02-21-2009, 09:39 AM | #1 |
Active Member
Need 4x4 frame cuts ?
4x4 frame cuts, $15 per ft + shipping. Brackets $10 for large, $5 small + shipping.
02-21-2009, 09:06 PM | #2 |
Not a bad nut after all..
Re: Need 4x4 frame cuts ?
I'm looking for '72 Blazer rear frame horns. What kind of a frame is this one?
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
02-21-2009, 09:55 PM | #3 |
wow harry, I could have used the power steering area last summer....
Can you get this measurement for me though? I bought an adapter to mount to my frame and need to know how far back this top hole goes from the rad support mount... ttt for you...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
02-21-2009, 10:08 PM | #4 |
Active Member
bad, this one is is from a '71 K-10
mike, I'll get that meas. Mon. |
02-22-2009, 09:50 AM | #5 |
thanks... might need to PM, this didn't pop back up for me...
02-23-2009, 01:53 AM | #6 |
how much for the two front spring hanger brackets shipped to 72701? Are they bolted on or riveted? if riveted i guess just the first foot or so of each rail.
02-23-2009, 02:27 AM | #7 |
Is there a PS box brace on that frame?
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
02-23-2009, 09:46 AM | #8 |
i will take the first 3 ft of the driver side if the steering box area is good, also if it has the frame brace that would be even better, just let me know the total if still available.
thanks, chris |
03-01-2009, 06:11 PM | #9 |
Active Member
Mike, hope these pics help
03-01-2009, 06:19 PM | #10 |
Active Member
yellowblazer69, here are pics of the LS front frame, $40 + $20 shipping, let me know.
03-01-2009, 06:40 PM | #11 |
Active Member
LS front frame
03-01-2009, 06:51 PM | #12 |
thanks harry...
funny how they are 1/4" different... are they both truck frames?
03-01-2009, 07:14 PM | #13 |
Active Member
Mike, the first 2 are from a '70 blazer, the 2nd 2 from the '71 K-10
03-01-2009, 07:53 PM | #14 |
have any of the crossmembers
atheystruck@comcast.net 67 1/2 ton 4wd custom cab 72 1/2 ton 4wd super cheyenne 71 1/2 BB super cheyenne shortbed |
03-01-2009, 08:21 PM | #15 |
Active Member
Bill, I have the 1st crossmember $25, engine $35, trans $35 + shipping or free delivery to Spring Carlisle. Also trade for Blazer only parts.
03-01-2009, 08:39 PM | #16 |
The main ones I am in need of now are the very rear one and the one over the rear axle. Would you have those?
03-01-2009, 09:46 PM | #17 |
Active Member
No rear crossmembers now, but will be pating a '70 K-20 & 2 '72 blazers soon.
03-02-2009, 08:10 PM | #18 |
let me know if one of those are good. Thanks, Bill
04-19-2009, 12:34 PM | #19 |
Harry,
I am looking for frame cut from the left side of a K10 frame from about where the transfer case cross member bolts to the frame. I need a foot or two. Can get you a picture of exactly what I am looking for if you think you have it. Thanks, Doug
71 Cheyenne Super 4X4 SB 72 Cheyenne Super 4X4 SB 72 Cheyenne 4X4 SB |
04-19-2009, 06:48 PM | #20 |
Active Member
Doug, Somewhere in this area?
04-27-2009, 10:55 PM | #21 |
Harry,
I believe that is the area I am looking for. A little difficult to tell. If you start behind where the front cab mount is a go a couple of feet back that will work. How much including shipping to 93065? Thanks, Doug
04-29-2009, 11:34 PM | #22 |
Do you have a 4x4 engine crossmember available??? If so how much and could you send pics to low900rr@comcast.net
My builds 69 stepside.......2wd to 4wd http://67-72chevytrucks.com/vboard/s...d.php?t=330675 and the new 66 http://67-72chevytrucks.com/vboard/s...d.php?t=302321 |
05-04-2009, 10:42 PM | #23 |
Harry,
Any word on shipping charges to 93065? Thanks, Doug
05-05-2009, 08:03 AM | #24 |
Active Member
Doug, a 2 ft section looks like $31.20 thru fedex home delivery. Thanks
05-05-2009, 11:06 PM | #25 |
Sounds good. PM your paypal account and I will send you enough for 2 feet plus shipping. Doug
