolife99
67-72 parts collector,…
lolife99's Avatar
Kevin,... I sent you a PM. Thanks.
Keith
Convert to disc brakes.
Old 12-17-2006, 10:47 PM   #16
Rokcrln
Rokcrln's Avatar
Your all set!
Kevin
LFD Inc.
Old 12-19-2006, 04:43 PM   #17
abadsvt
abadsvt's Avatar
Hey Kevin, how much do you estimate for material to build the one man lift and the tip and flip dolly? I am thinking about buy the both i just would like to know what it is going to cost me overall. Thanks
ps. Your truck is looking SWEET!!!!
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 12-19-2006, 08:25 PM   #18
Rokcrln
Rokcrln's Avatar
Josh
Well I think I got a great deal on metal at the time I built the dollys because I bought about 200' of tube at once for projects. I only had about $100 +- into mine but most people are saying it is running about $200 if I remember right. The cab lift is minimal as far as material goes but I would plan $100 and their should be money left unless you buy it all at homedepot! Hope this helps.
Kevin
LFD Inc.
Old 12-20-2006, 12:07 AM   #19
Rokcrln
Rokcrln's Avatar
3 more sent out tonight!
Michael WI
------- TX
Tom TX
Thanks,
Kevin
LFD Inc.
Old 12-21-2006, 08:01 PM   #20
T J Randall
Junior Member
Kevin, I just used my wifes' paypal to get the plans for the cab and bed lift headed my way.. keep up the good work there, you're makin' things a lot easier for a bunch of us out here. Merry Christmas!
T J Randall is offline   Reply With Quote
Old 12-21-2006, 08:12 PM   #21
Rokcrln
Rokcrln's Avatar
And I just sent them off and we all know your real name is "Kalena" Thank you and that is why I build this stuff in the first place. It is not to make money off them but it is to make my life alot easier and my prices cheaper for my customers who's rigs I work on. To tell you the truth on the tip and flips I just sold enough last week to cover my time for putting the plans together but I would rather make a $1 off each one and get more out their than $10 per set and not have as many guys get advantage of my sleepless nights And Merry Christmas as well..
Kevin
LFD Inc.
Old 12-27-2006, 10:36 PM   #22
Rokcrln
Rokcrln's Avatar
LoLife99~ I got your payment today and your plans will be sent off in the morning to the oakridge Fulton address.
Thanks,
Kevin
LFD Inc.
Old 01-29-2007, 12:14 AM   #23
old_blew_72
old_blew_72's Avatar
do you have any more pics of the lift jig
old_blew_72 is offline   Reply With Quote
Old 02-18-2007, 01:26 PM   #24
blazer72
Freedom isn't Free
blazer72's Avatar
do you have the specs for your door and fender hangars?
blazer72 is offline   Reply With Quote
Old 02-18-2007, 04:08 PM   #25
Rokcrln
Rokcrln's Avatar
No it was just scrap that I welded up to hold stuff! Nothing fancy, just look at the pic and start welding!!
Kevin
LFD Inc.
