Old 01-02-2012, 09:06 PM   #1
Red Rocket
which diff do i got?
I'm new to the solid front axle deal and i have a 1970 GMC 4X4 and id like to do front disc swap on it but i cant seem to find a conversion for them. i was wondering how i tell which axle i have under my truck its a 6 lug hub.
thanks dan
Red Rocket is offline   Reply With Quote
Old 01-02-2012, 09:19 PM   #2
Mike C
Mike C's Avatar
Re: which diff do i got?
Should be an open knuckle drum brake Dana 44 if all is as it left factory.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-02-2012, 09:25 PM   #3
Red Rocket
ok sweet any place online where i can get a disc conversion kit for it?
Old 01-02-2012, 11:28 PM   #4
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
do a google search. I found a few different options.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 01-02-2012, 11:41 PM   #5
Red Rocket
yeah i have been doing that but its hard to see if they would work or not i don't want to order something and find out it doesnt work. where did you find yours?
Old 01-02-2012, 11:41 PM   #6
63chevyll
gets board easy.......
63chevyll's Avatar
Your best option would be to.swap in a complete front diff.
76 and older Dana 44 with disc brakes will bolt right in
77 and later D44 will bolt right in but you will need new (wider) u bolts and upper spring plates out of the same year.
And any 10 bolt font end will bolt right in but you will also need new u bolts and plates.
IMO that would be your best option. And I've seen those complete front axles go for as low as $100 hub to hub.
63chevyll is offline   Reply With Quote
Old 01-03-2012, 12:30 AM   #7
argonaut
argonaut's Avatar
I would think any 71 or older Dana 44 with disk brakes will bolt right in...
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 01-03-2012, 12:42 AM   #8
63chevyll
63chevyll's Avatar
Didn't the 4x4s only have disc after 71? I'm not 100% sure. 71-76 would be the parts needed.
Old 01-03-2012, 01:01 AM   #9
argonaut
argonaut's Avatar
All trucks had disk starting in 71. My 72 K5 had a Dana 44 with disks up front. However at some point in the 70s the u-joints got bigger and maybe also the axle shaft diameter and spline count. Someone else will have to confirm the details on that.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 01-03-2012, 09:16 PM   #10
Mike C
Mike C's Avatar
I sold a '72 front axle to a guy with a '69 4x4. He just put the spindles, backing plates, etc. on his existing axle. No need to mess with finding matching gear ratio or anything else.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 01-03-2012, 11:30 PM   #11
mjensen
mjensen's Avatar
I'm swapping in a 10 bolt out of a mid 80s 3/4 ton because I got it for a pretty good deal at $160, and it has the all the parts and as an added bonus, the ratio matches the rear.
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
