Old 01-21-2012, 06:41 PM   #1
KyFarm
KyFarm's Avatar
Will a 700r4 matchup to a NP205?
Ok, I posted on here last week that I bought a 72 Highlander 4x4. Lets just say that it turns out I'm a bit of a sucker. I guess I got a little too excited.
At least I do have a decent rolling frame and transfer case. I am now in need of a donor truck with a good cab at a minimum and hopefully a worthy motor/trans. The other body parts I can get.
I'm going to look at one on Monday probably that is local and it has a 700R4 and a freshly built motor.
Are there any issues using that transmission in a 72 LWB frame with a NP205 transfer case? Thanks for any and all help.
Scott
KyFarm's Build/Need help thread
1969 K-10, Short Step, (383HT/4L70E soon)-NP205
KyFarm is offline   Reply With Quote
Old 01-21-2012, 10:40 PM   #2
ghettoluxury
ghettoluxury's Avatar
Re: Will a 700r4 matchup to a NP205?
You will need a NP205 for a TH350 and the adapter.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 01-21-2012, 10:52 PM   #3
KyFarm
KyFarm's Avatar
The NP205 was originally matched up to a TH350,
Can you recommend a source for the adapter?
Old 01-21-2012, 11:35 PM   #4
wilkin250r
wilkin250r's Avatar
From what I recall, the 700R4 output shaft is a little longer than the TH350 output shaft, but they're both 27-spline shafts. Lots of people make adapters for various transmission to bolt to an NP203 because the doubler kit is so popular, but I don't know any that make a specific 700R4 to 205 adapter.
The rear bolt pattern for the 700R4 is the same as the TH350, but the output shaft is longer. So you could replace the output shaft with a specialty shaft that makes it identical to the TH350 output, and then use stock components. The output shaft is less than $200, but it requires a transmission rebuild.
The other option that I've heard about (but haven't seen personally) is to buy a specialty adapter used for replacing a TH350 with a 700R4, then cut about 1/4 inch off the output shaft of the 700R4, and life is golden.
wilkin250r is offline   Reply With Quote
Old 01-22-2012, 12:06 AM   #5
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Heres some good reading for you. http://67-72chevytrucks.com/vboard/s...d.php?t=128495
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 01-22-2012, 02:14 AM   #6
speedfreekk
http://www.transmissionpartsusa.com/...it_s/11158.htm
7-35a is what I did to put 700r4 to a np205. Makes it a little longer but will not hurt.
Hope this helps.
speedfreekk is offline   Reply With Quote
Old 01-22-2012, 10:16 AM   #7
snj8198
snj8198's Avatar
ORD is also offering the correct length output shaft for use with the th350 adapter.
http://offroaddesign.com/catalog/trannyoutput.htm
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 01-23-2012, 03:20 PM   #8
Beelzeburb
Devil's in the Details
Beelzeburb's Avatar
Or there is always the Advance Adapters short TH700R4 output shaft:
http://www.advanceadapters.com/products/pn-50-6900/
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread
Datsun 240Z, 510 2 door and an old Honda motorcycle
Beelzeburb is offline   Reply With Quote
Old 01-24-2012, 05:21 AM   #9
1malo68
1malo68's Avatar
You can also use this if you don't want to rebuild the tranny
http://offroaddesign.com/catalog/700r4spacer.htm
1968 K10/30
Frame Off Project "Overkill"
My 5 year, $30,000.00 toy
1malo68 is offline   Reply With Quote
