Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > Review Board > Product Reviews
Old 02-18-2011, 10:02 PM   #1
todd99
Thumbs down Airbagit Drop Spindles
I have spent all day trying to install the 3" drop spindles I ordered from airbagit. They are still not fully installed. I had to do A LOT of grinding to make the brakes fit. I would recommend buying from someone else.
1971 C20 Longhorn Custom Camper
todd99 is offline   Reply With Quote
Old 02-18-2011, 10:05 PM   #2
BHBurban
BHBurban's Avatar
Re: Airbagit Drop Spindles
Junk. everything they sell is junk.
"94 Suburban '89 Dually '00 Tahoe 88 shortbox
BHBurban is offline   Reply With Quote
Old 02-18-2011, 10:07 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Got any pics of the problem areas?
Did the balljoints and outer tie rods fit?
Keith
Convert to disc brakes.
Old 02-18-2011, 10:17 PM   #4
todd99
No, I don't have any pics. The ball joints, tie rods, and disk fit fine. The shoes on both sides required a lot of material to be removed. The weird part was that the left and right spindles had problems in completely different places. They actually made two completely different designs for the left and right.
Old 02-18-2011, 10:42 PM   #5
lolife99
lolife99's Avatar
shoes???
Keith
Old 02-18-2011, 10:43 PM   #6
dave2953
Dave's not here, man
dave2953's Avatar
My thoughts exactly...pads maybe? Could it be that the pads you had were for the 1" rotors instead of the 1 1/4"? Just a WAG...
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 02-18-2011, 10:51 PM   #7
todd99
Sorry I meant to say calipers
Old 02-18-2011, 11:03 PM   #8
71swb4x4
71swb4x4's Avatar
Unfortunately this is one of those "you get what you pay for" things. Those guys sell cheap junk, and you learned the hard way. I do commend you for posting it on the board. Hopefully others will read this before they buy them.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 02-18-2011, 11:08 PM   #9
lolife99
lolife99's Avatar
Just curious,... how much the spindles cost?
The other problem with AirBagit.com is they normally have a restocking charge on anything you want to send back,... no matter who screwed up the order or quality of the part.
AirBagit.com is also the same company as Aim or ChassisTech.
(these are the previous names of this company)
Keith
Old 02-18-2011, 11:14 PM   #10
todd99
http://www.airbagit.com/Chevrolet-Lo...les-s/1771.htm
$289 - 1971 C20
Old 02-18-2011, 11:24 PM   #11
chevy2tom
chevy2tom's Avatar
Todd, I had the same problem with my 71 3/4 ton, what I found was that I had the wrong calipers&rotors on my truck from the po. I went to the local parts store & ordered rotors&calipers for a 71/72 & that took care of it.
chevy2tom is offline   Reply With Quote
Old 02-18-2011, 11:57 PM   #12
todd99
My brakes are definitely the originals. I would guess they used a truck with the wrong calipers when they designed their spindles. I would rather just file some metal off than go through the hassle of buying and installing new calipers. Thanks anyways.
Old 02-19-2011, 12:00 AM   #13
todd99
Did you have any alignment issues after installation? I've heard that anything more than a two inch drop on a 3/4 ton will be un-alignable.
Old 02-19-2011, 12:13 AM   #14
leddzepp
Moderator
leddzepp's Avatar
Dropped spindles will not adversely affect your alignment....drop springs will.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 02-19-2011, 12:40 AM   #15
tcb-1
Nothing to see here.....
tcb-1's Avatar
airbagit sucks. period.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 02-19-2011, 12:49 AM   #16
chevy2tom
chevy2tom's Avatar
No problems with having my front end alignment done. I have the stock front springs & shocks. I also bought & installed 5" drop coil springs from GMC Pauls.
Old 02-19-2011, 01:49 AM   #17
72rustbucket
72rustbucket's Avatar
I installed mine my like 3 years ago and had no problems w/calipers. But i dont know if you noticed they have two types of spindles clip on or bolt on for caliper. This might be your problem.
72rustbucket is offline   Reply With Quote
Old 02-19-2011, 03:26 AM   #18
leddzepp
Moderator
leddzepp's Avatar
Moving to Suspension Forum...
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 02-19-2011, 10:26 AM   #19
todd99
I bought the right spindles, bolt on. Maybe I just got a bad casting.
Old 02-19-2011, 12:50 PM   #20
BHBurban
BHBurban's Avatar
If one casting is bad, they are all bad.
Old 02-19-2011, 02:15 PM   #21
lolife99
lolife99's Avatar
When I originally read this thread,... I didn't realize they were C20 drop spindles.
(I assume they are?)
There are not many choices for the c20 trucks.
I do know that Performance Online sells them,... but they are a little more money.
(I assume,... due to lack of demand,... the supply and demand issue negates the price)
Sounds like they would've been worth the money, in this case.
Keith
Old 02-20-2011, 12:22 AM   #22
leftcoast66
leftcoast66's Avatar
Sorry to hear you got taken by them. I'm glad to hear yours are somewhat close to fitting. I ordered a set for my 66 when I first got it. I got a set of disc spindles that didn't fit any c10 discs or balljoints in 6 or 5 lug and they wanted us to pay the 30% restock fee even though they were advertised as working with factory drum brakes when I ordered. I hope you're able to get them to fit and good luck with the truck.
leftcoast66 is offline   Reply With Quote
Old 02-20-2011, 10:13 AM   #23
todd99
Thanks, I managed to install them. After seeing how much better my truck looks it was worth the frustration.
