08-04-2011, 09:42 AM | #1 |
Vintage 4x4s
Wing window questions
Is the stud (that the spring is on) spot welded to the chrome metal glass frame? I have one that isn't attached and was wondering if broken or they were held in with spring force into a dimple.
Also I'm assuming the 72's have an extra tapped bolt hole in the main framework to line up with the extra screw in the door?
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
08-04-2011, 04:48 PM | #2 |
Vintage 4x4s
Re: Wing window questions
really? nobody knows?
08-05-2011, 08:23 AM | #3 |
Vintage 4x4s
ttt
08-05-2011, 08:58 AM | #4 |
Are you talking about Part #1 on this page?
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=19 I am pretty sure that whole part is welded on, but I'll have to take a look when I get home (I have a spare that is not in the truck atm) |
08-05-2011, 09:41 AM | #5 |
Vintage 4x4s
Yes, thank you Dorian, It's the stud that is directly above #6 (spring) in your drawing. It is shown as part of the chrome surround so it probably is welded on like you mentioned. If you could confirm that would be great!
08-07-2011, 12:04 AM | #6 |
stud was welded. common problem even on later years
07-31-2015, 02:36 AM | #7 |
Hey, digging up this old thread. I have the same issue with my drivers side wing window. It will stay in the closed position fine but if I try to open it the pivot point will pop loose. So looking at the attached LMC diagram it looks like I can tack it back together. Is it that simple or am I missing something?
Is the spring just a tensioner to keep the window from flopping around? http://www.lmctruck.com/icatalog/cb/full.aspx?Page=24
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
07-31-2015, 08:17 AM | #8 | |
The Older Generation
You should be able to tack weld it. That's the nice thing about the Mig welders, you can keep the welded area pretty cool. The spring is an adjustable tensioner that never gets lubed so that puts a lot of stress on the joint between the window and tensioner stud. Check this thread out, "highwinger" and I posted a lot of info in it on removing, rebuilding, and installing vent windows.... http://67-72chevytrucks.com/vboard/s...d.php?t=660294 LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 07-31-2015 at 08:40 AM. |
07-31-2015, 09:43 AM | #9 | |
Glad it's a simple fix. Thanks for the info.
