08-20-2009, 08:44 PM | #1 |
Fyi 12 bolt rear wheel bearings ( updated )
I went looking for rear wheel bearings for my 12 bolt axle today. Boy what a difference in quality from each auto parts places. All except napa had larger but fewer bearing rollers. Napa had the " only " same as oem number of rollers in there bearings so napa was installed. Got my "timken " brand h/d oil seals at autozone. They was the best seals i could muster up, axle and pinion both. HOPE THIS HELPS SOMBODY.....
BOB update... got my ac delco wheel bearings today and there the large, fewer rollers style not like the original small roller and more of them. back they go.... I,am gonna stick with the napa replacement bearings as there just like what came in my truck new ( but there made in CHINA......)
I BELIEVE IN JOHN 3:16 Last edited by BCOWANWHEELS; 08-29-2009 at 01:04 AM. |
08-20-2009, 09:44 PM | #2 |
Restoration Virgin!
Re: Fyi 12 bolt rear wheel bearings
Hey Bob,
Got any pics of the install of the bearings...I gotta change my rear axle oil seals and might as well change the rear axle bearings too....Also, I gotta get a bearing puller from some place too...what did you use? Also also, would you mind posting up part numbers and price?? Thanks
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
08-20-2009, 11:17 PM | #3 |
NAPA does say " Get the good stuff"
Please post pics if at all possible, it really helps out newbies like me
72 C20 Longbed 05 1500 Z71 |
08-21-2009, 04:49 AM | #4 |
I had a V-8
I sold parts at a "mom and pop" store for many years. We tried to sell nothing but the best parts available. Over the years I noticed trends in component longevity. I would see customers come back for the same part every few years and it got me to thinking about quality and materials.
I did some research on many parts over time and one of the parts were semi-float wheel bearings. I got to looking at these because many times a bearing failure on an axle assembly of this type means a destroyed axle shaft. We sold BCA and while their service life was acceptable, I compared them to other brands including dealer parts. Just a note to start off with: most bearing companies do not make their own bearing of this style--they put someone else's bearings in their boxes. What I found was the bearings made by INA/INF were complete garbage. I had a customer bring in one that failed in an absolutely spectacular way. It was reduced to mere bits and pieces (and took out the axle shaft). The best quality in both appearance and materials was made by Torrington. Now, I do not know if Torrington brand bearings can be bought outright, but they come boxed in higher end bearing company boxes. I got mine through AC Delco. This is the brand that GM uses as original equipment. I have run these for years and have never had a failure. I also compared the seals. While every manufacturer has their own seal for these diffs, they also vary greatly in quality. The National brand seal that we sold was very inexpensive and I thought that to be odd for a "better quality" seal company. I compared the top brands i.e. National, C-R, and Timken. They were all similar in construction, materials and price. I decided to order some from GM and see what they look like. There was absolutely no comparison between the GM and any other brand. They do cost more--I *think* the last time I bought them they were about ten or eleven dollars apiece--but it has been a very long time since I bought some because I have not had to replace them. The quality of materials was much higher than the aftermarket units. The thing that struck me the most was the weight of the seals. They felt like they weighed three times as much as any other brand. Obivously thye didn't, but they were MUCH heavier. The ironic part is those seals are made by C-R or National, but they are made to GM specs. The same manufacturer's aftermarket line of seals have no specification requirements--they just have to fit and function, but no rules guiding materials used or service life expectations. So with that, I only use the Torrington brand bearings and GM seals for this job because I REALLY do not like doing it. Now, this is just my opinion on the subject and a little background on how my opinion was formed. I am NOT saying that other manufacturer's products will not offer an acceptable service life, just why I use what I use. *Disclaimer* The information provided applies only to the bearings and seals for the semi-float axle wheel bearings and seals. I use National seals on my 14 bolt full float and have for many years with no issues. Their tapered roller bearings are top quality and many are still made in the US as are Timken.
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE. |
08-21-2009, 06:42 AM | #5 | |
I think this will get you to it http://67-72chevytrucks.com/vboard/s...ight=star+vary
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! Last edited by Luvlegs; 08-21-2009 at 07:16 AM. |
08-21-2009, 08:39 AM | #6 |
Restoration Virgin!
Sweet...nice write up Darren!!!....Thanks!
08-21-2009, 05:07 PM | #7 |
I am a Referee of life.
When shopping bearings,quality is hard to beat.If you're in a major city there is a company called "Bearings Inc".They usually have just about any bearing and seal in about any brand you specify.You may have to wait a day or two for something ,but the parts and service I've had from them has been top notch.I usually have a rep thru work that does industrial stuff so i have an "IN"
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 08-21-2009 at 05:07 PM. |
08-21-2009, 09:20 PM | #8 |
just to satisfy my mind i ordered a bearing set today from my local chevy dealer. there the same up to 1977 he told me. my cosy was right at 24.00 each. i,ll keep em in my stash for next rear end build. i compared my timken seals to oem and they looked as good or a little thicker so i,ll stick with them. i,ve used both napa bearings and timken seals up to now in all my 67-72 pickups with no problems. one thing i forgot to mention. i packed the wheel bearings with amsoil h/d synthetic grease and the back side of my seals was loaded full of same also seal surface was greased before axle install. after bearing & seal was installed i added more grease with my finger too just to fill the cavity between the seal and bearing. just for added protection. just the way i do it.
bob
I BELIEVE IN JOHN 3:16 Last edited by BCOWANWHEELS; 08-21-2009 at 09:20 PM. |
08-21-2009, 09:53 PM | #9 |
i put wheel beaing in my boss's 88 s-10 blazer on the rear and he said put the cheapest in there well i pulled the gm bearigns out and installed a set of motor city bearing from advance auto parts I DID NOT even put the axles back in because the bearing slide intot the rear end and had so much play in them. i took them back and got a set of national bearing and they taped in fit tight had no problems since
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
08-21-2009, 09:55 PM | #10 | |
i would never put greece in the rear end bearings seeing they are lubes by the gear oil i really wouldn't want the gease in my rear end lube but thats just me
08-21-2009, 10:04 PM | #11 |
They need a good snug fit for sure. You know all the new semi truck hubs have gone to grease now....
I BELIEVE IN JOHN 3:16 |
08-25-2009, 10:44 AM | #12 |
Subscribing to this thread thanks to mosesburb's write up! That'll be great info when I get around to it.
1967 C10 LWB 454/TH400 1971 C10 SWB 1984 C30 LWB Dually 454/4 spd 4:10 2003 GMC Sierra 2500HD Crew 4x4 6.6L Duramax/Allison |
08-25-2009, 01:55 PM | #13 |
Agreed. Good write-up!
04-19-2015, 12:24 AM | #14 | |
Re: Fyi 12 bolt rear wheel bearings ( updated )
http://www.napaonline.com/Catalog/Ca...9TV_0329214404 This is their value line though at $10 each, and it seems that every other brand has the fewer/larger rollers. I think I'm going to go with the pack and just get National!
1968 LWB C20 / AC / Wood Bed |
04-19-2015, 12:50 AM | #15 |
The more rollers in the bearing the more it spreads the load stress out. The fewer rollers the more weight on the rollers hence more wear on axle and bearing.
04-19-2015, 02:17 PM | #16 | |
Idk, I'm just really hesitant to put $10 value line bearings on my new axles! I did find a set of NOS made in USA bearings from the 70's or 80's on ebay, one bearing has the fewer/smaller rollers and one has more/bigger -- maybe I'll pick it up and see which one lasts longer!
04-19-2015, 04:28 PM | #17 |
Well then just put the large roller bearings in then. ALL I,AM OFFERING IS MY SPERIENCE AND GM THEN IS PROBABLY WRONG ALL THESE DECADES FOR PUTTING THE SMALL I.D. BEARINGS IN...
04-20-2015, 12:14 PM | #18 | |
If I could locate a manufacturer that makes both versions I'd call them up and ask the difference, but I couldn't find one that does both unfortunately.
