09-03-2010, 01:59 AM | #1 |
bypass VATS with out key 96 vette LT4
I would like to start my donor 96 vette LT4 before I pull the engine out and swap it into my 69 pick up. I don't have the ign. key. I looked at the shbox site and all I found was how to bypass VATS with a resistor you need the key to do this. There must be an easy away to do this. Can any one help. Thanks
09-03-2010, 09:28 AM | #2 |
Gearhead
Re: bypass VATS with out key 96 vette LT4
I only know of the resistor mod or having the VATS programmed out of the PCM, I dont think there is an easy way, the point was to make it harder to steal the car. You could just have the VATS removed from the PCM, you're going to have to have it done for the truck anyway....
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 Last edited by 6772owner; 09-03-2010 at 09:28 AM. Reason: text |
09-03-2010, 09:48 AM | #3 |
The Older Generation
No easy way to do this unless the key code is on a sticker in the glove box. Some are.
LockDoc
09-03-2010, 12:10 PM | #4 |
Weren't there only 7 or so different resistors used? You could buy each one and try them until it works.
...wait a minute, we are not helping you steal a donor car, are we? Ha
1969 C10 SWB Project Charity Case AKA "Roscoe" 1971 Cheyenne Super A Combined Effort The Service Station-A practical ministry for those in need |
09-03-2010, 12:22 PM | #5 |
*** That's interesting ***
The VATS system is nice to keep once you figure out the correct resistor value. Later you can put a switch in to cut in/out that resistor as a security device. Nice thing about having that switch is that once the car is running, you can bump it and it won't shut the vehicle off (unlike a conventional kill switch). It only reads the resistor at start up once.
Also, any 1994-1996 Chevy Caprice 9C1 (police package L99 or LT1) car with have a VATS system that is in "dummy" mode. Meaning it will send the correct signal to the PCM without needing a resistor. It was cheaper for GM to do that (include the VATS reader on the car but never program it on the 9C1 cars which do not use the special key). Civilian cars did come with the resistor key, so it must be a 9C1 (RPO code). What this means is that you can use a VATS module from a 9C1 Caprice and it shouldn't need the resistor. When VATS is working (LT1/LT4), the engine will start for a few moments, then die. So you may be able to test your LT4, at least for a moment. Otherwise you will need to figure out the correct resistor value in ohms. Here is a table. Note that you can come up with these values by using a potentiometer or resistors in parallel or series to get the right value. KEY ID -- OHMS 1———— 0.402 2———— 0.523 3———— 0.681 4————-0.887 5————-1.130 6————-1.470 7————-1.870 8————-2.370 9————-3.010 10————3.740 11————4.750 12————6.040 13————7.500 14————9.530 15————11.801
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... Last edited by storm9c1; 09-03-2010 at 12:24 PM. |
09-03-2010, 12:35 PM | #6 |
Rottenwood Garage Member
Everything tom said is accurate - just note that the resitor values are in kilo-ohms:
1 -.402 is really 402 ohms 2 - .523 is 503 ohms etc... Also - using an incorrect value locks the vats system out for 10 minutes or so... potentially you could spend a couple of hours finding the right one. I worked in a 12V install shop in the 90's installing stereos and remote starts - I can confirm that this is how the delay works. another interesting option: http://www.fieroaddiction.com/passkey.html Todd |
09-03-2010, 05:20 PM | #7 | |
Oh, and if you are good with electronics, you can make your own dummy module with over the counter parts. http://home.hiwaay.net/~davida1/passkey.htm
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... Last edited by storm9c1; 09-03-2010 at 05:20 PM. |
09-03-2010, 06:19 PM | #8 | |||
F & B bodys The fuel enable circuit is an output from the theft deterrent module assembly and an input to the ECM. When the theft deterrent module assembly sees the proper resistance at the ignition key assembly, it will output a pulse width modulated (PWM) signal to the ECM. If the theft deterrent module assembly does not see the proper resistance at the ignition key assembly, it will not output the PWM signal to the ECM. Corvette Y body FUEL ENABLE DATA STREAM (FEDS) The FEDS system operates in conjunction with the UTD and PASS-Key(R) systems. The FEDS system uses a password exchange system between the PCM and CCM after a correct PASS-Key(R) has been sampled to enable fuel delivery to the engine. The password exchange uses the Serial Data Link (SDL) between the PCM and CCM. The PCM generated a password, scrambles it, and sends it to the CCM over the SDL. The CCM unscrambles the password and selects an appropriate response password. The CCM then scrambles the response password and sends it over SDL to the PCM. The PCM unscrambles the response password and compares it to the correct response it expects for the password it originally sent. If the response from the CCM was correct, fuel delivery is enables, and a message noting that FEDS has been successfully completed is sent to the CCM. Quote:
09-03-2010, 08:39 PM | #9 |
sharp as a marble
I have a customer with an 85 Vette. there is no chip in the key? He says, do not leave the key in the switch or the car will not start for more than an hour. With the lateer model GM stuff, we will see security probs, and put a battery charger on them, leave the key on for an hour or so. the security system gives up and the cars will start. NOT SURE, but if you have access to a tech2, and you can go to the right page you might be able to turn off the RPO code for security??
Current Performance is a company in Hudson Fl, Jason is the owner. Might give him a call and see if he can reflash the PCM to bypass the security. He is a good guy Last edited by cparman; 09-03-2010 at 08:41 PM. |
09-04-2010, 01:54 AM | #10 |
Thanks for all your comments I just finished putting together 15 different resistor combs to the corvette's key ID list I got them very close I heard you have to be with in 5% and I am so I will try it tomorrow before I pull it. I hope this will work.
