Old 12-06-2011, 01:35 PM   #1
mobileortho
mobileortho's Avatar
Bear Claw latches
For those of you using Bear Claws, what size works better, large of small? Also did you use the install kit along with it?
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 12-06-2011, 01:44 PM   #2
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: Bear Claw latches
I use the large one with the install kit.
Kabwe is offline   Reply With Quote
Old 12-06-2011, 01:47 PM   #3
Scottshotrods
Double jaw for sure alot safer for the truck doors.We have a ton in stock and can help you out
Justin
Scottshotrods is offline   Reply With Quote
Old 12-06-2011, 03:45 PM   #4
cajundragger
make sure you use the doubles. I have singles and it sucks cause as the door latches it pulls it down. So they are hard to align.
cajundragger is offline   Reply With Quote
Old 12-06-2011, 06:25 PM   #5
booger1949
large ones, trique now makes an exact replacement door latch, u can use your inside an outside door handles an locks, it was a little pricey i think 350 if i remember rite, but god what a diffrence, u want regret it, o that was for a 1949 ad
booger1949 is offline   Reply With Quote
Old 12-06-2011, 07:40 PM   #6
cleanshaven84
cleanshaven84's Avatar
I've been wondering this myself. Not trying to hyjack the thread but was also wondering where a good place is to get these with the install kit. I'm a good ways from needing a set but it would be nice to have all my ducks in a row before I get to that point. Thanks in advance.
1949 GMC Pickup
Project "No Time '49"
Currently working on S-10 chassis swap.
Philippians 4:13 - "I can do all things through him who strengthens me."
cleanshaven84 is offline   Reply With Quote
Old 12-06-2011, 08:10 PM   #7
Scottshotrods
We have plenty of them in stock and can help all who are in the market for some latches and power door kits.
Justin
Old 12-06-2011, 08:20 PM   #8
Kabwe
Certified Car Nut
Kabwe's Avatar
I got mine on ebay and they are the large double claws. I bought them with the installation kit.
Old 12-06-2011, 08:42 PM   #9
52 Rat
52 Rat's Avatar
Other than the bolt in bear claws, I have yet to find any that will work with the OE door handle without major modifications. I want to used the push button handle on my 52 and not door poppers. I've been looking at the bolt-in bear claw latches but they are $350 vs. the $20. for the universal units.
My build project http://67-72chevytrucks.com/vboard/s...=1#post4158671
52 Rat is offline   Reply With Quote
Old 12-06-2011, 09:04 PM   #10
booger1949
just remember u get what u pay for,
Old 12-06-2011, 09:06 PM   #11
BlueJeep
BlueJeep's Avatar
After wasting way too much time trying to figure out how to use the turn down handles with the autoloc small ones, I scrapped the plan, welded my doors back up similar to original and went with the Trique bolt in ones. If I wasn't using the original handles it would have been easy, as stated above. I may have even tried to use OEM locks off something with the power solenoids and everything if I wasn't dead set on using the stock door handles. So yes, I went the $350 route, but it's done now.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 12-06-2011, 09:49 PM   #12
52 Rat
52 Rat's Avatar
So true with almost everything. I am going with the bolt in latches.
Old 12-07-2011, 01:25 AM   #13
mobileortho
Wanted to get the Trique units but they're not in the budget right now. Just got a set of large bearclaws with dual jaws with the install kit on Ebay for $45. Plans for now are to shave the door handles.
Robert C.
1950 3600
Old 12-07-2011, 10:41 AM   #14
bretcopsey
Has anyone had any success with the bear claws and original pull down style handles? I'm wondering if this would help
http://www.southernrods.com/categori...duct-1304.html
My 51 project
http://www.cardomain.com/ride/2285825
My 68 Camaro project
http://www.cardomain.com/ride/2277404/1
bretcopsey is offline   Reply With Quote
Old 12-07-2011, 11:31 AM   #15
mknittle
mknittle's Avatar
Justin
Justin,
Do the ones you sell have locks? I want to run the stock door handles at least on the outside.I would also like to be able to lock the doors from the outside.
Thanks Mark
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 12-07-2011, 12:12 PM   #16
mobileortho
I looked at those as well but was wondering if there were provisions for the exterior door locks. Decided to shave the handles and forget about it. If someone knows for sure how to make it the stock lock work I'd reconsider.
Robert C.
1950 3600
Old 12-07-2011, 12:32 PM   #17
mknittle
mknittle's Avatar
I have the same problem. But I will not shave anything, so If I had a bear claw latch here I could most likely make it work. if not there has to be something that we can adapt that gives us what we want.
Mark
Mark
My GMC build.
Old 12-07-2011, 01:41 PM   #18
Speedbumpauto
Speedbumpauto's Avatar
I'm using the Trique kit on my 55 and it says right in the package that the handle push locks will not work with their kit. I do find that a huge annoyance and am trying to engineer a solenoid locking system to do the job. The biggest hinderance is devising a mechanical safety unlock in the event of a power failure. I always wondered why some guys put the locking mechanism on the cab and the pin on the door(backwards).....now I know why. It would be way easier to do the solenoid mount and adjusting as well as the mechanical safety on the stationary post as opposed to the moving door. On the up side, they are easy to install and look good and they do integrate well with the stock handles, at least on the mock-up assembly. I ordered new exterior handles with locks keyed the same to solve the exterior problem and I think I've figured out the keyless entry thing to my satisfaction but it will be a couple of months before final assembly and real testing. I'm actually glad someone is having trouble with/questioning the stock lock system because I've spent numerous days saying bad words and wondering why I didn't just buy new stock stuff and leave well enough alone.
Speedbumpauto is offline   Reply With Quote
Old 12-07-2011, 01:49 PM   #19
Kabwe
Certified Car Nut
Kabwe's Avatar
Thats how I did mine. I did not want the solenoids in the door. Now if you are not shaving the door handles thats a different story.
Old 12-07-2011, 02:19 PM   #20
mobileortho
You mean something like this?
Robert C.
1950 3600
Old 12-07-2011, 05:08 PM   #21
Speedbumpauto
Yea....might have to look closer at that. My deal was using some of that black drip system tubing and 1/8 cable and routing it through the same flex joint the power window cables will use. The obnoxious part is attaching it to the bear claw mechanism with provisions for an inside emergency egress and an outside emergency ingress. I've already modified the Trique latch to use the solenoid movement to lock/unlock, since thier lock and the solenoid kit I bought from them appeared to only work correctly on vehicles that have a knob up by the window opening. I just need to incorporate the manual inside, hidden or pretty, and the outside, hidden. I'd sure be interested in how some others have conquered this problem. My problem is probably worse because I'm using one peice electric windows and they take up a lot of space.
Old 12-09-2011, 10:43 PM   #22
rhodog77
rhodog77's Avatar
go with Trique. I installed a set on my dads '54. Worked perfect. Well worth the money. All his friends now call his truck "click click" cuz that all you hear when you shut the doors. Just my 2 cents.
"Get Busy Living or Get Busy Dying"
1970 P10 Stepvan
rhodog77 is offline   Reply With Quote
Old 12-09-2011, 11:35 PM   #23
whid
after weighing my options and deciding i realy wanted my stock handles i also bought a set of bolt ins from trique....what i still dont like is the fact you cant lock your doors from the inside..and since my 49 only has a passenger side door lock,i'm gonna get a second lock and have them keyed alike and install it on the drivers door....the guys at Trique said it will work fine... also if anybody on here is a HAMB alliance member also trique gives an alliance discount.........whid
whid is offline   Reply With Quote
Old 12-13-2011, 01:27 PM   #24
oldcouple
oldcouple's Avatar
I found this kit for 55.5s+, not cheep, but can be installed even if the truck is painted.
http://www.classictrucks.com/tech/11...all/index.html
oldcouple is offline   Reply With Quote
Old 12-13-2011, 06:31 PM   #25
booger1949
i will be trein to figure out a way to put electric door looks cause u can lock the truck if your inside r leavin the truck parked so that seems to be a simple fix, i hope. if any body has done this an has pics please post
