08-29-2007, 03:27 PM | #1 |
Luv the Crewcabs
How Best To Clean Alum Rims????
Has anyone Found a Good Way of Cleaning up Aluminun Rims That Look Like This??
Thanks, Rick |
08-29-2007, 03:37 PM | #2 |
Questionable
Re: How Best To Clean Alum Rims????
Go get a Flitz ball or Mothers Power ball. it will have those wheels so shiny you can see yourself in them in under 10 minutes.
I am not normally one to push products on anyone, but ... that Mothers power ball is freaking amazing. Some guys here have posted before and after shots if you really wanted to see, but I can tell you - no BS - you will be amazed.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 08-29-2007 at 03:37 PM. |
08-29-2007, 04:08 PM | #3 |
100% Beefcake
Try not getting them dirty I have a set of wheels that are identical to yours. I almost threw them in the trash until I used Mother's Power Liquid Metal and a Power ball. I recently placed 2 new 15x10's with P325/50R15 on the rear. I think the old ones are shinnier than the new ones. My wheels were bought in the mid 80's and looked every bit as bad as yours.
1969 C10,350,4:11 posi, Fast Enough 1984 Monte Carlo SS 1987 Chevy S-10, 355 w/150 Shot of Nitrous, Fun,Fun 1938 Nash Lafayette 1956 MG Magnette |
08-29-2007, 04:09 PM | #4 | |
Mothers Power Ball. Is that the one Chip Foose advertises for?
Robert Member 1532 |
08-29-2007, 04:35 PM | #5 |
Luv the Crewcabs
Thanks Guy's, Nice to Know they Can be Saved............
Rick |
08-29-2007, 05:02 PM | #6 |
What Hump?
If you getting the mothers power ball go to wally world instead of the auto parts store, when i bought mine it was a lot less expensive there.
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
08-29-2007, 05:48 PM | #7 |
its all about the +6 inches
does the wheel still have the clear coat on it?
08-29-2007, 07:01 PM | #8 | |
Questionable
Flitz is the same concept, they advertise on the "Power Block" on Spike TV (the hot rod shows).
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
08-29-2007, 07:41 PM | #9 |
>130dB Moderator
For best results, use Simichrome and a buffing bonnet at the end of a drill. Flitz and Mothers are more of a gimick I feel because of their advertising. Simichrome is one of those products hat you never hear about because only the enthusiasts know about it.
It's expensive, but it gets the job done better than anything else out there...
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
08-29-2007, 07:45 PM | #10 |
Happy to be here
Thats' what I was wondering too. If those are clearcoted and the dull look is caused by aging you have another problem to deal with...
08-29-2007, 07:49 PM | #11 |
Luv the Crewcabs
08-30-2007, 12:29 AM | #12 |
The Older Generation
A friend of mine that builds aluminum race cars swears by this stuff.... http://www.southwestwheel.com/wheels...leaningkit.htm I think he only uses the PDQ Polish. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 08-30-2007 at 12:30 AM. |
08-30-2007, 02:16 AM | #13 |
Removing clearcoat is basically removing paint. Thank you, but I will stick to using my California Customs Purple for my aluminum wheels.
08-30-2007, 12:17 PM | #14 |
mine looked like that and I tried a few things with no luck I took mine and had them professionally polished that removed the ridges and other inprofections (sp?) anyway they are now easy to keep clean but Randy I did just order some of that purple stuff and some wax should be here tomorrow and I plan on cleaning them up again with the good stuff.
Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
