08-13-2008, 01:24 PM | #1 |
TBI 305/4l60e w/ cpu
No wires were disconnected except power, ground, I layed the cpu over the engine so its a quick swap, came out of 94 truck runs good, gauges read around 215,000 but its clean may not be original if it is it was well kept, I did drive the truck on and off the trailer, and around the block so I know it all works great, tranny felt good but the fluid was dark probably needs a flush and filter $500 obo located near Sacramento, CA dont want to ship local pick up prefered. I will throw the tank and pump in if you want it!!
Tranny is sold make offers on tbi, harness, cpu, gas tank and lines, motor
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap Last edited by Scott68-93-97; 11-14-2008 at 01:28 AM. |
08-14-2008, 02:34 PM | #2 |
Re: TBI 305/4l60e w/ cpu
nobody huh? I thought that was a pretty good price for a motor tranny cpu working combo ready to drop in your ride and get good gas milage... This is a 210hp the 350 in the same year only had 225hp thats only 15hp, a $100 chip will put you over the 350 numbers
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap |
08-17-2008, 07:18 PM | #3 |
ttt gas tank and fuel lines included
08-20-2008, 02:00 PM | #4 |
ttt, offers, trades for 68 parts, I need disc brake kit, grille, hood, etc
08-21-2008, 10:15 AM | #5 |
New price $400, I will seperate if someone wants the TBI setup, the cpu controls both tranny and injection so if you want just the tranny you will have to buy a standalone computer for it, $400 for package, make offers on parts
08-26-2008, 01:54 AM | #6 |
ttt
08-28-2008, 03:00 PM | #7 |
offers? nobody even needs the fuel injection, serpantine kit, tranny?
09-06-2008, 05:30 PM | #8 |
bump offers I need it gone
09-21-2008, 08:13 PM | #9 |
Junior Member
Do you still have the motor & tranny? I may be interested. I have a '68 hood I could throw in.
63 C10 70 Coronet R/T 67 C10 70 Dart Swinger 71 K10 |
09-22-2008, 11:24 AM | #10 |
Out of the carpool lane.
Would the TPI work for a 350?
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
10-03-2008, 05:13 PM | #11 |
Howz abiut the wiring harness?
Thanx, Bud |
11-14-2008, 01:27 AM | #12 |
Sorry guys havent been on here in a while tranny is sold and tbi, motor, cpu, and harness are seperated but all there boxed up
and yes it will work on a 350 it will bolt to any small block with 86 and up heads non vortec you can modify the two center holes on the manifold to bolt to pre 86 heads or buy an aftermarket manifold or spacer/adapter for your 4 barrel manifold
11-14-2008, 01:31 AM | #13 |
its tbi throttle body not tuned port and it will work for a 350 you can even use a 454 throttle body and chip this cpu for better performance and higher fuel demands
01-22-2009, 02:59 PM | #14 |
Sold
