Old 07-07-2011, 06:32 PM   #1
MikeJones16
MikeJones16's Avatar
Tired of this Transmission bull.
Ok guys, Lets see if you can figure out the problem. My transmission won't engage.. Put it in R nothing, no movement what so ever. Same as the other gears. I just rebuilt the T-case and No its not in N, The sleeve that goes between the tranny and the T-case i've replaced. The thing is full of tranny fluid. I know the gauge selector is working, or atleast its moving the dial or whatever you'd like to call in under the pan.
I have no idea whats going on. Its a TH350.I just want this thing to be drivable.
Thanks, Mike.
MikeJones16 is offline   Reply With Quote
Old 07-07-2011, 06:58 PM   #2
donut
donut's Avatar
Re: Tired of this Transmission bull.
Hate to ask the obvious, is it (trans) full of fluid?
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 07-07-2011, 07:02 PM   #3
Mrtn15
Mrtn15's Avatar
its a th350! theres a vacume on the back right side beside where the yoke goes into it, check if the hose is connected, if it is check for leaks or cracks.
1986 Single cab 2WD Chevy 350/350
1977 Single cab Dually C30 BB454!
Mrtn15 is offline   Reply With Quote
Old 07-08-2011, 12:31 AM   #4
vtwinsport
vtwinsport's Avatar
Second the vacum line comment. Did you have any problems getting the transmission tight to the block?
76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262
http://beerbreadbike.wordpress.com/
vtwinsport is offline   Reply With Quote
Old 07-08-2011, 01:59 AM   #5
MikeJones16
I did not notice the vaccum thing. Where does it hook up to? Intake mani vacuum port? Would this really keep it from not engaging?
And yeah its full of fluid haha. and no problems getting it to the block
Old 07-08-2011, 12:47 PM   #6
Mrtn15
Mrtn15's Avatar
Yes sir
Old 07-08-2011, 01:45 PM   #7
spudz
spudz's Avatar
Crank it up, put it in drive then back to park.. If you hear a grinding noise then the transmission is working and something in the transfer case is broke. If no noise and your flexplate is connected to your torque converter, then something inside your transmission is broke and its time for a rebuild.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 07-08-2011, 02:19 PM   #8
MikeJones16
Ugh, lets hope this dang works. I'd hate to take that tranny out again.
Old 07-08-2011, 03:59 PM   #9
MikeJones16
Hooked up the vacuum, still nothing.. No RPM drop when into gear. Nothing at all.
Tried moving it around and still got nothing.
Old 07-08-2011, 04:13 PM   #10
DetroitDan
DetroitDan's Avatar
When Ive had modulator valves go, it just wouldn't allow it to shift. Youd still have reverse and 1st.
I'd be looking at the shift linkage and then transfer case linkage.
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop.
DetroitDan is offline   Reply With Quote
Old 07-08-2011, 04:49 PM   #11
MikeJones16
When i had the pan off, the linkage was fine, and I rebuilt the T-case. So I know the problem doesn't lie with the transfer case.
I'm ready to just pull this thing and rebuild it as a damn race tranny.
Old 07-08-2011, 08:12 PM   #12
spudz
spudz's Avatar
if the transfer case was bad and transmission working. When he shifts from reverse or drive to park he will hear the parking paw inside the transmission grinding. Since he is not hearing that.. Something is wrong inside of the transmission.
Old 07-08-2011, 11:08 PM   #13
rjn72
rjn72's Avatar
Put it on jack stands, if its not high enough already, and have someone you trust get in and put it in gear. You can be underneath listening for any "noise" that shoould or should not be there. You should be able to hear the tranny click into gear. Also, what year is your truck, is it full time 4x4? I had one that if both drivelines were not in it made some terrible noises unless it was in "lock" position. I have never had one that made no noise unless the gears on maybe the pump are sheared, but I wouldn't think so. Now I am just typing to myself I guess, Kind of like thinking out loud. lol.
JESUS IS LORD
87 crew cab V30 454/400
rjn72 is offline   Reply With Quote
Old 07-08-2011, 11:15 PM   #14
71swb4x4
71swb4x4's Avatar
Have you verified that when you move the shifter that the linkage is actually shifting the tranny? With it off, block the tires and put the emergency brake on and have someone shift it while you are under watching everything.
Start with the simplest things and work your way from there.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-09-2011, 12:55 AM   #15
MikeJones16
Everything looks okay to me. everythings intact. I could hear a slight whooring sound. I'm thinking its sheared off or the clutches are toast.
I'm getting close to just ordering a full race rebuild kit/shift kit/converter and never looking back. But the funny thing is, the rpm's don't drop when i try to put it in gear..
Look at my build thread if you have any questions, its a 79chev on a 79gmc frame with a th350/np205
Old 07-09-2011, 12:31 PM   #16
raceman6135
Dino burner
raceman6135's Avatar
Umm.... did you remove the filtre in order to take the picture? Because if not, that's your problem right there.
raceman6135 is offline   Reply With Quote
Old 07-09-2011, 01:27 PM   #17
MikeJones16
I did remove the filter for the picture... Pretty sure that wouldn't be the problem even if it wasnt there.
Old 07-09-2011, 05:54 PM   #18
y5mgisi
Second Chance Program
y5mgisi's Avatar
Its very very rare for a trans to be so toasted that it wont even make so much as an rpm drop when putting it in gear. For example, i had one that wore out on me a while back i could idle it around all day long and reverse worked as normal. when i pulled it apart there was NO friction material left on the first gear clutches. Still, it would move around the driveway at idle and back up fine. Dropped into dear like nothing was wrong. And for something to have broken bad enough for it to just not move, you would have had to thrown some insane horsepower at it. Like in the 500+hp range. So i doubt anything is actually broken. I really think that something is just wrong with your setup. I would really recomend putting the t-case in 4hi and in all other gears and trying it then too.
y5mgisi is offline   Reply With Quote
Old 07-09-2011, 08:11 PM   #19
pilotj
Same thing happened to my TH400. Came out one morning and had no gears at all. Made no bad noises, just felt like it was still in park or neutral. Had it towed to the transmission shop figuring my transmission was toast. Ended up being my torque converter. Went ahead and had them rebuild the tranny anyway while it was out
1979 Chevy C20 350/TH400
1974 Chevy C30 350/4speed
pilotj is offline   Reply With Quote
Old 07-09-2011, 11:14 PM   #20
MikeJones16
I'll be ripping the transsmission apart tomorrow. I'll let you guys know.
Old 07-13-2011, 04:26 PM   #21
81chevys
Its a little late now... but did you check the shifter linkage?? Ive had it happen to me where the linkage was just slipping around and not really engaging the trans but when i got under the truck and looked the rod was sliding up and down when i moved the shifter.
also if you havent pulled the trigger see if you can manually turn the rod that the shifter slides into. (i think the parking paul is on it) if that doesnt work try dropping the valve body and checking wherever that rod goes.
if your hearing a whining from the tranny area it could be the converter or the front pump.
i didnt think you would hear that noise if the vehicel wasnt in gear though.
you should be able to hear the distint clanks? can you hear that when you move the shifter.( dont forget to set the park brake before you try to listen for the sounds leaning out of the truck.
81chevys is offline   Reply With Quote
Old 07-13-2011, 07:20 PM   #22
MikeJones16
Yeah you can listen to the shifter go through each gear. and I had someone shift through the gear while I had the pan off. The park paul was there and working. And there was no noise whatsoever. also, the rpm's didnt jump down at all.. they remained at the higher idle.
Old 07-13-2011, 08:32 PM   #23
y5mgisi
y5mgisi's Avatar
Are you saying you had the truck running with the pan off?!?!? That=not ok! You do know how an automatic trans works right?
Old 07-13-2011, 09:52 PM   #24
bmchevy1979
bmchevy1979's Avatar
it could be a broken output shaft I broke one in one of are ranch trucks by putting it into park before completely stopping (got in a hurry) and when I got back in the truck I put it into gear and I didn't have anything wouldn't even cause a rpm drop Me and my grandpa took it apart and the output shaft was broken in two. it is not very common for this to happen but it is a possibility I only have seen it one other time. so best of luck and hope you find out what it is
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 07-13-2011, 10:01 PM   #25
MikeJones16
Haha, No i never had it running without the pan.
Well this is quite possible.. I'll upload a couple pics of what my tailshaft sleeve looked like, and the input shaft on the T case.
