Old 08-11-2010, 11:05 PM   #1
stefan
New Member
trimming lower control arms
Hey guys im sure this has been asked a thousand times,so ill ask once more,i need to trim my lower control arms but i need to know where and how much is safe,i really appreciate any help.
stefan is offline   Reply With Quote
Old 08-11-2010, 11:14 PM   #2
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Re: trimming lower control arms
In my experience, I will never do it again. I trimmed the front lower control arms so I could run Centerline 15" wheels... after say 2 months control arm failed on the freeway and I went from the far right lane, 3 lanes over into the conrete wall... wasnt hurt that bad... somehow I missed everyone, Someone was watching over me that day I tell ya. Just fatigued due to trimming too much off the "rain gutter". I would rather buy a spacer of some sort, or just get bigger wheels.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 08-11-2010, 11:23 PM   #3
SCOTI
SCOTI's Avatar
clint
How did you 'trim' the a-arm?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-12-2010, 06:57 PM   #4
87chevy.com
think we used a grinder... I think the problem was they were 3" drop spindles on aluminum wheels and it required to chop a lot of the gutter material... that gutter material is what gives the ball joint area its strength... thats where it failed... essentially bent the metal back and fourth untill it let go.
clint
Old 08-12-2010, 09:05 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
I've trimmed every 67-87 lower control arm on every truck I have lowered.
(My trucks and others)
Never had a failure of any kind.
I've done this mod since the 1980's.
Keith
Convert to disc brakes.
Old 08-12-2010, 09:12 PM   #6
lolife99
lolife99's Avatar
The area with the blue masking tape has already been trimmed.
The last picture is a stock "un-trimmed" lower a-arm, with the area "to be trimmed",... marked in red.
Keith
Old 08-12-2010, 09:42 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
I have trimmed several sets with no issue, but I have also heard of them cracking. My solution was to trim as needed then add a boxing plate on the bottom. After that I came up with the best solution in my opinion. I no longer wheels small enough to require the arms to be trimmed...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-12-2010, 10:38 PM   #8
mooseknuckles
mooseknuckles's Avatar
I had no choice but to trim mine they were rubbing into the bead on my tire, the first time I drove it thy peeled off my wheel weights!
mooseknuckles is offline   Reply With Quote
Old 08-12-2010, 11:53 PM   #9
54Caddy
GM Addicted
54Caddy's Avatar
??the picture with the red markings is the area that can be trimmed off correct??
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 08-13-2010, 01:27 AM   #10
SCOTI
SCOTI's Avatar
Too much backspacing will still cause rubbing even w/large diameter wheels. Like Lolife99, I've done it numerous times on different year models. I drill a hole where I want the lip to start/stop. Then w/a cut off wheel, I trim the offending material away.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-13-2010, 10:54 AM   #11
Lee H
Lee H's Avatar
I also trimmed that area on my son's truck a few years ago. At each oil change we rotate the wheels, and check the area for signs of failure. So far so good.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 08-13-2010, 01:38 PM   #12
lolife99
lolife99's Avatar
Correct.
You still have to check for clearance issues.
Set the truck on the ground after trimming, and turn the wheels in both directions to verify that no part of the a-arm will make contact with the wheel.
Keith
Old 08-13-2010, 05:25 PM   #13
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Here's what you'll end up with...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 08-13-2010, 08:34 PM   #14
54Caddy
GM Addicted
54Caddy's Avatar
i was going to completly cut off the bump stop and the metal, would that be a bad idea. Basically cut off the rest of what is showing on the picture above. Going with bags.
..Mac’s Garage..
IG:MacsGarage
Old 08-13-2010, 09:03 PM   #15
lolife99
lolife99's Avatar
The only part I leave is the "steering stop" for the spindle.
Some people remove all of it.
Keith
Old 08-13-2010, 09:05 PM   #16
stevencvn72
Kill Bill...et
stevencvn72's Avatar
Not to jack this thread, but did any of you have trouble with the LCA clearing the disk break dust shield? And yeah...I was also wondering about the question above with the steering stop.
-Steve
I Grease
'67 Chev stepper
http://youtu.be/38p_2Iu2fd0
stevencvn72 is offline   Reply With Quote
Old 08-13-2010, 10:26 PM   #17
SCOTI
SCOTI's Avatar
Some do clear, some don't. It's easy enough to tweak or trim the 'shield' for clearance if it interferes.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-13-2010, 10:56 PM   #18
63chevyll
gets board easy.......
63chevyll's Avatar
u normaly grind the stop off also, i like the travel
63chevyll is offline   Reply With Quote
Old 08-13-2010, 11:01 PM   #19
SCOTI
SCOTI's Avatar
Grinding the stop off only increases the problem if the wheels rub. Once the stop is gone, you have to remove more material because the steering arc will slightly increase (close to, or in bind).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-14-2010, 09:50 PM   #20
63chevyll
63chevyll's Avatar
see my avatar pic, it was on my race truck, travel was needed
Old 08-14-2010, 11:22 PM   #21
Mike J
vw guy & now c-10 guy
Mike J's Avatar
I cut the stops off completely on mine, but even with the 5.5" lowering and 15x7 steel wheels, I didnt have to take off any of the lip- I guess it really depends on the backspace of the wheel...
'68 long fleet
Finally made some progress on the build!!!
My Build Thread
Mike J is offline   Reply With Quote
Old 08-14-2010, 11:55 PM   #22
lolife99
lolife99's Avatar
Yep.
Usually a 15" wheel with more that 3.75" of backspacing,... will require a trim.
Keith
Old 08-15-2010, 02:31 AM   #23
SCOTI
SCOTI's Avatar
Read my statement again.....
If it's not a problem already.... good. But, it could become one so be on notice.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-15-2010, 10:47 AM   #24
54Caddy
GM Addicted
54Caddy's Avatar
well i looked at my truck and with the wheels fully turned nothing hits the stop, so im thinking just taking it all off.
..Mac’s Garage..
IG:MacsGarage
Old 09-07-2012, 08:27 AM   #25
ZUBZ
ZUBZ's Avatar
Very nice thread guys, thanks for the info and pictures.
ZUBZ is offline   Reply With Quote
