Old 12-07-2009, 02:57 PM   #1
laydc20
rear end help for 72 c20
im thinking of putting a rear end out of a newer gmc jimmy or envoy in my truck so i can lay out on my wheels. the rear end has discs and is out of a 4x4 w/4.3. let me know what u guys think.
laydc20 is offline   Reply With Quote
Old 12-08-2009, 10:13 PM   #2
capev86
Re: rear end help for 72 c20
ok....let me get this straight.....you want to put a dinky little axle on an 8 lug 3/4 ton burb?
......why not just get a 2000+ 2500 or 3500 gm rear axle complete with disc and keep the rugged status of your classic truck! i'd have gone that route on my 72 burb 3/4 ton, but it is simpler just to change the rear gear and adapt the brakes and keep the vintage axle that looks really cool.
capev86 is offline   Reply With Quote
Old 12-15-2009, 05:55 PM   #3
Dragsterbus
Dragsterbus's Avatar
I'm going to change the rear in my '69 C20 at some point, it's an Eaton with stupidly low gears (the 22" wheels help a bit though!) i'm just waiting for a later 8 stud axle to come along that i can get decent ratios for
Dragsterbus is offline   Reply With Quote
Old 12-16-2009, 10:14 PM   #4
capev86
there is a 4.10 ratio available for the ho52......pretty easy to do the swap and you are talking a 3/4 ton truck so anything less than a 3.73 is kinda soft. i am doing the gear swap on my 72 burb and eventually will add the factory OD unit to the saginaw (3 on the tree). i say soften the gearing a little and put in an overdrive....then you have the best of both worlds.....although a late model 14BFF would be killer in your old burb with trailing arms.......and have disc brakes and 3.73 gears. also...the newer axle will give a wider stance and more stability and bring the tires out to match the body lines better.
Old 12-22-2009, 04:00 PM   #5
63chevyll
gets board easy.......
63chevyll's Avatar
those are prett week, do you need options for a smaller one?
63chevyll is offline   Reply With Quote
