10-26-2009, 11:17 PM | #1 |
frame to start a 56 from
My buddy just picked up a 56 sitting on rockwells for the axles and I can get it for next to nothing. Since the frame has been modified for the huge leafsprings I was wondering what frame would be a good starting point. I know a lot of 47-54's are being built on S10 frames, so is this a good place to start? Since I Have not worked with any thing older than a square body I figured I would ask you guys.
Would a square body frame make a nice starting place since I want this truck to lay rockers?
1949 Five Window, 1973 Step Side, 2000 Z71 |
10-26-2009, 11:44 PM | #2 |
Re: frame to start a 56 from
S10 track is too narrow unless you run wheels with a huge dish front and back. The square frame track I believe is too wide if wanting to lay rockers.
On my panel I'm laying rockers with 29" tall tires. I'm going to go shorter later on, but that's what I have. If you are wanting to lay rockers the stock frame will work fine because you will need to mod both front and rear suspension anyway.
2001 GMC SIERRA 1956 Chevy Panel Build Page with a Scott's Hotrods IFS 1953 Chevy trucks Project Dime Time 1968 Camaro 1968 Volksrod "NOBACK" Jared |
10-27-2009, 12:00 AM | #3 |
I went through your build and let me tell you the dodge spare rims with the chevy caps is an awsome idea. Your panel looks killer tuckin those massive tires.
So the dime isn't gonna work. I guess I will have to kick a few ideas around and see what comes about. I was wanting to stay all GM so well see how well that plan works out. What did those center caps come off of by the way?
1949 Five Window, 1973 Step Side, 2000 Z71 Last edited by ghettoluxury; 10-27-2009 at 12:00 AM. |
10-27-2009, 12:11 AM | #4 |
You could do a camaro clip on the frame to get IFS and stay GM.
Caps are from the AD truck, but don't know which year.
10-27-2009, 12:21 AM | #5 |
I will have to talt to a few of dads old hot rod buddies and see what they think. IIRC Chuck used to have a 55 that had IFS.
10-27-2009, 04:37 PM | #6 |
I am going to be using an 84 frame under my 56.
I had a thread going about a frame swap a while ago,that you might find some info posted to help you to decide which way to go. One of the guys posted up a place that has kits to bolt your body onto a 73-87 chevy frame. Try e-zchassisswaps.com. Kits seem like they take a lot of the work out of swapping the frames. The guy was really good to deal with in anwsering all my questions too.
09 GMC 2500HD 6.6L 07 F-250 Super Duty V10 03 Chevy Tahoe 82 K5 blazer plow truck,currently under the knife 56 GMC stepside short,also in progress |
10-27-2009, 05:31 PM | #7 |
I'm biulding a new (different) frame to put my 4x4 57 on. You can find a stock frame and do it this way. http://67-72chevytrucks.com/vboard/s...d.php?t=368287
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway Last edited by blackdiesel; 10-27-2009 at 05:33 PM. |
10-27-2009, 07:28 PM | #8 |
A320 Pilot/USAF Retired
I vote for the stocker as a starting point!!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
