12-06-2009, 05:03 PM | #1 |
Under Construction
67-72 k10 frame id questions
I have a line on a '72 k10 roller. I have no knowledge of the k10's
I have only messed with c 10's, but miss my k5 4x4 so this could get me back in the 4wd game. Are there any telltell sign or anything I should be looking for to verify 67-72? Thanks for any input / suggestions. I'll pull up Mike project money pit and get a refresher on what his frame looks like just didn't want to overlook anything.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 12-06-2009 at 05:05 PM. |
12-07-2009, 01:16 PM | #2 |
Re: 67-72 k10 frame id questions
That`s a good one to come across.
The rear shocks aren`t staggered from front to back like`73-up.If the bumper`s off the front you can tell by the frame horn shape,which is just like 2wds on the end.The later rames are a bit longer in front and the horns would need cut to mount the 67/72 bumper to look normal.The core support mounts on the frame would need moved on a newer frame or the core support bolts will be relocated through the frame.
12-07-2009, 01:27 PM | #3 |
Under Construction
Thanks Tim!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
12-08-2009, 09:57 AM | #4 |
The 72 should have a d44 disc front rear,the frame should a extra plat welded on the inside where the steering box bolts to the frame,the driver side front frame spring mount will have a plate welded across the front( I know the balzer frames do I am not 100% sure on the k10)There are alot of small changes between 67 to 72.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
12-08-2009, 10:28 AM | #5 |
Under Construction
Thanks for the info duallyjams!
12-08-2009, 11:16 AM | #6 |
The trucks had the plate across the front of the driver`s spring perch and bolted on stop behind,also.
12-08-2009, 05:15 PM | #7 |
6>8 Plugless........
Also the 67-72 front spring shackle mount bolts into the flange and face of the frame, as the 73-87's only bolt in the face of the frame.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
12-24-2009, 07:09 PM | #8 |
Under Construction
well, it turned out not to be a '72 but a '69 other than not having disk brakes not sure what else was improved from '69 to '72.I had to save it from the field hopefully i got into it good.
12-24-2009, 07:15 PM | #9 |
Under Construction
more pics...
12-24-2009, 07:38 PM | #10 |
Well, Whoop-dee-do!
Cool... you didn't mention it was a shortbox! Nice bones to start with- just swap in a newer disc brake front axle and get started!
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD '72 K20 500 Cad/TH400/NP205 SOLD '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car |
12-24-2009, 08:09 PM | #11 |
Very cool! You don't see those laying around too much anymore!
12-24-2009, 08:17 PM | #12 |
Under Construction
thanks guys!
Get ready for all my questions in the future. I'll start a build thread when I start messing with it.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 12-24-2009 at 08:18 PM. |
01-27-2010, 10:38 AM | #13 |
Its Topless Season!!!!
Awesome find Heath...you don't see alot of 69-70 SWB K10's around as opposed to the later models, congratz!
01-27-2010, 11:08 AM | #14 |
Under Construction
Thanks Carlos..... i looked for awhile.... I did have to drive to gainesville for it.
02-14-2010, 11:55 PM | #15 |
Still Learning
Great looking truck! Wrap up the kids truck and start wrenching on this one!
02-15-2010, 10:52 AM | #16 | |
Under Construction
Thanks, thats the plan Mike.... I was able to get some patch panels for the hack job the po did on the k10 floor, as a member was scrapping a cab.
02-15-2010, 08:52 PM | #17 |
nice find... I know the brake lines in the rea changed over the years, and you will want to keep an eye out for a disk brake front axle, it will bolt right into that frame. Just be sure to match the gear ratio of the rear axle...
Looks like it already has a 4" lift so you can run 33x12.5's pretty easily..
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
02-15-2010, 09:36 PM | #18 | |
Under Construction
Thanks Mike, I acquired a '72 front disk brake axle, just have to read up on the haynes manual and figure out how to get the shafts reinstalled etc.
02-15-2010, 09:39 PM | #19 |
the axle shafts? easy... There are a lot of DANA 44 rebuild pages on the net... everything slides in and is held by the spindle... just get the bearings right!
02-15-2010, 10:07 PM | #20 | |
Under Construction
I need to read up for sure. will take it all down and clean it up/rebuild in the future....
