I hate 4.10 gears
My 70 lwb "Road Dog" hates them even worse. I did all the calculations before changing from 3.07's. But driving is believing. How it went down was,
after i changed out to my new motor I wanted a little more low end (stump puller) grunt but now I'm in forth gear at 40mph. and I can't stand it. specs: 70 lwb 4x4, built 355 motor, sm465 4 speed manual tranny, np205 transfer case. Luckily I swapped out only the rear to see if I liked the 4.10's or not. NOT. I'll be putting back the 3.07's today. I also think half my problem is that sm465. I would love a 700r4.
70 K-10 75 CJ-5 90 XJ Smell the Magic! |
Re: I hate 4.10 gears
You just need bigger tires. Try some 35's and the 4.10 will be just about right. I am running 4.56 with 38" tires and I am thinking about going to 5.13 and 40's. I do have the 700r4 though.
Tell me about it. I have a sm465 and 4:10s and that 4th gear is a range of 15mph-55mph, ha. I can just about start it in 3rd from a stop.
There are alot of Ratio's in between that. 3.07 seems really high for a 4x 4.10 is about right with 35's. If your running a smaller tires or a lower tranny maybe 3.55 would be the best of both worlds or as some may say the sweet spot!
There are two kinds of people, those who finish what they start and so on. 70 GMC Longhorn (A.K.A Money Bucket) 57 Chev 3100 05 Chevy LLY Dmax. 67 Chevy Camaro Dad's Budget Build 55 My Longhorn Build Last edited by Sinisterspeed; 06-11-2008 at 02:28 PM. |
![]() Join Date: Jan 2008
4.10s in my 71 are not highway friendly either BUT its just weekend cruiser/track beast
71 cheyenne lwb 300rwhp best 1/4 time so far 12.8 @103 ![]() http://i195.photobucket.com/albums/z...en58/001-2.jpg |
I'll be running 4.10s in my 68, but that will be with a 4L60E and ~29" tires.
I'm running 4.11 with a 700r and 30 inch tires.. runs about 2200 at 70 and first is squirly as hell.... but mine is a "hot rod".
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
Do they have like 2.56's as a stock option?
I'm a poor spectator
What size tires are you running right now?
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
LOL I ran 4.56 gears for about 3 weeks in my 69 2wd stepside with 205x60x15 tires. I had a healthy 350 balanced and blueprinted. MAN was I fast from 0-50mph started out in 3rd all the time.
In a 4x4 with 33 or 35" tires 4.10's should be pretty nice. The main thing your noticing is a HUGE jump from 3.07's It would realy help to know what size tire your running but 3.40 down to 3.73 would be about right for 31" tires alot of guys will run 3.73 even with 33-35" tires for better economy. IF your engine is healthy enough you should still have good low end with that combo. There IS a lot of other gear ratios in between 3.07 and 4.10 but the man ones to look at are 3.07, 3.40, 3.73, 4.10. One because they provide noticable differences and two because they was available stock ratios from GM. Suppliers will make you almost any gears you want but going from a 3.07 to lets say a 3.15 wont make much differnce. My vote is for 35" tires and keep the 4.10's. ![]() NOTE: the highest stock gear ratio in a truck I have seen is a 2.73 so yes its close to 2.56. Last edited by original_balzer; 06-11-2008 at 09:17 PM. |
runninf 4.11's in my 69...35' with a th350....it will pull hell right up off its hinges as long as i stop at every gas pump on the way...scott
i'm running 4.11's with 35's and a th350...will pull hell right off its hinges as long as i hit every gas pump along the way...scott
#13 |
Fabricate till you "puke"
Got a set of Richmond 4.10s & a 4 series posi under the bench
.......they sure were fun to play with tho ![]() ![]()
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#14 |
Thanks for the replies.
I'm running 31" tires. with a tape measure they are actually 30.5"
70 K-10 75 CJ-5 90 XJ Smell the Magic! Last edited by Dr.Jones; 06-11-2008 at 10:56 PM. |
#15 |
![]() Join Date: Jul 2007
#16 |
I love 4.10s.I roll at 75-80 mph all day long.Man that motor sounds happy!
#17 | |
Bloo
same as special-k here, my K20 has 4.10s in it.. if you can put up with the vibration, it'll roll right along at 80mph all day long
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
#18 |
My 71 C20 with 245 x 16 street tires and 4.11 rear gets 12.5 going back and forth to work but the trip is 23 miles each way so it gets spendy. I drive on a 55 mph road but if I went over on the freeway I think I would be getting about 10. I am hunting for a 3.55 rear or even a 3.73.
#19 |
Packrat
after reading this I think I should keep my 33's on.....
gone: --'07 Tahoe LTZ 4WD --'68 Firebird 400 Convertible gone: --'72 Chevy K20 |
#20 |
I got 12.5 in my blue`72 truck with 4.10s and 35" tires.I`d roll at 60-62 on the speedo,which was about 66-68 mph.The truck had a 400 SBC.It seemed to be an ideal set-up.It had plenty of bottom end and just rolled on the tires with little throttle.
#21 |
i love'd them when i had my 355 in my 72 they ran about 2200 rpm's between 55 and 65mph BUT I HATE THEM with my new power plant of a 500 caddy top's put to quick
1972 c-20 chevy 500 caddy/4.10posi / 1972 3/4 ton gmc 350 4x4/4.10posi front&rear ![]() ![]() ![]() |
#22 |
I've got 4.09 gears in. mine with 35 in tires and a Gear Vendors OD. It runs 65 at around 2200 RPM. the 383 will still set you back in the seat with the OD off.
69 Chevy 4x4 383 Power ![]() |
#23 |
4.10's with a sm465 is like a two speed. At least with the 3.07's I can fake a 3 speed again.
Sounds like all your rigs are bad ass. right on!!!!!
#24 |
Not sure I understand.Isn`t it like a 3spd?
