03-28-2010, 08:41 PM | #1 |
Active Member
Front Disc's Rubbing on Lower A-Arm
I installed CPP modular drop spindles on my '64 C10 and have run into a problem. The disc's I bought are the standard 11" or 12" 6-lug also from CPP. The problem I am having is the very end of the a-arm rubs on the disc. At first I thought maybe I hadn't seated the lower ball joint all the way, but I had and it's torqued to specs. Another thought is that the spindles were not machined correctly by CPP. Anyone else had this issue? I appreciate any insight you may have or ideas on how to fix.
03-28-2010, 08:57 PM | #2 |
Active Member
Re: Front Disc's Rubbing on Lower A-Arm
Now that I think about it a little, when I put the disc's on the spindles, I thought it was strange that the castle nut went on the spindle beyond the hole for the cotter pin. I had to add a second spindle washer to space the castle nut out on the spindle so the cotter pin would keep it from spinning. I think the spindles were not machined properly.
03-28-2010, 10:39 PM | #3 |
67-72 parts collector,…
You might PM member CPPJEFF.
I never knew how CPP narrowed the track width,... without running into this problem. I know their "modular" spindles are only a 2" drop compared to the standard 2.5" or 3" drop. Are you sure you have the correct bearings?
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 03-28-2010 at 11:15 PM. |
03-28-2010, 10:59 PM | #4 |
Active Member
lolife99,
The rotors came with the inner and outer races installed. The bearings fit the spindle fine, I guess it's possible that the races do not match my A3 and A5 bearings, but they looked fine when dry fitted. Maybe the rotors are out of spec. I sent Jeff a message, we'll see what he suggests. Thanks for the feedback. |
03-28-2010, 11:16 PM | #5 |
I'll be following this thread also.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 03-28-2010 at 11:17 PM. |
03-28-2010, 11:48 PM | #6 |
Didn't spray bomb have this problem with his spindles
nickle and dime |
03-29-2010, 10:26 AM | #7 |
I have NEVER seen this problem. Can you put the whhels on the vehicle instead of jackstands and let me see what it looks like then? I will send this thread over to my engineer. Thanks
03-29-2010, 11:40 AM | #8 |
The area marked in red,... looks wider than the 67-72 or 73-87 lower arms.
I wonder if the early arms are different?
03-29-2010, 12:01 PM | #9 |
03-29-2010, 12:12 PM | #10 |
Does this do this on both sides?
03-29-2010, 01:12 PM | #11 |
Active Member
Jeff,
Yes, this is happening on both sides. I'll get some shots with the wheels on the ground in the garage and post them tonight. Would this have something to do with the rotor going on the spindle so far that the cotter pin hole does not engage the crown nut? Should there be a spacer between the spindle and the inner bearing to hold the rotor out a bit? I appreciate the help in getting this resolved. If you need me to measure anything, I can do that. Steve B. 563-320-1993 |
03-29-2010, 01:32 PM | #12 | |
03-29-2010, 09:21 PM | #13 |
Active Member
Jeff - I sent you an e-mail with these pics. Thanks for your help with solving this issue.
For those interested in this thread, here you go. |
03-31-2010, 12:31 PM | #14 |
Active Member
Decided I'm just going to grind off the ends of my a-arms to prevent them from grinding on the rotors. Don't want to take too much though and risk weakening the ball joint area of the stamping.
03-31-2010, 01:29 PM | #15 |
05-19-2010, 06:31 PM | #16 |
Anymore on this?
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
05-26-2010, 07:48 PM | #17 |
I would like to know what the problem was. I want to get these for my truck. I wonder if he got the wrong bearing or rotors
Rick 71 C10 long fleet sold 72 C10 short fleet 72 Olds cutlass 85 442 87 442 |
05-26-2010, 08:26 PM | #18 |
Redefining LowBudget
Hmmm I seem to have read this somewhere before but it is and older post.....I thnk they just ground it till it cleared??
what about thethickness of the rotor?? seems like they came in 2 diff thickenss's Last edited by Hottrucks; 05-26-2010 at 08:27 PM. |
05-28-2010, 01:45 PM | #19 |
Active Member
The rotors came from CPP. The bearings are the correct ones for the application, very common bearings.
I ended up just grinding the ends of my lower A-arms enough so that they no longer rub. I actually had to take quite a bit off, I'm hoping they are still mechanically sound and safe. In my opinion, I should have forced the issue more with CPP. I think the CPP drop spindles were not machined correctly. This allowed the rotors to install to far inboard on the spindles. The reason I believe this is that after I installed the rotors, the crown nut tightens up way beyond the hole in the spindle that the cotter pin goes into. I had to install extra spindle washers between the outer bearings and the spindle nut to hold it our far enough so that the cotter pin will keep the crown nut from loosening. I have to say, I'm not really happy with this setup, I just did not want to incur more shipping charges and down time sending the spindles back to CPP for inspection and replacement. |
11-22-2014, 04:08 AM | #20 |
But Found Her 25yrs Later!
Old thread.....
But still interesting information on modular spindles.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
11-26-2014, 12:37 AM | #21 |
Did anyone notice theres no dust plates either? The spindles must be wrong if the rotor runs so far back that the castle nut completly clears the cotter pin hole
1967custom |
11-26-2014, 03:19 AM | #22 |
I read on here that you can't run the dust shields with the modular spindles.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
11-27-2014, 10:36 PM | #23 |
Youre probably right. I ran magoughys and those had the holes to mount dust plates so i just assumed
1967custom |
11-28-2014, 10:41 PM | #24 |
Here is a recent pic from a thread by Chevy_Mike showing modular spindle with 15" rally wheels. Looks like the ball joint is taller or something. No interference between a-arm & disk.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
11-28-2014, 10:52 PM | #25 | |
The distance from the arm to the bottom of the spindle looks to be quite a bit more on Chevy_Mikes'. The pics above, where the poster says he's having clearance issues, looks to only be about 1/2".
