Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 01-06-2012, 12:29 AM   #1
CLASSIC87'
OL BLUU
CLASSIC87''s Avatar
Changed it up again...
I think its obvious that I am getting bored with this truck... I wish I could lower it... but I don't its possible being a 4x4. Anyhow... here's a pic.
CLASSIC87' is offline   Reply With Quote
Old 01-06-2012, 12:31 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Changed it up again...
Looks good!
Keith
Convert to disc brakes.
Old 01-06-2012, 12:28 PM   #3
LEEVON
LEEVON's Avatar
Anthony,
There are alot of lowered GMT900 4x4's over on performancetrucks.net and gmfullsize.com nobody is complaining about CV joints, all of the lowering components are exactly the same as 2wd...I know a guy who has done 2 with no issues. 3/6 or 4/6 will flatten out your CV angles, that's it.
In fact I wish I had gotten a 4x4.
Just saying...LOWER THAT THING so you can be one of the cool kids too!!!
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 01-07-2012, 10:53 PM   #4
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Looks good!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-08-2012, 11:26 AM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
It would be hard to lower it now that you have those rims on it, but there are kits out there for the 4 wheel drives. Come on up to Emporia and talk to Greg at Gigers Street Rods and Sport Trucks for a really good price on what you want. It would be worth the drive.
Frank
piecesparts is offline   Reply With Quote
Old 01-08-2012, 09:37 PM   #6
Squareforceone
Squareforceone's Avatar
I'm sorry but why would you lower a 4wd what's the point of that? I mean with 4x4 don't you want to have ground clearance?? I'm sorry i just don't get it does somebody want to explain this to me?
Squareforceone is offline   Reply With Quote
Old 01-08-2012, 09:43 PM   #7
piecesparts
Not to be mean, but there are many 4X4s that are not used for hill climbing. They are used for daily driving and working the snow and ice. I can see an advantage to having a 4 wheel drive truck on some days going to work.
However, I also see a lot of 4 wheel drives in the ditch as I drive by them on the ice. Some people have the vision that the extra wheel driving is going to make them invincible. NOT!
For the most part a good posi and common sense will get you just about anywhere.
Frank
Old 01-08-2012, 11:02 PM   #8
Squareforceone
I live in iowa i know what you mean just because you have a 4x4 doesn't mean you can't get stuck, i just mean even if you are in snow if you are lowered you can get snow up in the wheel wellsand other places and get stuck 4x4 or not. Youre right about the good posi and common sense i do alright in my '84 2wd you just have to know how to drive in winter weather i'd rather have stock height 2wd drive than lowered 4x4 but that's just my opinion then again im also not big into lift kits.
Old 01-09-2012, 02:03 PM   #9
piecesparts
I am curious, what it took to get your TPMS sensors moved? Did you have to put on new ones?
Frank
Old 01-09-2012, 02:10 PM   #10
stroker87
most of todays aftermarket wheels accept your TPMS sensors I've been true about 7 sets of wheels on my 07 suburban only a few sets didn't accept them back in 07/08 they just unbolt from your factory wheels and bolt in the new rims
BTW i've really been thinking of lowering my 4x4 07 suburban its not used off road just main in bad weather (snow) here in chicago its not needed as stated 2wd and a posi will do the job but the 4x4 make life a lot easier lol
stroker87 is offline   Reply With Quote
Old 01-09-2012, 02:36 PM   #11
piecesparts
I believe that the TPMS sensors on my 2011 are rubber stems, and if they are, then the stems will not be able to be transferred. I don't know if there is a removable sender inside the tire. I am wondering if they had to put on all new senders or did they just move his sending units and put on new stems.
Frank
Old 01-09-2012, 02:43 PM   #12
stroker87
I be leave you can swap them over but not 100% you might need to buy new stems any local tire shop will tell you
Old 01-09-2012, 09:48 PM   #13
piecesparts
I spent some time with my parts guy buddies at the local GM dealership, this evening. The stem is a rubber one and the TPMS sensor connects to it with a screw. The stem and a new screw costs about $10.00 over the counter and when installed you can use your sensor from the original wheels and NOT loose the computer connection. The complete setup, the stem and sensor sells for about $57.00, if needed. Finally a GM engineering idea that is useful.
Frank
