Old 04-04-2009, 02:06 PM   #1
t_graham11
87 frame longbed/shortbed
I recently bought an 87 longbed C10 for $150, is running. good glass good everything stored here on the west coast not driven on the salty roads so its sweet. Now, I've been researching and have came up with little information. there is two different frames built so 2 different size wheel base's 117.5 in (2985 mm) for short-bed and 131.5 in (3340 mm) for long-bed. I found these set of frame dimensions
http://www.chuckschevytruckpages.com/framespecs.html
Now when I frame differences are 14 inchs and the dimensions of the frame diagram is only showing a difference of 10? Its got me confused because I am trying to Shorten the Frame to a shortbed. It might sound silly but I bought the truck for cheap and the frame is good on it, and the front end is good. Does anybody have any suggestions or any information that could help me.... thanks for reading, Tony
t_graham11 is offline   Reply With Quote
Old 04-04-2009, 02:33 PM   #2
bigblock73
yeller
bigblock73's Avatar
Re: 87 frame longbed/shortbed
The difference is because when you shorten a lwb to a swb, senctions are taken out before and after the axle.
There has been several discussions here on the board, do a search and you will likely find your answer from ppl here who have actually done it (I am not one of them).
bigblock73 is offline   Reply With Quote
Old 04-04-2009, 09:32 PM   #3
bigblock73
yeller
bigblock73's Avatar
Forgot I had this on 73-87.com
http://www.73-87.com/7387garage/chas...lwb_to_swb.htm
Old 04-04-2009, 11:28 PM   #4
t_graham11
hey thanks I've been looking on here and have found some very helpful information I was also hoping to find some numbers of the length you cut I know my cut will be different but I was hoping to be close to the same ballpark. Thanks again
custom, frame, frame conversion, longbed, shortbed
