Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
View Poll Results: Powerglide or Th350
Powerglide 7 77.78%
th 350 2 22.22%
Voters: 9. You may not vote on this poll
Old 07-14-2008, 02:00 PM   #1
hotrod 80
mini truck racer
hotrod 80's Avatar
powerglide vs th350
I am about to make some pretty big ( in my world ) changes to my truck and im looking for opinions . The truck is a 1978 Chevy Luv with a 355 , th350 , Ford 9" 4.11 gears and a spool . I weighs as light as 2780 with me in it to as much as 3210 with me in it . I run a stock suspention , drag radial class that has a 410 ci limit and 3200# weight min . I also run a max of a 28" DR or a 26" slick @ the lighter weight . I will on rare occasions drive this on the street and it will keep current tags and inspection mainly for bragging rights . I will soon replace the 355 with a 397 SBC It should make around 600 hp + an 82 nitous jet ( around 230 hp) . I need a transbrake to be competetive in this class . I have a th350 that is in the truck that is fresh and works good that i could add a transbrake to or I also have a good powerglide with a cracked bell housing that already has a transbrake and works good . I have 2 other pg cases or could just have this one cut for an ultrabell bellhousing . Looking for opinions on which way to go and info on similar set ups .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 07-14-2008, 02:56 PM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: powerglide vs th350
If you go to a glide, you will HATE the uneventfull launches, but love the traction and consistancy. I went from 6' wheelstands to barely bouncing the tires with the change from a TH400 to a 1.80 glide. Althought the launch is now somewhat boreing,,,, the launch is now 'uneventfull' which means less broken parts, no more crushed oil pans, no broken front suspension parts, total control, consistant short times and consistant ET's.
If your going to continue in a D/R class, I'd think a glide is the only choice if she ends up making 600 at the crank.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 07-14-2008, 03:35 PM   #3
hotrod 80
mini truck racer
hotrod 80's Avatar
Thanks for the input . I will be happy if the new motor makes 500-525 to the ground . This one will go on the chassis dyno also .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 07-14-2008, 03:52 PM   #4
regan wilson
regan wilson's Avatar
At your weight I would say go to the Glide . I'll have to stay with my TH400 with my 3700lb tank .
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 07-14-2008, 07:25 PM   #5
bigjimzlll
bigjimzlll's Avatar
Glide.i have never liked a brake on a th350.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 07-14-2008, 09:45 PM   #6
ripdog28
ripdog28's Avatar
Glide, Then send your TH350 to me I am looking at getting my 350 freshened up or a new one for my build so i do not have to pull it out after i brake it due to the new pwr.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 07-14-2008, 09:59 PM   #7
djracer
djracer's Avatar
as noted I would run a glide at your weight. If I was as heavy as Regan I would run the turbo 400. The 350 probably won't like the new power. I would go the ultrabell route!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 07-15-2008, 09:56 AM   #8
regan wilson
Kevin is right about the 350 not liking the power . Unless you replace the input shaft you will definatly have problems . They will snap like a twig .
Old 07-15-2008, 01:48 PM   #9
nxtruck
nxtruck's Avatar
X2 on the th350 input shafts breaking.
At your weight and with the tire and suspension that you're running, I'd go with a 'glide. Those n2o launches will be a lot more manageable with a 'glide.
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 07-19-2008, 12:03 AM   #10
prostreet1967
prostreet1967's Avatar
not to hijack but i am also intrested in this, ive been pricing getting a pg built i currently have a 400 but i want a brake i figured might be a good time to upgrade. my weight is also 3700 with 454 9in 4:56 gears and 33x16 mt slicks.
prostreet1967 is offline   Reply With Quote
Old 07-19-2008, 12:14 AM   #11
djracer
djracer's Avatar
At your weight I would keep the 400! I might be able to get you a good price on a brake for it.
Kevin
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 07-19-2008, 12:49 AM   #12
hotrod 80
mini truck racer
hotrod 80's Avatar
While we are on this subject . How much power can a stock case powerglide take ? Mine has a hardened input shaft with a turbo spline and a manual valve body with a brake .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 07-19-2008, 12:58 AM   #13
Malibu 496
Junior Member
Malibu 496's Avatar
I had a stock case glide in my #3400 malibu and my 496 made 612hp and 608tq and I would spray a 150hp shot on top of that, and I had about 50 passes and alot of street miles on it without any problems.
1970 blazer, street/strip project
1963 ford fairlane sports coupe 50,000 original miles
Malibu 496 is offline   Reply With Quote
Old 07-19-2008, 10:43 AM   #14
djracer
djracer's Avatar
A stock case glide can handle quite a bit but I think you said your bel housing was cracked if thats the case go ahead and get and ultrabell so you don't have to fool with a flywheel shield.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 07-23-2008, 11:38 PM   #15
Outlaw72
Hay Team!!
Outlaw72's Avatar
Another vote for glide here.....oh and prostreet, djracer is right with yours. Stay 400..
1972 Chevrolet Cheyenne LWB "Orange and White" 8)
Outlaw72 is offline   Reply With Quote
Old 07-24-2008, 11:46 PM   #16
prostreet1967
so should i go with a nice 350 over a 400. ive heard alot of bad about 400 being power hoggs and to heavy
Old 07-25-2008, 12:12 AM   #17
Outlaw72
Hay Team!!
Outlaw72's Avatar
With a BBC I would stay 400.....just my input. I have a 350 and even though I have put it through some abuse...I don't know how much longer it will last. If you have any plans to put a more powerful BBC in your truck....make a plan for a 400
Old 07-25-2008, 12:19 AM   #18
ripdog28
ripdog28's Avatar
I am no tranny expert but i do know a little. A STOCK 400 will last longer then a 350 but you take both to a shop and get them built for racing or more abuse not all out race. I highly doubt there will be much difference in ability to handle the power. I know more guys go to 400s but i have seen a lot of guys run 350s in 9-10sec cars and not have any problems.
69 c-10 BBC
Old 07-25-2008, 06:37 AM   #19
djracer
djracer's Avatar
A 400 is much stouter than a 350. If you aren't crazy heavy go with a glide. Power glides are in 75% of all drag cars for a reason. This includes dodges and fords also! You can run an aftermarket bellhousing and put a glide in almost anything!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 07-25-2008, 05:18 PM   #20
70rs/ss
70rs/ss's Avatar
I say the glide for the simple reason of the bell housing issue, as the needed fix is also a safety upgrade you should do as well and the limited street use. My brother ran a glide in has circle track cars too, couldn't break it!
70rs/ss is offline   Reply With Quote
