02-09-2010, 12:19 PM | #1 |
68 K20 Axles
What axles would be in my friend's 68 K20? We think that it has a Dana 60 in the rear, but we aren't sure what the front is. He also needs to know what the spline count is. Thank you.
02-09-2010, 11:23 PM | #2 |
Post Whore
Re: 68 K20 Axles
Should be a Dana 44 heavy duty front axle and either a Dana 60 or Eaton HO52 rear axle. I'm not sure of the spline count but someone will know. The front axle should be a closed knuckle axle which gives you a poor turning radius and drums. Either rear axle is strong.
Here's what the Eaton axle looks like
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
02-14-2010, 01:19 PM | #3 |
Re: 68 K20 Axles
that looks like my 69, I agree with Yukon Jack that is a eaton HO52 you are limited with that rear end it can only be a single rear wheel or update with a locker. Good news is that rear end is bullet proof.
West My Project and Photo Album http://67-72chevytrucks.com/vboard/s...d.php?t=378159 http://67-72chevytrucks.com/vboard/a...hp?albumid=641 |
02-14-2010, 06:47 PM | #4 |
Post Whore
Re: 68 K20 Axles
West, I'm not sure by what you mean you are limited with that rear. Mine has a factory No-Spin locker, which is a detroit locker, and a 14 bolt detroit locker can be used with, I believe, a change axle shafts.
02-14-2010, 10:06 PM | #5 |
Re: 68 K20 Axles
I had a HO52 and wanted a limited slip diff, I was told that I could do single wheel or a locker no in between. The in between for me was the LSP andthat is why I said you are limited in that you only had the two choices single wheel or full locker. I wish I had the locker but I was told that it is really not good for a truck driven mostly on the road as a daily driver. Best of luck with your friends build.
West My Project and Photo Album http://67-72chevytrucks.com/vboard/s...d.php?t=378159 http://67-72chevytrucks.com/vboard/a...hp?albumid=641 Last edited by west9378; 02-14-2010 at 10:07 PM. |
02-14-2010, 11:55 PM | #6 |
Post Whore
Re: 68 K20 Axles
I wouldn't be too worried about a locker in the rear, both my 69 and 70 have them and they get driven mostly on the road. The one in the 69 is pretty much unnoticeable but I must admit you know the 70 has it back there.
02-15-2010, 09:00 PM | #7 |
Re: 68 K20 Axles
spline count of the front or rear, inside axle shaft or outside (front)?
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
