09-03-2007, 11:30 PM | #1 |
Shaving the drip rails
One of the things that I've always disliked about our trucks is the drip rails. I've read on here about people cutting them off, and stories about the cons of removing them.
Well I figure I'll give it a try myself. Here you can see the 3 distinct layers of metal that are contained in the front drip rail (over the windshield) I made the cut tangent to the curvature of the top skin of the roof, which leaves a little ledge on the bottom side. Then I moved to the side and cut out this piece You can see the the drip rail on the side is a seperate piece only spot welded on. And you can actually remove the entire drip rail piece before doing any cutting . I didn't get to welding it back together today as my welder won't reach where the cab is currently setting. Hopefully I'll get the trial cuts welded sometime this week. Oh, also, this is an extra cab that I have that is pretty rusted out, so I figure I'd practice and see what is all envolved before I cut up the cab I'm planning to use. Hopefully if I figure out the process I'll be able to do it on the "finished" cab. |
09-03-2007, 11:37 PM | #2 |
Questionable
Re: Shaving the drip rails
cool, definitely thanks for the info sharing!
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
09-04-2007, 12:18 AM | #3 |
I had mine shaved and I love the new look, it really cleans up the cab.
Keep us posted |
09-04-2007, 09:58 AM | #4 |
It's a catastrophic success.
They say the trick to this is to cut and weld small portions at a time. It helps to prevent separation and distortion.
10-17-2007, 07:22 PM | #5 |
PITbut
Updates?????????
10-18-2007, 09:49 AM | #6 |
ttt
10-19-2007, 06:54 AM | #7 |
any updates??
10-19-2007, 07:41 PM | #8 |
A few pics on project!
10-20-2007, 02:53 AM | #9 |
Have you welded in a whole section?
10-20-2007, 06:27 AM | #10 |
Camaro Club
i know this would probably be impossible with the stock glass but i think it would look pretty cool to have flush mounted glass like the newer cars to go along with your shaved drip rails
