Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 05-20-2009, 07:56 AM   #1
72BlckButy
Tot Roddin'
72BlckButy's Avatar
How many use Spray-On Detailer's?
We washed up the fleet this weekend and this was the first time I used a spray on wax/detailer following the wash. It seemed to provide a slicker finish to the paint once it was wiped down.
So what are your experiences?
What products do you use?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 05-20-2009, 08:25 AM   #2
70k52wd
Blaze-Air
70k52wd's Avatar
Re: How many use Spray-On Detailer's?
I love the quick detailer. I get my best results after I wax it. Then use it between wax. I can put a fresh shine on my blazer including the top in about 5-10 min. No haze either. I love it. I use Meguires. I'm sure there may be better stuff out there. It works well for me though.
70k52wd is offline   Reply With Quote
Old 05-20-2009, 08:27 AM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Do you apply your spray while the vehicle is still wet? Use a chami to wipe it off?
I was amazed how much of a difference it actually made by using a spray-on detailer. I definitely added a new process to my cleaning regiment...
-Nate
Old 05-20-2009, 08:53 AM   #4
70k52wd
Blaze-Air
70k52wd's Avatar
I use it on dry. I think wet works also. I just never have tried it. As far as a chamois goes. I don't really like them. I feel like they remove wax. I use very high quality towels. I buy towels to match color of vehicle. I never use fabric softener on towels when I wash them as that leaves a residue. Another trick for removing wax. I never swirl wipe. I straight line wipe. Swirl wiping shows up in the sunlight easily. Straight line wiping keeps the illusion of marks down when the sun hits it. Hope that makes since to you.
Old 05-20-2009, 08:59 AM   #5
70k52wd
Blaze-Air
70k52wd's Avatar
I meant to ask if you have tried a clay bar. They are magic. Get one, use it. Your truck will love you for it. And don't use one of those soft squeegees after you wash. they will leave scratches eventually.
Old 05-20-2009, 02:13 PM   #6
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Charlie, great posts above. I have yet to try the clay bar process, but when I get a spare moment around the house I am planning on using one on the '69. I used the chamois on my '08 but sprayed the detailer on the truck before I wiped it down with the chamois. After the chamois removed the majority of the water/detailer I came back with an extra soft cloth I had to finish wiping the body down to a clean luster.
One thing I did notice when using a chamois and detailer together was that I didn't end up with "water streaks" once I wiped off a panel. It seemed to use the water to help spread the detailer while pulling more water off the truck as well. Does that make sense?
Above you mentioned that you purcahsed high quality towels, are you referring to a microfiber towel? Mothers, Meguiar's...?
-Nate
Old 05-20-2009, 02:56 PM   #7
BigDaddyDave
RIP BigDaddyDave ~7-23-09~ You will be missed~
BigDaddyDave's Avatar
A good detailer is great between waxing. I use a lot of Meguires products and like them all. I use to detail for a living and i learned to stay with one line of products.
BigDaddyDave's Truck: http://www.flickr.com/photos/daves71chevy/ | See it in Action!
BigDaddyDave is offline   Reply With Quote
Old 05-20-2009, 06:55 PM   #8
70k52wd
Blaze-Air
70k52wd's Avatar
I use cotton towels. That's why I purchase in my case black, because of the lint. I will use my California duster to remove that.
I'll try the wet, chamois, detailer combo.
Old 05-22-2009, 07:59 AM   #9
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I've had a California duster in storage for about 3-4 years now, so I guess I need to finally break the packaging and start using it.
-Nate
Old 05-22-2009, 09:07 AM   #10
70k52wd
Blaze-Air
70k52wd's Avatar
It's true what they say. The dirtier it gets, the better it works.
And yea, I think your new baby deserves the best care possible.
Just for instance, the paint on my truck is 25 yo. It has been washed a minimum of times. Actually it goes years without water hitting it. Every weekend when I showed it. I wax it. Then I get to show and use detailer on it. I get home and detailer once more, cover it. Next weekend, I would pull cover, california duster it. Wax it, go to show. Repeat process. The longest I've gone without getting it wet, other than sitting in the garage; I went around 3.5-4 years before I had to strip it and start process over. Right now, I'm thinking of a wet sanding and buff. The paint is thin in places though.
I clay bar about 2-3 times a year. That's a huge step in protection. If you think your paint is free of debris. Wash, wax, then run the back of your hand over it. Feels smooth right? Now, clay bar it and feel the difference. It will be noticeable. Then wax it.
Since I'm rambling. One more wax trick. I have only done this a few times myself. After you wax. Rinse with really cold water, then dry as usual. It's supposed to give the wax a harder setup. I got that tip from Lowrider Mag. They would actually put ice in a bucket of water to pour over a fresh wax job. Those guys really know how to treat there High dollar paint jobs. That's where I learned to remove wax in a straight line also.
Old 05-22-2009, 12:48 PM   #11
big_al_71
big_al_71's Avatar
I am a huge fan of eagle one products this wax below works awesome..
http://www.eagleone.com/pages/produc...=1121&cat=5010
This wipe and shine I use all the time as I also do not wash my truck as it sits in a garage with a cover on. When it is dusty from sitting I use this product and it comes out terrific..
http://www.eagleone.com/pages/produc...=1076&cat=5010
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 05-22-2009, 01:34 PM   #12
Nolowrider
Nolowrider's Avatar
I just started using Eagle one. I am very pleased so far. Seems like good quality stuff.
Nolowrider is offline   Reply With Quote
Old 05-22-2009, 05:28 PM   #13
70k52wd
Blaze-Air
70k52wd's Avatar
I've always used Meguires products. I know theirs equal, maybe even better products. I should try the Eagle stuff. I've noticed a few people using it.
Old 05-22-2009, 07:39 PM   #14
boatpuller
boatpuller's Avatar
i always use meguiar's quick detailer.work's for me.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 05-24-2009, 06:29 PM   #15
leddzepp
Moderator
leddzepp's Avatar
A clay bar is the best way to go...it will make old paint look new. Use a spray-on detailer like Meguiars to lubricate it as you rub it on the paint.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 05-24-2009, 06:47 PM   #16
leddzepp
Moderator
leddzepp's Avatar
oops...double post
Old 05-24-2009, 08:49 PM   #17
piecesparts
Parts and more parts
piecesparts's Avatar
Once again detailing is a subject that brings everyone out of the woodwork. I was introduced to a spray detail item many years ago, from Mother's and since then I have tried many dofferent ones with my final choice being a product from Wizard's products. laugh if you want, but their stuff walked all over Mequires at their little detail seminar back during one of the hot Rod Power Tours and I carry the stuff in ALL of my vehicle. It is for the really bad bugs and of course the dang birds.
I know some of you have seen my black truck and the finish that I have. It is hard to keep black clean--this stuff makes that a lot simpler than most think.
http://www.wizardsproducts.com/
piecesparts is offline   Reply With Quote
Old 05-25-2009, 12:42 AM   #18
UltraBlue71
UltraBlue71's Avatar
I love Eagle one wax as you dry too, works great! Is it me or does that stuff smell like bubblegum? I want an air freshener that smells just like it!
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG...
71 LWB
UltraBlue71 is offline   Reply With Quote
Old 05-25-2009, 08:50 AM   #19
70k52wd
Blaze-Air
70k52wd's Avatar
I'll be switching to Wizard as soon as I go through all the stuff I already have.
Old 05-25-2009, 09:53 PM   #20
boatpuller
boatpuller's Avatar
can ya buy wizard's in a store ? or is it mail order only? i'd like to try it.
Old 05-25-2009, 10:09 PM   #21
piecesparts
I know of a couple stores in my area, that sells the product, but I found that ordering from the internet was the best way for me. I have it in my basement and always ready for use. I would check through Wizards, to see if they list any suppliers in your area.
Old 06-04-2009, 08:07 AM   #22
72BlckButy
Tot Roddin'
72BlckButy's Avatar
This past weekend I was able to use a detail sprayer on my '69 and it helped to keep the shine there. The truck truly needs to be waxed, but the spray on detailer will definitely help until I have the time to get it waxed.
I'm sold!
-Nate
Old 06-05-2009, 06:44 AM   #23
Mudder
Mudder's Avatar
A heads up. Never store your products outside in and unheated garage during the winter. Freezing will destroy most detailing products.
I use California Customs M-Ron for waxing and will follow up with Meguires #34 in between waxes. No silicone in either. I also use a chamois but will not use it if it is ever dropped on the ground. I have not dropped very many. Good way to ruin a good paint job.
Mudder is offline   Reply With Quote
Old 06-05-2009, 07:21 AM   #24
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Excellent points Mudder!
While we're on the subject do you prefer to use a chamois or a microfiber towl?
-Nate
Old 06-20-2009, 01:51 AM   #25
hotrod 80
mini truck racer
hotrod 80's Avatar
Has anyone tried the Lucas oil detail spray ?
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
