Old 11-14-2009, 11:14 AM   #1
eric67m
eric67m's Avatar
cross member and oil pan?
These pictures are of my 67 K10. The engine cross member has been cut and extended down about 1". The oil pan clears by about 0.5" The engine is a 327 small block.
I am going to be switching my engine to a different frame. I assume the oil pan will hit the other crossmember and want it to work.
Is my oil pan odd or incorrect?
Are my motor mounts wrong? 6 cyl or big block?
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job"
eric67m is offline   Reply With Quote
Old 11-14-2009, 08:48 PM   #2
Livrat
Member #1049
Livrat's Avatar
Re: cross member and oil pan?
You just have an early passenger car oil pan with a center stepdown.. everything else is correct for a V8.
You will need to find a different pan to use an unmodified crossmember..
I do believe I have one at the shop that you can have.. I will check Monday...
Livrat is offline   Reply With Quote
Old 11-14-2009, 09:53 PM   #3
msgross
msgross's Avatar
interesting..
Here is my 68 K-10 with 327
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 11-15-2009, 01:45 AM   #4
OrrieG
OrrieG's Avatar
I looked at all the engines I have had in my 59 and all three (350 and two 283's) have the single drop pan like the post below. Maybe the double drop plan was a factory larger capacity for an auto or larger truck?
OrrieG is offline   Reply With Quote
Old 11-15-2009, 10:05 AM   #5
eric67m
eric67m's Avatar
When I changed my timing chain and had to drop the oil pan I realized that the crossmember was hacked. I just figured that 4x4's had less clearance (which I had heard). I did not realize that the P.O. had hacked it in an engine swap. Come to think of it, when I was trying to figure out the engine suffix code it said that it was out of a impala or a camero (TO325HCH). I just assumed that most oil pans were the same.
I suppose that I could move that hacked crossmember over to my newer frame and keep the good one if I ever get a proper pan. I would just like to have as many things semi-proper and not have to fix it later.
Livrat, if you had a pan that would be excellent. Let me know if you do!
