The burbs new look.
Here's some new pics of the burb. I just got done with the 14 bolt, Ford Dana 44 high pinion, rear disc brake, 38x15.50r16 swap. The lift is 6" with both axles moved back 1". Shot the primer last weekend so now I can start finishing the body work.
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc. |
Re: The burbs new look.
Wow!
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
A few more.
double wow, nice truck
![]() Join Date: Jan 2007
Nice!!!
Looks like MT Classics? Nice!!! Wil
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() |
Junior Member
Its perfect! dont paint it!
sweet
1970 k/5 blazer--> money pit - 14bolt dana 44 350 sm465/205 36 14.50 16 tires 1972 nova plane jane 6 clyinder might sell might keep dont know 2004 chevy s-10 crewcab zr5 sold 1985 c20 chevy long bed , beater , on its way to a better place in pa from what the dmv told me 2010 kia forte koup 2.4 sx -over the river and threw the woods to the total lot it went . 1999 k1500 suburban 350 vortec 4l60e leather land yacht . |
I like it!! Alot!!
Luv the Crewcabs
Yes, MT Classic II's, 16x12. It will be this color till this fall, even though I don't really like it. It has more shine than I'd wanted it to, so it looks like a lower cost paint job in my opinion. Then most of it will be getting sanded off in preperation for paint. I have to say, spraying something this big was a little bit of a challenge. Especially since I'd never done it before. The roof is HUGE!
Thanks for the compliments!
Looks great ! I cant tell in the pics but did you use )rates to move the axles and are you going to trim the fenders any or is it just a driver.
Earl 68 2500 4x4 GMC Burb Last edited by earl87gta; 08-14-2007 at 03:39 AM. |
#13 |
Post Whore
![]() Join Date: Feb 2000
That is very nice! There is nothing like the sight of a lifted 67-72 Burb. That gets your attention for sure.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#14 |
SWEET!
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
#15 |
Junior Member
I love It!!
'72 Cheyenne K-10 LWB '05 Jeep Wrangler Willy's Edition '07 Victory Vegas '99 Subaru Legacy SUS |
#16 |
Sweet fancy moses,I like the looks of that,I luv my BURB,TOO.
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
#17 |
To move the axles I used a new spring perch ( had to anyway ) with an off set pin whole in the rear. And in the front I made my own "0" rate block and welded it to the axle. It's only 3/4" thick so nothing crazy. It's just a driver that won't see anything more than fireroads so I don't plan to cut the fenders at all. I'd like to eventually get the axles narrowed to bring the tires back into the wheel well completely. That would give me a little more clearance as well. I like the fenders as crammed as posable with tire!
#18 |
turbo enthusiast
WOW! WOW! WOW! WOW!
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting ![]() |
#19 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
those subs look huge when there are lifted that thing is killer looking..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#20 |
boostat4500 ,
how wide is the whell your runing and how lose to 38 15.50 did the tire come out . my 36 x 12.50 were 35 3/4 by 11.
Earl 68 2500 4x4 GMC Burb |
#21 |
The wheels are 16x12. They are 37.5" tall. The tread is 12.5" wide and at the widest part off the side biters, just under 16" wide. Made my old BFG mud 35x12.5's look tiny. Did you have 11" of tread or is that the sidewall width?
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc. Last edited by boostat4500; 11-21-2007 at 08:20 PM. |
#22 |
Thanks My tread was 11. Im trying to decide on new tires and cant make up my mind. I have been thining og going with 37 12.50 hummer tires but i odnt think they will be wide enough for me.
#23 |
How wide are you wanting? I actually wish mine were about an inch narrower. I didn't want this wide but got such a good deal on them, I couldn't resist. I don't like that they stick out past the fender. If I keep the truck, I might look into getting the axles narrowed. What kind of tires did you have? I've never seen a 12.50 with that much tread width.
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc. Last edited by boostat4500; 11-21-2007 at 11:29 PM. |
#24 |
There a set of buck shots there not bad tires I just want them bigger and I like the wider look it doesnt bother me if they stick out past the fenders. I dont have a paint job to worry about. you need to check out the hummer tires if you dont want a wide tire they would not stick out so far I think changing you rims would fix the trouble easier then shorting the axles that is a $$$ thing to have done.
Here is a set of 37 hummer tires on a truck you can see they are a true 37 tire. and they dont stick out past the fenders. http://67-72chevytrucks.com/vboard/s...d.php?t=261824
Earl 68 2500 4x4 GMC Burb Last edited by earl87gta; 11-22-2007 at 09:13 AM. |
#25 |
Changing rims would definetley be the easiest way to go. The problem is, I'm very,very picky about wheels on a truck. I've never had much luck finding wheels with options for the back spacing. Everything I found in a 16x12 were all 4 1/2" backspace. I'd love about a 5 1/2 or 6". Any suggestions on brands to look at?
