09-18-2011, 05:06 PM | #1 |
Rear custom four link pics!
I wanna see what some of yall have done/seen. Lets see em!
09-18-2011, 06:52 PM | #2 |
Re: Rear custom four link pics!
Don't know how custom it is but this is one i put under the '51 suburban. It's from TCI
09-18-2011, 07:04 PM | #3 |
vintage car junkie
Heres a picture of the rear setup on my 50.
1950 chevy truck, s10 swap, bagged, v8, 18s My build: http://67-72chevytrucks.com/vboard/s...d.php?t=392761 |
09-18-2011, 07:44 PM | #4 |
I would like to see a close up of the front arm bracket and length of the arm, Thanks
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
09-18-2011, 08:58 PM | #5 |
I just pulled the TCI four liunk out of my 57 and fab up new front mounts.I think that the front mount hang way to low. will try to get some pic
09-18-2011, 09:02 PM | #6 |
Is that a watt's linkage in the rear? it looks like there is something between the shocks
09-18-2011, 09:08 PM | #7 |
Those are sick guys!
09-18-2011, 09:12 PM | #8 |
09-19-2011, 12:12 AM | #9 |
Not the best pics but here are a few of mine.
Kim |
09-19-2011, 12:34 AM | #10 |
great work guys - kim your truck rocks!
09-19-2011, 02:08 AM | #11 |
Here's what my unfinished parallel 4 link/ watt's link looks like.
09-19-2011, 05:37 AM | #12 |
HRRookie why exactly are you mounting the 4-link outside the frame rails? Are you not planning to mount a wide set of tires out back? Only you and Kim57 have real 4-links of the street variety.
09-19-2011, 10:07 AM | #13 |
i like the watts linkage. looks nice.
09-19-2011, 10:20 AM | #14 |
09-19-2011, 11:26 AM | #15 |
Here is what we have concocted, tell me what you think, if yall see strength's or weakness's in doing it this way.
'51 Chevy 3100 longbed pickup - bagged/MII/4link/bravada 3:73 posi rear. |
09-19-2011, 11:32 AM | #16 |
You got it. I considered running a huge tire but I won't be making enough power to justify it. On top of that, I didn;t have to take out the crossmember where thr front brackets mount.
09-19-2011, 04:54 PM | #17 |
nice welding.
09-19-2011, 07:40 PM | #18 | ||
vintage car junkie
09-19-2011, 08:07 PM | #19 |
again let me say you guys do great work !
09-19-2011, 10:21 PM | #20 |
Studio Jak,
I see a problem with the panhard rod being on top of the axle. The panhard rod needs to be in the middle of the arc that the axle panhard rod mount will scribe in motion. In other words, at the top of the arc, the panhard rod will be centered, at the bottom of th arc it will pull the axle to the right. If the panhard rod was mounted on the axle centerline, it would have maybe 6-7 inches of up and down movement without appreciably pulling the axle to one side. |
09-19-2011, 10:56 PM | #21 | |
09-20-2011, 08:09 PM | #22 |
here is a few pictures of my 4 bar setup.with the new c-notch had to make new front mount because the old mount were to low.and now with the rearend in have to make up new mounts for the coil overs and the panhard bar.
09-20-2011, 09:24 PM | #23 |
Here's what i came up with.
09-21-2011, 04:29 PM | #24 |
Coupeguy2001, Parkwood,
I was wondering if it was going to give me trouble. thank you for the response. Parkwood, I like your panhard being diagonal across the fourlink. Who makes that?? Is is as sturdy as it seams?? Thats a real clean setup you have going
09-21-2011, 07:41 PM | #25 | |
It is sturdy and easy to adjust and stays out of the way of the exhaust too.. you need the phone number let me know..wayne |
