Old 11-14-2009, 09:38 PM   #1
cparman
sharp as a marble
corporate vs dana 44 front axle backing plates
This might be confusing. I have a friend that is building a SWB 3/4 ton 4X4. Started life as a swb 1/2 ton, but he has a small junk yard, and put together 3/4 ton 8 lug front and rear axle assys, along with a transfer case and a big block. My friend was looking for a front hub, which WHISKEYDENTED helped with. Went by to check on the progress today, and Donald was perplexed about why he could not get the front brake calipers to mount? I want all to know that he has pieced and parted together what he has completed.
We went for a walk today, and he showed me a " corporate " rear end where the front brake rotor did not extend past the dustshield/backing plate.
The truck build has the front rotor extending past the caliper mount/backing plate.
He had another set of backing plates that did resolve his problem, but he/I would like to know what is up with this.
I do have a couple of pics, but they are on my phone. may not be smart enough to post them.
cparman is offline   Reply With Quote
Old 11-14-2009, 09:44 PM   #2
msgross
msgross's Avatar
Re: corporate vs dana 44 front axle backing plates
hmm, there are a few different options when you start mixing 1/2 and 3/4 ton.. and corp and dana axles... Send pics of what you have, not sure if i'll be of any help but I did build a corp 10 out of a dana 44 axle. Some items swapped and some didn't.
I also have a spare front backing plate
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 11-25-2009, 10:33 PM   #3
msgross
msgross's Avatar
any updates on what you found?
The Garage:
