01-30-2009, 11:49 AM | #1 |
new here, new truck
Hi all, I've been lurking on this board for a few weeks. I just took delivery of a 59 today; the battery is dead at the moment, so I'll hopefully know for sure if it runs in a few hours
Big plans down the road, but for now it's going to be driven basically as-is. |
01-30-2009, 12:14 PM | #2 |
Re: new here, new truck
Jealous of your very nicely patina'd apache! Love the tone for sure! Good luck w/it, my friend!
01-30-2009, 01:55 PM | #3 |
Welcome, nice starting point.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
01-30-2009, 01:57 PM | #4 |
Nice find!
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674 My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost 1960 (400/T350/?) Apache 10 short/fleet side-big window 1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4 2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB Doing my part to warm the globe |
01-30-2009, 04:20 PM | #5 |
Hollister Road Co.
It looks to be in good shape for being that far north
01-30-2009, 04:38 PM | #6 |
01-30-2009, 04:40 PM | #7 |
I ended up buying a new battery but it still won't start. It cranks and cranks, but doesn't seem to catch. If I pump the pedal a bit it might catch once but not in any significant way. I checked the plugs and they're quite black but dry. I'm pretty clueless about these things so any thoughts/tips would be greatly appreciated.
01-30-2009, 05:16 PM | #8 |
Yellow truck club
Welcome to another 4 lighter. Great start with the picture posting.
Really like the fleetside. If the plugs are dry give it a little shot of gas down the carb and see what happens. Could disconnect the fuel line at the carb and run the line into a small gas can. Crank the the truck a bit and see if the pump is moving any fuel. If there is fuel then the carb float needle could be stuck. If no fuel then look back towards the pump/tank.
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
01-31-2009, 10:27 AM | #9 |
thanks for the advice. I pulled the hose and it was getting fuel, but quite rusty fuel so the whole system will need to be gone over. I did get it started after finding that the choke was stuck open (the cable is all rusted up) so once I closed that it fired right up.
another question, what do the factory bumper brackets/license plate holder mount to? at the very least I need to get a plate on there and I figure why not get it the right way off the bat rather than jerry-rigging it and having to redo it. Also, any advice where to find a rear bumper? I've seen the one from classicparts but I don't want to pay $160 for a chrome model just to strip it and spray it white. |
01-31-2009, 02:36 PM | #10 |
After you deal with the fuel delivery issues, I suggest that you take a look at the distributor points.
Make sure to file off all the dark gray oxides on the contact faces. Sure, you could simply replaced the points with new ones but if you just want to see if it will run then this will work temporarily. Anyways, that was the key for me when I was attempting to start my 59. It hadn't been running since 1979. |
01-31-2009, 06:40 PM | #11 |
Original Fleetside rear bumpers are very rare, most of these trucks started life as service trucks with an after market bumper or lift gate. They started reproducing them a few years ago. In the 80's I looked for 10 years to find an original one that came chromed from the factory. I have never seen a painted stock rear fleetside bumper, I suspect they were all a chrome option. FWIW I ran my truck with a white painted front bumper and the chrome back one, I figure you can't see both ends at the same time!
01-31-2009, 09:14 PM | #12 |
Right on man!!
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
01-31-2009, 10:40 PM | #13 |
Wow nice truck! Welcome from Maine.
02-01-2009, 12:16 AM | #14 |
Welcome, nice looking truck. New points, condensor , plugs, wires and new gas and she should work like a new one. Good luck.
Jean-Marc Lacasse 57 GMC 55 GMC 55 Belair 99 S10 http://67-72chevytrucks.com/vboard/s...d.php?t=316140 http://67-72chevytrucks.com/vboard/s...d.php?t=806011 |
02-01-2009, 01:13 AM | #15 |
nice looking truck you have there, color looks awfully familiar.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
02-01-2009, 04:30 PM | #16 |
Alden , got yourself a nice looking truck !
02-01-2009, 05:00 PM | #17 |
Thanks! A few pictures after cleaning it up quickly - still needs a heck of a lot more degreaser
who knows what year this is from, but I think it's staying Only one wheel has the clips, are the other wheels usable for the original hub (center?)caps? oh, and some photoshop fun - it'll be a while before it looks anything close to this: Last edited by alden; 02-01-2009 at 05:01 PM. |
02-01-2009, 11:54 PM | #18 |
Looks Great!
Let's see an engine shot. They sell an aftermarket primer rear bumper now for about $100. But you will have to buy the brackets, $120, bolts $20, and a licence plate kit too $35. I will probably go this route on my 59 eventually. Last edited by Texasdeere; 02-01-2009 at 11:56 PM. |
02-02-2009, 06:05 AM | #19 | |
Who sells the primer'd bumper? |
02-02-2009, 01:00 PM | #20 |
I am sure they are not the only ones but LMC has one listed in their 55-59 catalog for a 58-59 fleetside.
I have a picture I will post later of a 59 3200 fleetsdside with an original looking white rear bumper. |
02-02-2009, 01:44 PM | #21 |
Classic parts most likely will have the primer bumper as well. Plus they advertise on our board, thereby supporting it. Not to mention they are way cheaper than LMC, and from my experiences much more polite.
02-02-2009, 05:11 PM | #22 |
I buy almost everything for my 59 from Classic Parts. I will check and see if they have it listed.
Here is that picture I promised: |
02-02-2009, 07:55 PM | #23 |
02-02-2009, 08:55 PM | #24 |
very cool! Thanks for posting that, I'll have to take a picture of the frame rails near the bed so hopefully someone can give me an idea of what all we'll need to mount the bumper once I get one.
02-03-2009, 06:54 PM | #25 |
ToTM Winner
Welcome to the board, its good to see another 4 holer gettin reborn, good luck with your build.
ToTM Winner |
