Old 02-02-2010, 12:12 PM   #1
jerden
jerden's Avatar
72 blazer shock hoops
Who has shock hoops on their 67-72? I've look everywhere but I can't find anyone who makes them. Anyone make their own? I've seen the Ford towers but I was looking for a hoop setup for dual shocks. I asked over on ck5 awhile ago but got little response. Ridding with 52's and 56's and no shocks is interesting!
72' Blazer, 350, sm465, 205, 14bolt, 44 front with 4.10s , Diy4x4 FGB52's, Rear shackle flip with 56's, Skyjacker 4" lift springs, ORD 1" body lift, 35x12.50 Bfg's on H2's
jerden is offline   Reply With Quote
Old 02-02-2010, 05:45 PM   #2
onlyifihadachevy
Re: 72 blazer shock hoops
I think you will have to make them or have them made. But you could modify a ford dual shock setup to fit. I don't recall hearing or seeing someone that hasn't had them custom made.
72 gmc 2500 2wd drive convert
My 72 thread
http://67-72chevytrucks.com/vboard/s...d.php?t=346712
THe other truck, wheeler 69 1/2 4x4, yellow and rusty.
http://67-72chevytrucks.com/vboard/s...d.php?t=350300
onlyifihadachevy is offline   Reply With Quote
Old 02-02-2010, 05:55 PM   #3
6600DURAMAX
6600DURAMAX's Avatar
How about these
1972 K5 Build - plans - LS3-6L80e-One Tons.....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 02-02-2010, 08:47 PM   #4
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Does the 73-87 style not work on our frames? We have some on our monster that are 73-87 style with 3 shock mounts on them. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 02-03-2010, 01:16 PM   #5
jerden
jerden's Avatar
I had a set of those on my 87 and though about using them, but I' not sure they will clear the steering box on the divers side. Not to mention I don't think Rancho makes them anymore.
Old 02-04-2010, 11:08 AM   #6
jerden
jerden's Avatar
6600DURAMAX I've been watching your build, beautiful truck. I like the compact design of your shock towers. I'm wanting to run dual shocks up front so I'm thinking hoops that are tied together with a crossbar under the hood is the way to go. I don't mind making my own but it would be a lot easier with less trial and error if someone had done it before.
Old 02-04-2010, 02:34 PM   #7
71blksuper4x4
SWB 4x4 Collector
You could also get by with a factory dual shock setup off of the 73-87 style trucks, blazers, etc. It's just a special tab that holds 2 shocks in the stock position. Someone could maybe save those and sell them to you from the 73+ crowd. Trevor
TREVOR
Old 02-10-2010, 12:16 PM   #8
jerden
jerden's Avatar
With the 52" springs up front I want to get as long of shocks as possible. I'm leaning toward dual King remote reservoirs.
Old 02-10-2010, 06:56 PM   #9
vtblazer
vtblazer's Avatar
Built these for mine after the furd shock tower tore a huge chunk outta the frame rail.
First pic showing the rip-n-tear...
vtblazer is offline   Reply With Quote
Old 01-20-2012, 04:40 PM   #10
jstplyn331
jstplyn331's Avatar
Originally Posted by 6600DURAMAX View Post
How about these
What truck is this On? Do you have a Picture of the Drivers side? and were to get them or did you make them? Thanks in advance
And sorry about the bombing of questions I have been looking to do the same to my Blazer and I can't find anything I like, but I do like those ones...
Build Thread,
jstplyn331 is offline   Reply With Quote
Old 01-20-2012, 06:29 PM   #11
6600DURAMAX
Here are a couple of the driver side. I just made a cardboard template and had them burned on a table. At one time I had a set for sale but I have no idea where they went. I just added some small flat plate gussets I bought from DIY4X.
Looking at VTBlazer's pics is exactly what will happen if you do not reinforce the back of the frame if you wheel your truck, mine just sits in the garage so I did not reinforce the back of my frame. Ironically I did box my entire frame from the transfer case back and plate the inside at the large bend mid way back in the bed area but left this area up front alone . I got in a hurry to get it to powdercoat.
Old 01-20-2012, 07:45 PM   #12
jstplyn331
jstplyn331's Avatar
Man that is sweet, it is exactly what I am looking for, If you can find the other set you have I would be willing to take them off your hands...
And if not do you still have the Templete, or point me in the direction to the templete?
Did you just weld tabs to the top of the spring cover?
Build Thread,
Old 11-07-2017, 10:35 PM   #13
rustyburbin
I don't know how to post pictures here but here's the link to the build thread for my 70 K20 Suburban. I think page 4 and 9 have several pictures.
I'm going to build the front hoops after I put the body back on the frame to make sure they don't interfere with the steering column.
https://www.overlandbound.com/forums...suburban.5571/
1970 K20 suburban.
ZZ4 350 - 4l80e - 203 / 205 doubler.
Long travel Deavers with king shocks and bumps.
Detroit in back, Eaton E-locker up front with crossover & hysteer.
Plus 5 kids a wife and a dog!
rustyburbin is offline   Reply With Quote
