Old 09-05-2010, 11:33 PM   #1
67C10BUB
67C10BUB's Avatar
What is this on 2008 5.3L?
Can anyone tell me what this tube is for? It is on the passenger side head.
67C10BUB is offline   Reply With Quote
Old 09-06-2010, 04:58 AM   #2
tk-mpl
tk-mpl's Avatar
Re: What is this on 2008 5.3L?
I think it is the PCV. I just routed mine into the air intake tube. I know it goes into the intake on the stock truck.
1968 short box stepside.
2007 5.3L 4L60, tuned w/EFI Live
2005 Silverado bucket seats.
Dominator 2600's all around.
Porterbuilt tubular control arms.
Magnaflow 3" dual exhaust.
tk-mpl is offline   Reply With Quote
Old 09-06-2010, 01:00 PM   #3
67C10BUB
67C10BUB's Avatar
Did you use the stock intake duct? If not, how did you hook it up?
Old 09-06-2010, 05:43 PM   #4
LEEVON
LEEVON's Avatar
I know it's routed into the intake because I had to relocate it when I put a different intake on.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 09-06-2010, 08:34 PM   #5
TR65
TR65's Avatar
LEEVON
That hose supplies filtered and measured air to the crankcase. It is sucked out on the other side of the engine and into the intake by the intake vacuum thru an orifice tube. That makes up the PCV system.
Since the tube takes in air after the MAF the total air intake into the cylinders is all accounted for.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 09-06-2010, 08:57 PM   #6
TR65
TR65's Avatar
On second look that tube seems to be after the throttle body in which case I guess it would be the air from the crankcase to the intake.
I have an 2005 and a 2008 that work like I said in the first post.
There should be one tube to the intake from usually the drivers side head for crankcase ventilation.
There should be one tube feeding measured and filtered air to usually the passenger side head to supply the crankcase.
There is the vapor return line from the tank to the intake
There is the vacuum line from the intake to the brake booster.
That should be it.
TR
1965 C10 SWB Fleet
Two owner
Old 09-06-2010, 10:42 PM   #7
67C10BUB
67C10BUB's Avatar
Thanks for the help everyone. I guess I'll have to figure out a way to plumb it into my intake.
Old 09-07-2010, 10:58 AM   #8
Shon
I take it off and put a breather on the VC and cap off the intake.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 09-08-2010, 01:06 AM   #9
tk-mpl
tk-mpl's Avatar
I just heated the end of that plastic pipe alittle and pulled the end off. The I just put a 3/8 barp in the intake tube..
Old 09-08-2010, 05:38 AM   #10
67C10BUB
67C10BUB's Avatar
Good idea. I'll have to see if I can find a thread-through barb fitting. Any idea where you got yours?
Old 09-08-2010, 07:35 AM   #11
Shon
not such a good idea. where is the oil going??? cap it off and put breather on VC.
Old 09-08-2010, 09:59 AM   #12
tk-mpl
tk-mpl's Avatar
You can get a fitting at any parts store....
Shon, there shouldn't be any oil there and that is exactly where it goes in the factory intake.
Old 09-08-2010, 10:04 AM   #13
Shon
Let it run like that or the factory way and pull intake after a little while and let me know what you find.
Old 09-08-2010, 09:33 PM   #14
TR65
TR65's Avatar
Guys,
That tube supplies air to the crankcase. It is sucked out of the other head into the intake mainfold by vacuum.
If you are building up enough crankcase pressure to push oil up that tube it seems like something must be wrong.
I have seen people even put oil separators on that line but I don't get it. Is that something that happens with continuous high revving??
TR
1965 C10 SWB Fleet
Two owner
Old 09-08-2010, 10:52 PM   #15
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
the efi throttle bodys do have a tendency to get very dirty/carboned up....and some say that its due to sucking up oil....and that those catch cans help. Generally hard use situations tho I think...
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 09-09-2010, 01:24 AM   #16
Ackattack
Ackattack's Avatar
I put some cast aluminum valve covers on my engine, so that eliminated the PCV location that is on the stock valve covers. Initially I tried running just 2 breathers (one on each valve cover) but I was getting oil dripping out of one of the breathers, so I put a regular PCV valve in the pass. head and routed it to the intake and no more dripping oil.
Ackattack is offline   Reply With Quote
Old 09-09-2010, 07:45 AM   #17
Shon
but that oil is going somewhere....
Old 09-09-2010, 10:25 AM   #18
68GMCCustom
I plan on adding a catch can to mine
Kurt -
Old 09-10-2010, 08:55 PM   #19
TR65
TR65's Avatar
Well,
I talked to a real mechanic today and he said that at high RPM wide open throttle with a worn engine the blow by pressure can get high enough to reverse the flow and drive oil up inlet tube. So I guess that is the deal.
TR
1965 C10 SWB Fleet
Two owner
Old 09-10-2010, 09:11 PM   #20
tk-mpl
tk-mpl's Avatar
Beter tell the GM engineers that..
Old 09-10-2010, 09:16 PM   #21
Shon
it happens from day one on most of them....
Old 09-10-2010, 09:25 PM   #22
68GMCCustom
this is not a "worn motor" issue. I've had a new '01 LQ4 and have a new '06 LS2 that both do it.
Kurt -
