Old 11-19-2007, 11:27 PM   #1
Turtle
after market turn signal
i got a add on switch missing the wiring diagram,it looks like brothers part # tsa 7200. it has the 4 way flasher and indicators lights it has seven wires green.brown,red,blue,yellow,black,tan or pink.any help would be great thanks
Turtle is offline   Reply With Quote
Old 11-20-2007, 01:55 AM   #2
hewlett2002000
hewlett2002000's Avatar
Re: after market turn signal
well i dont know if it would be the same but i also have an aftermarket turn signal and ill check my wires and see if there the same and write down where they go. ill check tomorrow.
John
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 11-20-2007, 09:49 AM   #3
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I also have an aftermarket turn-signal switch...Mine is a 'Signal-Stat'.
I will check my wires and let you know as well...they might be the same color codes.
I tested mine on the bench with a battery-charger and a test light.
You have two (+) coming in....constant power (key on)..and brake switch;
Four outputs (lights), then the last wire might be a (-) or (+) for the built light (if equipped)
I will check it out......
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
