Old 10-28-2011, 08:29 PM   #1
Envy
Envy's Avatar
Mounting and Plumbing AccuAir Elevel ideas
I need pictures and ideas of how people have been mounting and plumbing their eLevel systems on a 64-72 chassis. Im running dual compressors and dual tanks, one on each side.
Envy is offline   Reply With Quote
Old 10-29-2011, 06:10 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Mounting and Plumbing AccuAir Elevel ideas
Also interested in this.
Anyone?
Keith
Convert to disc brakes.
Old 10-29-2011, 08:09 AM   #3
Pkh66
Me too. Was pulling bed tomorrow to get started.
Pkh66 is offline   Reply With Quote
Old 10-30-2011, 10:20 AM   #4
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Anyone?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 10-30-2011, 07:35 PM   #5
Envy
Envy's Avatar
No one has any ideas apparently. So i spent my one day a week at the shop pondering this issue. Came up with this idea and although i will refine the output surrounding area by have a plate water jetted and replacing that center area where the manifold mounts, i think im going to go with it, i like it. Protected, centered, hidden, and accessible. The biggest issue im facing now is the fact taht i have to mount the computer so close, but i think i have that figured out, just didnt have time to mock it up yet.
Old 10-30-2011, 07:47 PM   #6
VA72C10
VA72C10
VA72C10's Avatar
Don't hart rod and n2billet have this system installed and rckcrln had it on his tahoe build before selling...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-30-2011, 07:49 PM   #7
Envy
Envy's Avatar
My plan is to cut out the area that the VU4 tucked up into, and weld in a thick piece of plate flush at the top so that i can tap it and do away with the mounting nuts. Il then have two plates (one for each side) water jetted or milled to perfectly surround the push-to-fit connections for a cleaner look.
The reason for this is that the aluminum manifold fits perfectly into that crossmember, but the protruding connectors keep it from fitting, so i had to carve it out the same on both sides. The new sides will be welded to the new top plate and provide the necessary clearance on the inside since they will be on the outside of the crossmember.
The computer will be mounted upside down in the crossmember with the connectors facing toward the back. The backside of the crossmember will be altered and carved out to clear and shroud the connections. The crossmember also provides nice protective hideaway for the wiring and air inputs.
Old 11-01-2011, 01:08 PM   #8
dznucks
dznucks's Avatar
It all depends on how creative you want to get and how clean you want it to look.
My system is not show quality, but.....I am running a single compressor and two 3 gal tanks. I attached a basic diagram I made when I was at the same point you are. You can get an idea of how the components, wiring, and tubing are routed.
I installed the valve and ECU in a enclosure for protection. It also made more sense to me to keep all the wiring and tubing inside the frame rails.
I know you said you have 2 compressors so you may want to mount the compressors close to the tanks. Keep in mind the intake filter for the compressor. You dont want the tires throwing water on it.
dznucks is offline   Reply With Quote
Old 11-01-2011, 02:17 PM   #9
belowme51
belowme51's Avatar
if you want a clean set up the EXO mount is the way to go......but you have comps and tanks already....here are a few shots of mine...i did make sure to get the mounting bracket they use for the EXO kit so you can mount the valve, ecu, and fuses all in one tidy place....at that point you can determine where you want it all.....keep it close for wire lenght reasons....the standoffs on the frame at are 2" and threaded on both ends for attachment of the sensors and the clamps are just diameter matched and I drilled and tapped them for the ball mounts to keep it clean...just some Ideas but make it yours.
belowme51 is offline   Reply With Quote
Old 11-12-2011, 08:33 PM   #10
Envy
Envy's Avatar
Thats an awesome setup.
Would there be any issues mounting the VU4 manifold upside down?
Old 11-13-2011, 11:53 AM   #11
belowme51
belowme51's Avatar
no you can mount the vu4 any way that you want....its all your valves in one tidy package but does not matter how you mount being its ran off the connections and air pressure.
Old 11-13-2011, 01:13 PM   #12
kieth
kieth's Avatar
Using the Accuair manifold is the way to go, it eliminates plumbing and wiring which can really be a headache. Its sounds expensive when you first look at it, but when you see how compact and easy it makes wiring and plumbing you begin to see it really saves money in the long run. Try to use those push on fittings anywhere you can, they do not leak and make installing and routing air lines a breeze. Kieth
I am trying to come up with a inexpensive york 210 air compressor so i can eliminate the electric compressors and their inheritant problems. Have not found one yet but will soon, plan to mount it where the smog pump was once located on my tbi 350 ....
kieth is offline   Reply With Quote
Old 09-13-2012, 10:55 PM   #13
ChopperCity256
ChopperCity256's Avatar
anymore pictures of peoples set ups? i'm at this point now!
ChopperCity256 is offline   Reply With Quote
Old 01-04-2013, 09:24 AM   #14
Square_78
Square_78's Avatar
Anyone use the EXO mount somewhere under the bed? I want to use the mount so I can keep everything together. I dont want it in the back of the bed for security reasons as the truck will be parked outside sometimes at night. I've got the accuair eLevel kit with dual compressors and I am getting ready to start figuring out where to mount everything... I was thinking to mount the EXO somewhere in the back where the spare tire would be under the bed.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 01-04-2013, 11:17 AM   #15
PBFAB.COM
PBFAB.COM's Avatar
We made this cool little panel for Old Aux.... keeps everything in one spot and can easily be tailored to fit under the bed. Comes with all the mounting holes pre-drilled for easy installation of all the electrical components.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 01-04-2013, 03:39 PM   #16
jimmydean
jimmydean's Avatar
That looks great! I was looking to do something similar to that between my rear mounted compressors.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 01-06-2013, 01:58 PM   #17
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Nice install Nate!
Any others out there?
-Nate
Old 01-06-2013, 07:18 PM   #18
gofast68c20
Here's mine
gofast68c20 is offline   Reply With Quote
Old 01-06-2013, 08:10 PM   #19
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Those hardlines look great!
-Nate
Old 01-06-2013, 11:51 PM   #20
superflysteiny
superflysteiny's Avatar
I know it is not accuair but it will be in a week so I will get you more pics then
superflysteiny is offline   Reply With Quote
Old 01-29-2013, 07:57 PM   #21
Square_78
Square_78's Avatar
Very cool idea! Keeps everything neat and secure.
#teamlongbed
Old 01-30-2013, 03:35 PM   #22
baggedbigblock
Wow, What a frame Superflysteiny!!! JEEZ!!!
baggedbigblock is offline   Reply With Quote
Old 02-02-2013, 02:05 PM   #23
superflysteiny
Wait till its done
Old 10-13-2013, 10:49 PM   #24
knomadd
knomadd's Avatar
Anyone got more pics of the porterbuilt piece? I'm curious where this is installed.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 10-14-2013, 05:05 AM   #25
ddubbs
ddubbs's Avatar
They have this panel mounted by the front bed panel. The piece of Steel above it is the raised bed floor. If you want to see a better pic look at Old Aux build thread. Better picture there.
LIFTED OR LOW THE ONLY WAY TO GO!!!!
Check out my build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=517346
Projects
56 Chevy pickup Porterbuilt FR/RR dropmembers
ddubbs is offline   Reply With Quote
