Old 08-12-2011, 12:47 PM   #1
dukkie
My Spoon Is Too Big
dukkie's Avatar
454 recipe
I want to drop a 454 into my 72 C20
I Want to duplicate this Horsepower TV Episode basically perhaps some small upgrades with your input.
This currently only at the research stage, I have no block, no parts, Just a Big Idea and a Small Budget.
In the link above they used
Hydraullic flat tappet cam 228/238 @50
pullies
lifters
double roller timing set
Machined iron heads
pioneer brand balancer
dual plane aluminum intake
mallory HEI
Pro sidewinder distributor
8mm wires
750 cfm carb
mr gasket oil filter adapter
hit 409 hp 524 torque on dyno
1972 C20, 03-14-10 Build Thread
2000 Silverado 4.8L, 11-04-13 (Currently Parting)
1999 Silverado 5.3L, 07-07-14. (Engine Donor)
2015 Ram 05-20-15 (Daily Driver)
dukkie is offline   Reply With Quote
Old 08-12-2011, 12:49 PM   #2
dukkie
My Spoon Is Too Big
dukkie's Avatar
Re: 454 recipe
In this episode they throw out the budget and install
lunati solid roller cam
lunati lifters
merlin single plane intake
RHS pro action heads 320cc 225In 185 ex
KB pistons
Eagle balanced crank
Eagle rods
clevite bearings
melling hi volume oil pump
pioneer dampner
1000cfm holley
1.7 ratio rocker arms
custom pushrods
pertronix flamethrower distributor
8mm wires
with this combo they hit 532HP 561 torque
then theres a tweak of lighter distributor spring they get 622.5 hp
However they never say the cost and the Merlin heads alone are more then the first build up
Old 08-12-2011, 12:50 PM   #3
dukkie
My Spoon Is Too Big
dukkie's Avatar
Re: 454 recipe
My goal is more autocross than drag strip. whatever HP comes with 550 torque in low to mid range.
So my question to everyone here is what are the specifics i need to accomplish this?
What heads? what intake? what cam? ect...
I would like to go aftermarket aluminum heads instead of stock iron
Old 08-13-2011, 01:28 AM   #4
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: 454 recipe
You want to do this and autocross a C-20??
prostreetC-10 is offline   Reply With Quote
Old 08-13-2011, 01:47 AM   #5
darthwall
Re: 454 recipe
if you want to autocross dump the money into suspention and rear end
darthwall is offline   Reply With Quote
Old 08-14-2011, 07:28 PM   #6
dukkie
My Spoon Is Too Big
dukkie's Avatar
Re: 454 recipe
considering autocross style, not actually competing
Old 08-15-2011, 01:35 AM   #7
darthwall
Re: 454 recipe
well still autocross style would be lots of suspension work and lots of torque
Old 08-15-2011, 10:09 AM   #8
dukkie
My Spoon Is Too Big
dukkie's Avatar
Re: 454 recipe
thats what Im looking for:
1.how to get the most torque with the least dollars from a 454
2.then those saved dollars can buy all the suspension stuff that I havent even began to look at
Old 08-15-2011, 10:19 AM   #9
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: 454 recipe
A mildly warmed over 454 will put out gobs of torque. I would think autocross would want a lighter engine than a big ol' hog in front.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 01-13-2012, 03:41 PM   #10
dukkie
My Spoon Is Too Big
dukkie's Avatar
Re: 454 recipe
but i still want to put a bigblock back where it belongs
Old 01-13-2012, 05:45 PM   #11
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
Re: 454 recipe
Don't forget that their dyno probably reads high for "wow" factor.
ProStreet68SB is offline   Reply With Quote
Old 01-13-2012, 08:16 PM   #12
ratfreak8871
Re: 454 recipe
they must have used "peanut" port heads and a crappy intake, the HP # is about 80 HP low
ratfreak8871 is offline   Reply With Quote
Old 01-14-2012, 08:27 AM   #13
cdowns
cdowns's Avatar
Re: 454 recipe
keep in mind most if not all TV shows are 95% paid commercial endorsements
i'm in the process of assembling parts for a bigblock build// as far as heads from reading up and talking to hipo machine shops the overall impression i'm getting is that the work and money required on 40year old heads,oversized valves,sleeving valve guides even just simple basic port cleanup for the cost you're pretty much alot better off buying new right out of the box and performance wise far ahead plus if you go aluminiuum theres near a 100lb of weight off the front wheels
i'd like to find a set those dizzy springs that are worth 90horsepower
Old 01-14-2012, 09:52 AM   #14
SSC's76
No No
SSC's76's Avatar
Re: 454 recipe
Yup thats what i was thinking seems they tend to use the lowest output oem parts to turn around and drop a insane set of heads and a nasty cam and a huge perfectly tuned carb on it for the second go around.
good show but gotta pay for it someway.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 01-14-2012, 11:59 AM   #15
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: 454 recipe
If you want torque out of a big block thats not real hard - don't think so much about the big trick stuff - even a 1990 454SS motor with a cam change and different intake would be tons of fun and a cheap build - they use the peanut port heads which flow well up to 4200 or so - perfect for autocross and standard street use
Start looking at crate motors, read the build sheets and pay attention to valve size, camshaft size, camshaft indexing, those are som eo the big keys
Be careful with aftermarket AL heads - many flow way to much for good street use - or the torwue monster you want to build.
Also - consider a stroker motor - much easier to get torque out a 496 than a 454
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 01-15-2012, 11:56 AM   #16
dukkie
My Spoon Is Too Big
dukkie's Avatar
Re: 454 recipe
is this guy rob phillips a member here? he is my inspiration with a 496
**Correction 468
Old 01-15-2012, 12:07 PM   #17
prostreetC-10
My Carbon Footprint
Re: 454 recipe
That's a mean little truck! The announcer said it was a 468. Did he mean 496? To throw a truck that big around is pretty cool.
Old 01-15-2012, 12:17 PM   #18
dukkie
My Spoon Is Too Big
dukkie's Avatar
Re: 454 recipe
im proably wrong and the announcer right because the post above mine said 496.. edited above
Old 01-15-2012, 01:19 PM   #19
cdowns
cdowns's Avatar
Re: 454 recipe
468 is a 454 bored 60 over i do believe
Old 01-15-2012, 01:33 PM   #20
Newtz67
Newtz67's Avatar
Re: 454 recipe
Yes, a 454 bored 60 is 468. Feel free to check out my build of my 468. This was my first big block build, so I copied an engine that Edelbrock built, minus the heads. It's under My '67 short wide. Good luck!
Newtz67 is offline   Reply With Quote
Old 01-15-2012, 01:37 PM   #21
prostreetC-10
My Carbon Footprint
Re: 454 recipe
It's a whole lot less expensive to make a 460 or 468 as apposed to a 489/496. The 496 will have unreal torque but take quite a bit more $$$.
454, big, block, build
