10-21-2007, 09:06 PM | #1 |
327 4-bolt main How rare?
I found a 327 4-bolt main all I have ever seen is 2-bolt mains is this rare or special????? Any info????? Thanks
10-21-2007, 09:42 PM | #2 |
Re: 327 4-bolt main How rare?
If it's a large journal 327 crank, it can be put into a 4 bolt main 350 block. They both share the same bore size.
10-21-2007, 09:56 PM | #3 |
i have never heard of a 4 bolt 327 and on mortec website it does not show one either. Someone may have made a 2 bolt to a 4 bolt. Are the outer bolts splayed (angled)?
10-21-2007, 10:57 PM | #4 |
I talked to a well known machinest about the rare 4 bolt block a yr ago and he said no such thing.Like the others mentioned above some one splayed it or used a 350 block.That is what I was told and I myself have not ever seen a true 327 4 bolt.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
10-21-2007, 11:38 PM | #5 |
Msgt USAF Ret
3955270 427 2-Bolt or 4-Bolt
3955272 396 2-Bolt or 4-Bolt 3956618 302 or 327 or 350 2-Bolt or 4-Bolt 3956632 307 2-Bolt 3963512 427 or 454 2-Bolt or 4-Bolt 3969854 I found this casting number on a couple of websites. I read it as three possibilities for a two or four bolt main. Check your block casting number.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
10-22-2007, 01:38 AM | #6 |
I just seen a 4 bolt 327 when I picked up my block yesterday, fact the guy had 3 of them but not sure if all three where 4 bolt. Dood had a chit load of old 60's to 70's blocks & heads, also seen some old fuel heads for 300.00 and he asking 200.00 for the 327 blocks (bare)
10-22-2007, 01:41 AM | #7 |
My father retired from Chevy V8 plant in Flint Michigan, I'll give him a call and see what info I can get from him.
10-22-2007, 02:08 AM | #8 |
A board member built a 327 4 bolt for his truck, several years back,,,The engine was from an old combine.
1970 long fleet, 355 4 speed, primer, walnut goodies |
10-22-2007, 02:23 AM | #9 | |
Anthony |
10-22-2007, 11:08 AM | #10 |
Gone Fishing
They never made a 327 4 bolt main block. You can make one with a large journal 327 crank in a 4 bolt 350 block due to the same bore that they have.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
10-22-2007, 07:27 PM | #11 |
Yes they did make a 327 4 bolt main. I owned one about 12 years ago. I bought a 68 lwb rust bucket and the guy i bought it from said that the motor ran great but it smoked when first started but the engine was supposed to have came out of a 65 vette.
I said yeah right and bought the truck anyway because i needed some other parts off it. So i got the thing home running on 3 or 4 cylinders and then i opened the hood and started replacing the plug withe that the mice had ate into and it ran MUCH better. after i scrapped the greese of the head i seen the camel humps and thought i should look a little deeper then i removed the valve cover and found the 461x casting on the head and then next i ran the numbers on the block and it came up to be a 327. I pulled the engine a few weeks later and sat it in the barn for a few years until i needed it and i tore it down to freshen it up and found that it was a 4 bolt main. That is the only 327 4 bolt main i even seen but with the 461x heads. It was a strong running motor that i never should have sold. |
10-22-2007, 07:37 PM | #12 | |
What were the numbers on the block? the 461X heads were definately from a early motor as the 1968 motors had acc. holes.
Anthony |
10-22-2007, 08:41 PM | #13 |
I spoke to my father. He worked at Chevy v8 plant for years out of Flint Michigan, He stated GM did indeed produce the 327 4 bolt mains, they were used in Truck applications. I asked him if they were rare, he stated they didn't produce as many as the 350's.
10-24-2007, 11:53 PM | #14 |
They used the 4 bolt mains in combines,trucks,and pickups, the two bolt mains were in the cars at that time, before the late 70's it didn't matter if it was 327 or 350's.
01 Pontiac Bonneville SLE 62 Studebaker GT Hawk 72 GMC C20-327/th350 81 Chevy c10 84 Monte Carlo SS 70 Ford 3/4ton 4X4 Highboy 390/bedhoist 68 Mercury Cougar GT |
10-24-2007, 11:59 PM | #15 |
I have worked in Machine shops since I was 17 and have NEVER seen a 4bolt 327. They are easy to BUILD using a lrg journal steel crank or a 307 cast crank and 350 4bolt block.
Plus EVERY book I have ever read states that Chevy NEVER made a 4 bolt main 327. A 327 from a '65 vette would have been a small journal motor, and I know for a fact that a 4bolt small journal anything was ever made available to the public. Even the first "DZ" 302 camaro motors were small journal 2 bolt main blocks. The stamping on the front pad can be restamped. I know someone PERSONALLY that does it for Corvettes. Good Luck -Lance
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
10-25-2007, 12:52 AM | #16 | |
i have an old 327 out of a Massey Combine...maybe i should pull the pan before i sell it!!
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you." '84 chevy half ton short box 2wd, 67,000 actual miles '03 chevy 1500 HD crew cab 4x4 standard box, 6.0L |
10-25-2007, 10:21 PM | #17 |
well i must have owned one of those motors that were not avaliable to the public.
i sold it to a vette dealer here locally and he wanted it for a 65 vette restoration. I wish i had the casting number still, that was a long time ago. |
10-26-2007, 01:12 AM | #18 |
I have personally had SEVERAL L-79 327's from vettes,chevelles, and the RARE chevy II's. That was chevy's HOT 327. NONE of them were 4bolt mains. I have had a '67 DZ 302 block also 2bolt main.
I dont want to get into a pi$$in contest here,just saying I have NEVER seen one. -Lance
10-26-2007, 09:34 AM | #19 |
On a budget like Fred Sanford
I've never seen one either, and everything I've heard/seen/read says that a 4 bolt 327 doesn't exist and was never produced by GM.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
06-23-2015, 11:44 PM | #20 |
Hope this thread ain't dead mabey breath some life back in to it ....
It seems people don't know about 327 4 bolt mains this is what I know for fact I have a 1967 all original factory 327 4 bolt main large journal 4 barrel carb ... It came from the factory like this the trucks been in my family since 68 .. But then again my truck was custom order from factory... But yes it rolled out of Fremont ca as this block an options All number matching frame ,cab ,spid , motor ,trans an rear 1967 CST C20 |
06-23-2015, 11:52 PM | #21 |
Curious what is the casting number on the block and engine prefix code.
06-24-2015, 12:15 AM | #22 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
06-24-2015, 01:23 AM | #23 | |
06-24-2015, 02:03 AM | #24 |
I did not say wont, or cant be.....can you dig up the date code, & the stamping on front? Pass side front on the stamp.... longhorn
06-24-2015, 02:11 AM | #25 |
