Boyds rear mounted tank
I sent some specs to Dave and he built me a nice rear mounted tank. Still working out some fitment issues but you get the idea.
Re: Boyds rear mounted tank
more...
and more...
That my friend is "NICE".
I guess that solves the "where do I put the filler?" question. What are your plans with this truck? I assume you don't plan on having a hitch back there...or will it still fit?
Curry in a Hurry: SB rebuild for my 71 C20 |
Really nice. How many gallons does it hold?
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
Thanks all.
I have no plans for a hitch or towing but depending on what type of hitch you used, it may still fit. It's about 18 gallons. |
I had Dave make one a few years ago, that's the first attempt at a rear filler though, nice work. It look like the filler will reduce the amount of capactiy a little though.
I think you could still run a regular hitch with that setup, no hidden hitch though... does it drain to the front?
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 12-20-2009 at 09:44 AM. |
![]() Join Date: Sep 2008
what did it cost u
$359 to my door.
Adam B
Do you see any ideas on how to make the tank a larger capacity, possibly 25 gals? I have been looking at various ideas over the years, and I would prefer something a bit bigger than 18 gals, especially since V8's don't get the best mpg.
Any ideas or thoughts? Adam |
Depends on what else you may be doing with your truck. The tank could easily be a couple of inches deeper (lower) and a few inches longer (front to rear).
#13 | |
How are you planning on attaching the tank? A rear tank is near the top of my list and I'm really interested in your setup since the fill is really straightforward. (or straight backward in this case ![]()
#14 |
Frequent Flyer
Thats a nice looking tank!
I wish I would have seen this back when we did my Dads 76 tank conversion. |
#15 |
Adam B
I was just checking in to see how this conversion was working out for you? I was going to take some measurements in the follow week to see how much of a larger tank you could get by with. My truck has a drop of 4/6, so I need to see how far I can go.
With '73 and up era trucks, some suburbans had a 25 gal tank that might fit. I need to take some measurements, but maybe your tank builder could make an even bigger tank. With most stock 350's making 10-14mpg, I want to get the biggest tank available. Adam |
#16 | |
aboyer, I have no idea how it works yet. It fabbed up ok but I wish I would have gone with about 12* on the filler though instead of the 15* that I went with because I think I'm going to end up dropping the tank down just a little to get the filler in the right spot in the license plate opening. I kind of pushed this to the side for a while so I could get the sheetmetal work done on my cab. Hopefully I'll finish the fab work by the end of this month. We'll see. |
#17 |
id like to see how this turns out
#18 |
Adam B
Any new updates on this. I would love to see new pictures if you have any available.
Thanks, Adam |
