Old 03-04-2010, 11:49 AM   #26
SCOTI
SCOTI's Avatar
Re: C4 Dropmember and Trailing Arm Conversion Install
Originally Posted by glock35ipsc View Post
Danny - I am planning on swapping my 85 to trailing arms also. I called a couple weeks ago, but don't remember who i talked to. I asked about buying just the 73 and up crossmember, but was told that only the 67-72 crossmember could be sold separately. True, or did I get bad info? I plan on fabbing my own crossmember, unless you guys would be willing to sell the 73 and up member as a separate item. Whatcha say?
Wild83C10 - Looks very nice! Could you post some info on the coil-over brackets on the rear end, link or part numbers please? Also, do you think a 67-72 crossmember could be modified to resolve the floor interference problems?
Prob could modify it like the guys that 'lay out'. They shave the portion of the stock c.member that extends beyond the frame rail on the bottom; this would require it to be done to the top.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-04-2010, 11:55 AM   #27
SCOTI
SCOTI's Avatar
I'm curious about one concern.... The 67-72's have the drive shaft loop extended higher (above the top plane of the frame rail) for clearance. The CPP 73-87 conversion piece has the c.member loop flipped & it's on the bottom. The top portion of the c.member does not extend beyond the frame rail.
I know on my 68 w/the stock TA c.member, the d.shaft was pretty close @ the top (~8" drop). My 74 has the top of the axle tube within 1" of the bottom plane of the frame rail so it looks to be several inches lower than Wild83C10's truck.
I'm wondering what kind of clearance there will be @ my ride height?
What ride height is the CPP 'kit' meant to be set at (2/4 drop; 4/6 drop, etc...)?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-04-2010, 01:05 PM   #28
68 TT
Still plays with trucks
68 TT's Avatar
Originally Posted by bluex View Post
Would a stock 67-72 crossmember not work?
With a long bed the 67-72 crossmember might work. The crossmember stops just in front of the bed. It might tuck into the raised section of the cab right behind the seat.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 03-04-2010, 04:14 PM   #29
bluex
bluex's Avatar
From CPP about the kit:
Kit is designed for 63-72 arms and will work with a stock set of arms.
The truck in that video uses their modular brake kit with a 2" drop spindle
They also used a 2" drop spring up front for 4" total.
Their rear arms have no drop built into them
and the truck has 3" 63-72 drop coils in the rear, or can use any other drop or stock spring for those years.
Scoti, Here is the info I got from them when I called about the kit they installed on their '79. I dont think it is as low as yours.
I think you will use a shorter drop spring than your current drop amount since the arms go under the axle? (I have shackle/hangers now for a 4", but I might have to use a 2" spring to get the same ride height?) That is the only way that having a 4" drop up front and a 3" out back sounds right to me..
bluex is offline   Reply With Quote
Old 03-04-2010, 04:25 PM   #30
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Nice looking install!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 03-04-2010, 05:23 PM   #31
DKN
Active Member
When we made the conversion kit we had a short bed truck. The rear axle will bottom out into the C-notch at the same time the bed floor will bottom out into the differential. The crossmember mounts up high against the floor of the cab. The dive shaft loop hangs down off the bottom of the crossmember but is still higher than the bottom of the frame rails under the cab. The frame is not straight; it is very low under the cab, then rises up to the bottom of the bed. The reason the crossmember doesn’t work on a long bed is because the new location for the crossmember will be much higher, and will need to mount on a level section of frame instead of the section of frame that is angled from under the cab to the bottom of the bed. The cross member is shaped like a Z rather than a C. If we make a crossmember for the long bed I expect that it will have a larger lower loop for the drive shaft. The loop will still be higher than the cab section of frame. I expect that all of the other parts of the kit will be the same, only the crossmember is a problem for the long bed trucks.
Danny Nix
CPP
DKN is offline   Reply With Quote
Old 03-04-2010, 05:46 PM   #32
SCOTI
SCOTI's Avatar
The c-notch & bed floor bottom out @ the same time on my 74. Your description of the frame is just like the 67-72's (low under the cab & kicks up as it transitions to the bed). I'm going to crawl under my 74 today for some dimension verifications & will try to compare your description of the c.member mounting location while under there.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-04-2010, 06:39 PM   #33
Wild83C10
Wild83C10's Avatar
Originally Posted by tomtuna1978 View Post
i like how you put the rear coil over outside the frame on that tube you put threw the frame ! what wall thickness is that tube ? and od ? thats what i wanted to do on my 4x4(shocks only) 79 c10.
The wall thickness looks like .120, the OD is 1-5/8.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 03-04-2010, 07:08 PM   #34
Wild83C10
Wild83C10's Avatar
Rear suspension P/N:
lower brackets: C2047 (Competition Engineering)
Upper brackets: TB103GBK (QA1)
Crossmember: 7387TAC-LDL (CPP)
Adj track bar: 6572DTBK (CPP)
Coilovers: DR3855B (QA1)
Springs: 7-450 (QA1)
Just about anything is possible as long as you have the skills and time to modify the x-member I'm sure you can get it to work. My opinion is that the CPP x-member was worth it.
turbo=
Old 03-04-2010, 07:26 PM   #35
SCOTI
SCOTI's Avatar
I would be by-passing the coils all together & moving directly to bags since I'm already using them in an air-over-leaf fashion (home-made) on my truck now.
Because my 74 has the HD rear set-up, that 8-leaf spring pack rides like a swb 3/4 ton on rough roads. I want them out of the way so I can run truck arms w/bags just like my 68 was set-up (ride quality was muuuuuuch better).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-04-2010, 07:44 PM   #36
Wild83C10
Wild83C10's Avatar
Heres a picture of a 67-72 chevy truck frame. The light blue line is the x-member location. The red lines are the 73-87 frame profile. Obviously the lines aren't exact but just to give you an idea of how the frames are different.
turbo=
Old 03-04-2010, 07:52 PM   #37
bluex
bluex's Avatar
That is exactly why I want to do it as well. With the heavy half package on mine it rides like crap unloaded. Now put about a ton in the bed and it rides like a caddy....
I took it for a ride sunday and hit a dip in the road and almost hit my head on the roof when the rear went over it. It was never very smooth riding unloaded as a long bed, but when I converted it to short bed it got waaayyy worse..
Old 03-04-2010, 09:22 PM   #38
SCOTI
SCOTI's Avatar
Yeah, we looked under the frame & I could see where the 'initial' kick-up is vs how the 67-72 frame is (I have a 68 swb frame sitting on my trailer). The CPP dropped center is still higher than the bottom lower plane of the frame rail.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-05-2010, 11:21 AM   #39
aggie91
I'm just glad to be here!
aggie91's Avatar
I also looked at a LWB mid 80's truck. There is a kick up in the frame rail about 1/2 way between the front cab mount and the rear cab mount. after that it is straight until just past the front spring hanger where it kicks up again to go over the rearend housing.
Does the SWB frame have the same kick up under the cab? I do not have one handy for a visual inspection...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-05-2010, 12:11 PM   #40
JW76
JW76's Avatar
yes it does and the crossmember goes in where the kick up is on the shortbed. that is part of the issue why it wont work on the longbed because the longbed calls for a crossmember to be located on the straight part of the frame which is higher than in the kickup
JW76 is offline   Reply With Quote
Old 03-05-2010, 12:14 PM   #41
JW76
JW76's Avatar
in addition, when the arms are located that high up on the longbed (the pivot point).... due to the shape of the frame, when you swing the arms they want to hit the frame so you don't have much suspension travel. HRH is building me a crossmember that solves this problem for my longbed and pefects the geometry.
Old 03-05-2010, 01:53 PM   #42
aggie91
aggie91's Avatar
I saw HRH install on a 3/4 ton on their site. I did not like how the crossmember was that much below the frame rail. But, it doesn't hang below the lowest part of the frame and is braced correctly, then it really does'nt matter...
I am lucky, mine is a '65 and I don't have to worry about it....I already have the trailing arms..
Karl
The LST Challenge:
Old 03-05-2010, 04:15 PM   #43
JW76
JW76's Avatar
I talked to the Steve at HRH and he said that one is that low because of the ride height the guy desired. The one for my truck will be a little less low but still lower than just sticking a stock 67-72 between the rails. As I said it has to do with the arm clearance and Steve says it has to do with the geometry
Old 01-18-2011, 12:38 AM   #44
aggie91
aggie91's Avatar
Any progress on this truck?
Karl
The LST Challenge:
Old 02-14-2011, 01:53 PM   #45
love my 72
love my 72's Avatar
Wow! great work! im loving that coil over set up! when i buy my C4 DM i want coil over set up! and that anti-sway bar is just awsome! i always wondered what the DM would use for an anti-sway bar!
Keep up the good work! but keep us posted too!!!
51 Chevy 3100 Deluxe Cab(SOLD)
65 **stang 6cyl
70 C10 Long Bed Fleetside(1st truck,thanks Dad![SOLD])
72 C10 Short Bed Fleetside
73 Blazer 2WD Catalina Blue White Top(Needs Love)
73 Blazer 2WD Work in progress LT1/4L60E
83 Grand National (SOLD)
94 Blazer K1500 Silverado (SOLD)
96 Impala SS All original (NEXT IN LINE 2 B SOLD)
99 Tahoe 2DR, 2WD
love my 72 is offline   Reply With Quote
Old 02-14-2011, 07:05 PM   #46
Wild83C10
Wild83C10's Avatar
I have all the suspension together and I drove it some this summer/fall. Doing some additional work this winter.
I'm bad with pictures, but I will post some up. Can't see much of the suspension work behind the turbo stuff though.
turbo=
Old 02-14-2011, 11:00 PM   #47
Wild83C10
Wild83C10's Avatar
Ok here's some completed for now suspension pictures. Next upgrades: larger front swaybar, rear sway bar, frame stiffening and then a roll cage.
turbo=
Old 02-15-2011, 12:35 AM   #48
SCOTI
SCOTI's Avatar
Man.... That's quite the package of parts you have pieced together. I imagine you have an ear to ear grin when you're behind the wheel.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-15-2011, 08:19 PM   #49
Wild83C10
Wild83C10's Avatar
Yes I do. I waited all this time for the suspension upgrades but the turbo seems to give me the biggest grin. I really haven't spent the time tuning the suspension yet though.
turbo=
Old 02-17-2011, 10:15 AM   #50
aggie91
aggie91's Avatar
that looks great! I bet that turbo motor is just to much fun.
How much travel does the rear suspension have? It looks like only a couple of inches of compression.
Karl
The LST Challenge:
