Old 04-23-2011, 06:07 PM   #1
72c10lover16
72c10lover16's Avatar
does anyone offer an overdrive gear set for saginaw 4 speed with granny gear
i was just wondering if there is a company that offers a rebuild kit for the saginaw 4 speed that would give you an overdrive 4th
68 swb 4x4 327 4 speed
72c10lover16 is offline   Reply With Quote
Old 04-23-2011, 07:13 PM   #2
cableguy0
Re: does anyone offer an overdrive gear set for saginaw 4 speed with granny gear
Nothing that im aware of. You really cant just add an overdrive to a transmisson that wasnt designed to have it. Not having your 1-1 gear and replacing it with overdrive would hurt a lot in most driving. The switch from 2nd to overdrive would lug the engine a ton and render the gear almost useless. the transmission now has Granny then 1st 2nd and 3rd 3rd being 1-1 You cant just get rid of the 1-1 gear and replace it with overdrive.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 04-23-2011, 09:56 PM   #3
72c10lover16
thats not what i was wanting to do i know that. I wanted a 1st through 4th change in gear sets. by that i mean changing the first gear so it isnt a granny and changing the rest accordingly where as my actual 3rd gear would become 1:1 and 4th would become something beyond that.
Old 04-23-2011, 09:59 PM   #4
cableguy0
Ahh gotcha... Your best bet is to just swap to a different transmission.
Old 04-23-2011, 10:03 PM   #5
72c10lover16
Yeah thats kind of what i have been finding out. Do they make any 4 speeds in other cars that have an overdrive 4th gear
Old 04-23-2011, 10:05 PM   #6
cableguy0
To get an overdrive your going to likely end up with a 5 speed. Unless you go to an auto.
Old 04-23-2011, 10:09 PM   #7
72c10lover16
i prefer driving a manual better. much more fun
Old 04-23-2011, 10:19 PM   #8
clinebarger
There is the New Process A-833 3 speed with overdrive transmission. Some mid 80s chevy trucks had them. Its a old Chrysler design & a good transmission.
clinebarger is offline   Reply With Quote
Old 04-23-2011, 11:40 PM   #9
ka_jd7and1
is a fungineer
ka_jd7and1's Avatar
Yup, I'm currently looking for one of those as well. NP440, GM code MY6.
2003 S10, 2.2 auto- the daily driver, currently with a 2"/2" drop and some minor engine bolt-ons
1978 Impala 2-door, race 350/T350 - the new race car, in progress
1968 Chevy C10 longbed- 3/5 drop, currently undergoing a heart transplant
ka_jd7and1 is offline   Reply With Quote
Old 04-24-2011, 12:47 AM   #10
72c10lover16
its only got 3 gears or 4 total?
Old 04-24-2011, 01:20 AM   #11
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
4... one is the OD
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-24-2011, 01:22 AM   #12
blackedoutharley
It has a total of 4 forward gears with 4th being a slight overdrive.
This transmission was also offered in Dodge Aspen and Plymouth Volare vehicles from the mid to late 70's as well.
I would assume that the input shaft splines are different but I can't see there being something preventing it from being used on a GM.
blackedoutharley is offline   Reply With Quote
Old 04-24-2011, 03:21 AM   #13
Winola73
In the late 60's/early 70's GM offered the full synchro Saginaw 3 speed with OD and the OD unit can be adapted to the Saginaw 4 speeds "relatively" easily. Problem is that they are getting pretty rare these days.
Winola73 is offline   Reply With Quote
Old 04-24-2011, 02:47 PM   #14
72c10lover16
so what all cars did the A-833 come in or these other transmissions with the 4th gear overdrive
Old 04-24-2011, 03:54 PM   #15
Redcap
Most often, they came in A-body Mopars. Dart, Duster, Volare, Aspen, etc.
Redcap is offline   Reply With Quote
Old 04-24-2011, 04:04 PM   #16
RichardJ
>>the OD unit can be adapted to the Saginaw 4 speeds<< CAR Saginaw.
Are you not talking about a 4X4 with the SM465 truck trans? You'd play hell getting the T-85 3-sp OD on the back of the SM465 and then you would probably have to use a divorced transfer case.
The A-833 is the Chrysler car 4-spd used in their cars in the '60s and '70s. The A-833 OD is still a car 4-spd, but was also used in Chevy and Dodge trucks.
4th gear is still 1:1 , but is called 3rd. 3rd is regeared and called 4th as the OD.
You end up with what Cableguy was explaining. With your SM465 you drive 90% of the time using 2nd, 3rd and 4th. Pretend you have an OD that is above 4th. Drive around using only 2nd, 4th and OD.
The A-833 with OD has a pretty good step, but not as big and it does have a usable 1st gear. The A-833 OD probably works good in a light car, but I don't think it makes a good truck trans. The regular A-833 is unbreakable as a car trans and has good gear spacing for that.
There are several on the Stovebolt forum that use the A-833 OD and claim they love it, but there are some that quietly replaced it with a 5spd.
Again, you would be looking at a divorced Transfer case.
Wouldn't an NV4500 4x4 5spd be a mostly bolt up conversion?
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 04-24-2011, 06:37 PM   #17
72c10lover16
im not sure what 5 speeds would bolt in. I am trying to find out all the info i can get about getting an overdrive. I really would like a bolt in application lol. I am currently getting 7 1/2 miles to the gallon doing 75 with 33"tires. Thats roughly 75 the tires throw off the spedo. any info on different transmissions that would bolt in is appreciated.
Old 04-24-2011, 08:10 PM   #18
cableguy0
Your just flat out not going to get good mileage in a 4wd with 33 inch tires. Modern trucks with fuel injection and overdrive barely get 10-12mpg with big tires. Unsprung weight has a huge impact on the amount of power it takes to move a vehicle.
Old 04-24-2011, 08:48 PM   #19
72c10lover16
well on the highway doing 75 i am doing about 3,000 rpms or a little more usually more. I think and overdrive would bring that down a little bit which would increase fuel mileage a little bit. I used to have a 72 2 wheel drive with a 350 and a 4 barrel quadrajet and i got 13 mpg
Old 04-24-2011, 08:52 PM   #20
cableguy0
You cannot compare 2wd and 4wd. Its not apples to apples. Slow down to 65mph and see if your mileage improves any. It probably will a little bit but I wouldnt expect a huge improvement.
Old 04-24-2011, 09:07 PM   #21
72c10lover16
well right now im in laramie wyoming for school and i graduate june 24th then i got to drive this thing home. its an 8 hour drive 530 miles im hoping to find something to help with fuel mileage so i can do 75 comfortable. since that is the speed limit. doing 65 is going to turn it into a 10 or 11 hour drive
Old 04-25-2011, 07:15 PM   #22
bmchevy1979
bmchevy1979's Avatar
you could put a nv4500 5 speed has granny low and overdrive they came in Chevy trucks from 93-98 it is about the same size as the sm465 the shifter is set a little further back and Advance Adapters makes a adapter kit so you can use your transfer case or you can get a np205 off of a th400 and it will bolt up.
Adapter Kit
http://www.advanceadapters.com/products/pn-27-0030/
Dirty Larry and a few others in the 4x4 section have done this swap here is Larry's there is a lot of good info in here
http://67-72chevytrucks.com/vboard/s...d.php?t=431033
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
