04-18-2010, 01:36 PM | #1 |
Rear end ID help please 67 C10 Stamped #'s?
It's a GM 12 bolt with the following info
NF 3896838 GM 60 THA W 0832 2 If anyone can point me in the right direction or let me know....I have been looking on internet for 4 days and still can't find out exactly where it came from. It's on a 67 C10 but I'm not sure if it's the original. Car or truck? Any help would be greatly appreciated. |
04-19-2010, 09:29 AM | #2 |
Re: Rear end ID help please 67 C10 Stamped #'s?
I believe I have the codes at home and will send you something tonight. The info looks complete.
Dan |
04-19-2010, 09:41 AM | #3 |
Thanks alot, I really would appreciate it.
04-19-2010, 09:57 AM | #4 |
i had same question a couple weeks ago. what someone pointed out is numbers might tell you what came from factory, but not always whats in there now. i took cover off and found gear ratio stamped on ring gear and a posi set up. if you do find codes i also would be interested to see if mine was ordered or changed at some point.
04-19-2010, 10:00 AM | #5 |
I pulled the cover and counted teeth awhile back, i believe I got 3.08, or was it 3.07?? Man I can't remember, my memory is shot!
04-19-2010, 05:36 PM | #6 |
My book claims it is a 1971 3.07 non-posi.
Is it a 5-lug diff? Dan |
04-19-2010, 06:00 PM | #7 |
Yeah, it's a 5 lug. I thought 3.07 were car rear ends?
04-19-2010, 06:02 PM | #8 |
3.07 was a very common gear for pickups. Good Luck!
04-19-2010, 06:25 PM | #9 |
Moderator
3.07 is truck.....3.08 is car
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
04-19-2010, 08:08 PM | #10 |
could you id mine? NF3896839 GM 53
04-19-2010, 08:47 PM | #11 |
Those #s won't give you to much info, say your looking at your rear axle with your back under the trans. Go about 6 inches to the left of the pumpkin at about the 2 O'clock position and start scrubbing. I used sand paper and clean paper towels. It literally has to be SHINEY clean to see it. It's stamped with a die not cast.
04-19-2010, 08:52 PM | #12 |
That's a good description of the location. Here is a graphic of it (disregard the casting number info).
04-19-2010, 08:53 PM | #13 |
will try to find the stamped numbers. thanks
06-29-2015, 09:02 PM | #14 |
Rear end ID help please Stamped #'s?
Wow Dan ;
That's a great diagram . Any chance of a link to decode the numbers ? . When I worked in GM Dealers, we had scads of books to decode anything .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
06-29-2015, 10:26 PM | #15 | |
The Older Generation
Re: Rear end ID help please Stamped #'s?
This may not cover everything but it covers most of them.... http://67-72chevytrucks.com/vboard/s...d.php?t=578793 LockDoc
01-13-2022, 04:33 PM | #16 |
can anyone help identify mine?
I do realize this is a very old thread, but figured it was worth a shot. 67890 - GM 12 bolt E120 - May 12, 1970 NF3896838 Axle Stamp = TDA 0521W1 so I think the TDA means its a 3.73 gear and i think the 052 is the 52 day of the year it was built? and i have no clue what the 1W1 means? any ideas? Thanks, |
Tags |
67 c10 rear end id |
