03-15-2007, 09:05 AM | #1 |
sufficiently talented fool
Power brake setup
Power brake booster,master cylinder, proportioning valve, pushrod, and support brackets. Off of 1972 c-20 disc brake truck. $50+shipping
Attachment 250544 Attachment 250545 Attachment 250546
"it's impossible to be surrounded by idiots when you are part of the circle" 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board Last edited by centsless; 10-04-2007 at 08:49 PM. |
03-15-2007, 09:43 AM | #2 |
Re: Power brake setup
03-15-2007, 09:45 AM | #3 |
Oh and this is Disc/Drum right?
03-15-2007, 10:58 AM | #4 |
yes, it was a front disc, rear drum truck. I will post pics and price shipping this afternoon
"it's impossible to be surrounded by idiots when you are part of the circle" 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
03-15-2007, 11:00 AM | #5 |
And this should bolt right up in a 1/2 ton right? If so, definitely interested.
03-15-2007, 11:10 AM | #6 |
Yes. It will bolt up and work fine. It has everything you need except for the hose and check valve. Just took pics and it DOES have the check valve. Sorry...it has been in a box and I forgot....
"it's impossible to be surrounded by idiots when you are part of the circle" 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board Last edited by centsless; 03-15-2007 at 11:48 AM. |
03-15-2007, 12:32 PM | #7 |
Are you willing to split this up? If so, can you post a better pic of the master cylinder and prop valve?
Thanks, John |
03-15-2007, 12:54 PM | #8 |
if splitting, i may be interested in booster, bracket, and rod. i want to put it on my 69 c-25 but i'm curious if it will work properly since the booster was different between 69 and 72. the bracket and rod the same?
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration. |
03-15-2007, 04:29 PM | #9 |
I would rather leave this together and ship in one box. Shipping to oleblue68 is $23 parcel post or $21 DHL. I do not know if it will work with other years parts. I do know that the whole assembly will fit other years.
03-15-2007, 04:42 PM | #10 |
Thanks centsless but I think I'm gonna pass on this one. I got a booster here in better shape than that so I'd rather not pay for the booster + it's shipping if I'm not gonna use it.
John |
03-17-2007, 08:58 AM | #11 |
ttt
03-17-2007, 03:32 PM | #12 |
ttt, it's worth that as a core...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
03-17-2007, 06:02 PM | #13 |
I sure paid more than that...
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
04-08-2007, 08:50 AM | #14 |
Still got this stuff Bob???
Alex 1971 Lil' Red 350 SBC 700R4 |
04-08-2007, 11:34 AM | #15 |
Yup
04-08-2007, 11:40 AM | #16 |
I want to whole kit and ka bootle...sold!!! $50 plus shipping to 80233. Don't send the MC or the P valve...don't need them.
FYI, I have am sending $20 for the Alt bracket and shipping , Envelope is already adrressed with the 20 in it...going in tomorrows mail....no it's and or butts...buddy...you helped me and I want to send you 20. take the Red neck gal out for a bite to eat or a beer!
Alex 1971 Lil' Red 350 SBC 700R4 Last edited by ChevyDude; 04-08-2007 at 11:42 AM. |
04-08-2007, 12:54 PM | #17 |
bob, hows the prop valve then?
04-08-2007, 05:04 PM | #18 |
hey... is this the setup i was looking at a while ago? do you have any others?
04-08-2007, 06:54 PM | #19 |
Chevydude...I will get pricing on the shipping in a bit.
msgross...I will take $5 for the shipping, then send something to chevydude if you want since he already paid me for it... racerman85...this is the setup you were looking at and did not want to use because it was a 3/4 ton setup. If I come across one for a 1/2 ton, I will let you know!!
04-08-2007, 06:58 PM | #20 |
$5 sounds cool, is the prop valve in good condition? It would be the only thing "used" on my new brake system.
Chevydude, let me know if you are leaving the prop valve and i'll send you some $$$ too.
04-08-2007, 07:40 PM | #21 |
msgross...The valve has some pretty bad rust on it, but did not leak, the switch terminal is clean, and I made sure the lines came out. I left the line nuts in the valve, but they are all loose.
chevydude...the box I had this in is way too big for just the booster. I will try to get a box to fit better tomorrow at work, then price shipping for you.
"it's impossible to be surrounded by idiots when you are part of the circle" 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board Last edited by centsless; 04-08-2007 at 07:45 PM. Reason: added info |
04-08-2007, 08:25 PM | #22 |
alright. thanks! keep me posted, i've been unable to find a setup.
04-08-2007, 09:17 PM | #23 |
I really only want the booster all the brackets, adj rod and bolt. Thanks.
Bob, I believe the brackets, and rod are the same whether it's 3/4 or 1/2 ton. I will use the booster as a core and get a new 1/2 ton C-10 booster a new C-10 MC and new disc/disc P valve, sand blast the brackets.......and she's new again! Ya no...correcto???
Alex 1971 Lil' Red 350 SBC 700R4 Last edited by ChevyDude; 04-08-2007 at 09:23 PM. |
04-08-2007, 10:11 PM | #24 |
brackets are different, but you can buy a 3/4 ton booster and MC and have even better braking (dual vs single diaphram). autozone sells combo kits for a good price.
04-08-2007, 11:33 PM | #25 |
From the pics I have seen, the booster I have is not the dual diaphram. It actually looks identical to the one on my 1/2 ton. I could be wrong, though...
