Old 05-18-2011, 08:17 PM   #1
texastrendz
porterbuilt sway bar install
those with a sway bar from porterbuilt, is the second bolt around the radius of the front horn? looks like when i go to drill the second hole is going to tweak the bracket. anyone got a picture of the hanger of the sway bar off of the frame.
texastrendz is offline   Reply With Quote
Old 05-18-2011, 09:36 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: porterbuilt sway bar install
Does this one help?
Keith
Convert to disc brakes.
Old 05-18-2011, 09:47 PM   #3
texastrendz
Does this one help?
thanks for the pic, what i am looking for is a close up side view of the frame hanger with the bushings. hopefully someone with an installed sway bar will be able to post one up. i am sure it will not be a problem with the install, just want to make sure. sometimes i have a problem with over thinking things.
Old 05-19-2011, 01:05 PM   #4
PBFAB.COM
PBFAB.COM's Avatar
Daniel-
Yours may be slightly different with the factory control arms, but this should give you what you need:
http://www.porterbuiltfabrication.co...-Equipped-quot
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 05-19-2011, 01:29 PM   #5
texastrendz
thanks nate,
you know me, always over thinking things. I was worried about the radius of the front horn and the flat strap for the bracket. You probably got a thousand of these things out and with no issue. I line it up tonight and shoot the hole in it. lol.
Old 05-19-2011, 01:32 PM   #6
PBFAB.COM
PBFAB.COM's Avatar
Originally Posted by texastrendz View Post
thanks nate,
No worries Daniel! Nothing wrong with thinking before cutting/drilling.
Let me know how it goes!
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 05-21-2011, 03:36 PM   #7
grs
Hey, lolife99. Did the cross member raise the engine up any, and did it push the engine forward any.
grs is offline   Reply With Quote
