Old 04-22-2009, 02:46 AM   #1
souza777
souza777's Avatar
my 1976 Beast going through transformation!!
Here's the begining!
Got the mouldings off and going to start welding the holes. also got a pic of my son at the wrecking yard, pulling 1/2 ton coil springs so we can drop the 3/4 ton beast! thanks to the awesome info on this site!!!!!!!!!!!!!!!!!!!!!
souza777 is offline   Reply With Quote
Old 04-27-2009, 01:19 PM   #2
souza777
souza777's Avatar
Re: my 1976 Beast going through transformation!!
Ok here's what we did this weekend!! Dropped the front end 3 inches! Had got 1/2 ton springs and put them on and didn't move!! So we cut 2 coils off the 3/4 springs and "BAM" down it went!! Still debating on what I'm going to do with the rear? Thought about drop shackles and taking some leafs out or just do the flip???????????????? hum hum hum?????
Old 04-28-2009, 07:21 AM   #3
Turbo85GMC
Turbo85GMC's Avatar
Looking nice! I'd say a flip kit in the rear. That would make the stance real nice.
'85 GMC 1500
"Friends don't let friends drive stock!"
Turbo85GMC is offline   Reply With Quote
Old 04-28-2009, 03:22 PM   #4
souza777
souza777's Avatar
thanks turbo!! really starting to lean that way!!
Old 04-28-2009, 03:59 PM   #5
tvblazer78
Low & Fast!
tvblazer78's Avatar
Looks like some work to me.. Keep that moulding it is getting hard to come by, I am kicking my a$$ for giving mine away.. And looks good..
tvblazer78 is offline   Reply With Quote
Old 04-30-2009, 04:01 PM   #6
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Sweet looking truck its looking good so far. Should look great when the back gets closer to the ground. My vote is for a flip kit in the rear as well just my .02 cents.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 04-30-2009, 04:08 PM   #7
jchav62
1962 C-10
jchav62's Avatar
Looking good! If that trim you took off is getting in your way, send it my way!
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 04-30-2009, 05:17 PM   #8
souza777
souza777's Avatar
Alot of the trim got damaged when we took it off. I took it off before I found this awesome site full of info!! or I would of asked for the best way to get mouldings off without damage!!!
Old 05-03-2009, 01:11 AM   #9
souza777
souza777's Avatar
Ok wanted to see what it would look like if I took some plates out of the leaf springs!! So here it is!! Not to bad!! What you all think??????
Old 05-03-2009, 02:50 AM   #10
flamingbig10
6.0 powered square
flamingbig10's Avatar
looks good you can get 2" drop shackles at any auto parts store cheap
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 05-11-2009, 02:04 PM   #11
souza777
souza777's Avatar
Got a ? what do you all recomend for filling the moulding holes?
Old 05-11-2009, 04:02 PM   #12
flamingbig10
6.0 powered square
I would weld them up
Aaron
Old 05-11-2009, 10:05 PM   #13
bigblock73
yeller
bigblock73's Avatar
Welding them up is the only way to go IMO.
Truck looks great! I do think I would like it better with the trim however.
bigblock73 is offline   Reply With Quote
Old 05-12-2009, 03:08 AM   #14
84 400
Sb 400 club
84 400's Avatar
great project! I liked it better with the trim but it looks good dropped like you guys did. Keep up the good work
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 05-15-2009, 10:14 AM   #15
manimal
manimal's Avatar
Nice looking truck! Are you planning on leaving the 8 lugs? I really like the stance. I too agree with others, the trim would have made it look even better.
-Lance
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 05-18-2009, 12:20 AM   #16
heavychevy79
Cheyenne Super
heavychevy79's Avatar
I would have kept the trim too.
Keep it 8 lug for sure, you'll have a better choice of wheels.
heavychevy79 is offline   Reply With Quote
Old 06-05-2009, 03:06 AM   #17
rome704
rome704's Avatar
looking good bro
rome704 is offline   Reply With Quote
Old 06-14-2009, 08:14 PM   #18
bb1979
bb1979's Avatar
You might want to remove the front bump stop mounts if you haven't already done so. Also replace the upper a-arm bolts with longer units to allow for alignment and you will more than likely need a spacer between the shims and the chassis otherwise your shim stack will be an inch give or take thick.
Reminds me of mine when I first dropped it.
1979 C20 pickup 454 big block turbo 400, 4.56 gears
bb1979 is offline   Reply With Quote
Old 06-15-2009, 01:47 AM   #19
souza777
souza777's Avatar
thanks!! ya I already buzzed off the front stops. but was wandering what to do with the wheels being so slanted? so where would you suggest I go to get the longer bolts and shims?
Old 10-02-2010, 09:31 PM   #20
nbpro
flip kit in the rear with the trim on as well
nbpro is offline   Reply With Quote
