Old 11-16-2009, 06:51 PM   #1
Jaybird2
Jaybird2's Avatar
New steering box
I put a new steering box on my 71 blazer. The problem is that now it turns further to the left than the right. Is this solved by adjusting the drag link?
Jaybird2 is offline   Reply With Quote
Old 11-16-2009, 07:21 PM   #2
mastertruckmaster
mastertruckmaster's Avatar
Re: New steering box
You will need to center your new steering box. Then put your pitman arm on with your wheels pointing straight ahead. Any small adjustments needed can be made with your drag link.
mastertruckmaster is offline   Reply With Quote
Old 11-16-2009, 11:15 PM   #3
Jaybird2
Jaybird2's Avatar
Thanks for the help.
Old 11-17-2009, 08:40 AM   #4
OLDCHEV4X4
OLDCHEV4X4's Avatar
The pitman arm will only go on the sector shaft one way.
Center the steering box.
Adjust the drag link till the wheels are strait.
If the steering wheel isnt strait, remove, rotate, and reinstall.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 11-25-2009, 10:31 PM   #5
msgross
msgross's Avatar
good info gang...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
