03-22-2011, 05:09 AM | #1 |
C10 Club Tennessee
How safe is raising the ball joint?
I just bought a 72 burb that someone did this too. It has been changed over to a 73 and up control arm. I've obviously seen it done, but was wondering how stable it is.
I also plan on getting drop spindles and it has 2 inch coils on it now. Posted via Mobile Device
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
03-22-2011, 10:21 AM | #2 |
It'd be alot cooler if you did
Re: How safe is raising the ball joint?
I'm not sure about the actual stepped control arms, but I would think you might have issues with your scrub line if you combine the stepped control arms with dropped spindles. I would think that it would bump steer with the stepped control arms though.
03-22-2011, 10:32 AM | #3 |
C10 Club Tennessee
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 Last edited by 5150; 03-22-2011 at 10:43 AM. |
03-22-2011, 10:40 AM | #4 |
pic doesn't work...
03-22-2011, 10:44 AM | #5 |
C10 Club Tennessee
Can you see in now?
03-22-2011, 04:17 PM | #6 |
I can see it,, doesn't look too safe to me!!!
what is the purpose of raising the ball joint? |
03-22-2011, 04:21 PM | #7 |
x2 shakeeee
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
03-22-2011, 05:07 PM | #8 |
The purpose is to lower the stance of the truck. Poor mans lowering kit. I'd either buy new arms or at a bare minimum, take it off, clean it up and box the hell out of it!!
'59 Apache - 383" SBC/TH-350 '68 GMC - BBC/TH400 Last edited by nikwho; 03-22-2011 at 05:09 PM. |
03-22-2011, 05:38 PM | #9 |
There is a shop nearby that offers these, I never liked the looks of them and it's only about $50 more for drop spindles.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
03-22-2011, 07:16 PM | #10 | |
IMHO, it is not triangulated enough to have the strength required to support the weight of a small car, much less a nose-heavy truck....and when it fails, it will be catastrophic.
But, of course someone will say that it's been like that for years
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. Last edited by LONGHAIR; 03-23-2011 at 06:57 PM. |
03-22-2011, 07:32 PM | #11 |
Garage wrench
I agree. In this case the risk far, FAR outweighs the reward. Get some stockers on there a.s.a.p. Just my .02
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... Last edited by SBTork; 03-22-2011 at 07:34 PM. |
03-22-2011, 08:32 PM | #12 |
I wouldn't run it. Not when there are much safer options out there.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
03-22-2011, 09:42 PM | #13 |
vw guy & now c-10 guy
looks scary to me
03-22-2011, 09:50 PM | #14 |
67-72 parts collector,…
Bryan,... I would throw those away.
To me,... a stepped a-arm is no different that a "drop pocket" designed tubular a-arm,... like DJM sells. They work fine with a mild drop spring,... but when combined with a drop spindle,... the lower edge of the a-arm is too close to the ground. Run some stock a-arms, drop springs and a set of drop spindles,... and you will be fine.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 03-22-2011 at 09:51 PM. |
03-22-2011, 11:30 PM | #15 |
C10 Club Tennessee
thanks guys, that's what I was leaning towards. Just don't like the look of it. csbatey has an extra set of lower arms he said I could have.
03-23-2011, 01:28 AM | #16 |
Square
I dont get how that even fit in there. isn't it flaired?
Squarebody Syndicate |
03-23-2011, 02:31 AM | #17 |
VA72C10
Glad to hear you're changing them out. Knowing this will be a family hauler I'd be worried with the way that one was put together.
Looking for a 67-72 swb or blazer project in or around VA. |
04-01-2011, 02:31 AM | #18 |
Glad to hear your getting rid of those, didnt want to see anyone hurt or killed. The PO must have thought that was a good safe method. but that would scare the hell outta me. and I dont care who fabbed them up, i see all kinds of places for the cracking of metal/and or welds to start from.
its amazing the things some people will do and think its safe. but then again some people need to get out the gene pool, they keep muckin up the water. |
06-10-2011, 11:24 PM | #19 |
.Charlies Drop Shop In Portland build a Far better step control arm. its a 2 Inch step which stays above the scrub line and his are Boxed in really well. Classic trucks has done a few write ups about his control arms.
I would agree in drop spindle being better and easier, But thats Only if your upgrading to disk brakes. If your still using your drums the step has been a nice way to go . Again thats ONLY if you dont go over 2 inches,and its boxed in really well
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
