Old 01-25-2012, 06:37 PM   #1
terrylgreenjr
Shorty Headers
Does anyone know if these will fit 73-87 swap?
http://www.ebay.com/itm/99-04-YUKON-...item3a6941defa
I'm not sure if the link will work or not
terrylgreenjr is offline   Reply With Quote
Old 01-25-2012, 08:26 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Shorty Headers
Header choice depends on position of the motor/trans choice. IMO from what I can see, the position of the flange might interfere with the frame.
Besides that, ebay stainless exhaust is usually....garbage. It holds more true with turbo manifolds than anything else, but even with cheap headers, the heat cycling tends to crack the cheap stainless and often questionable welds.
I do like that its being sold by someone named IloveTACOTACO tho....classy.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-26-2012, 12:24 AM   #3
terrylgreenjr
Re: Shorty Headers
Yea I saw that I love taco taco but he has sold a ton of stuff I love taco myself lol
Old 01-26-2012, 09:25 AM   #4
Shon
Re: Shorty Headers
Why not get the long tube headers that fit your application:
http://www.herronperformance.com/sto...&productId=457
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 01-26-2012, 11:46 AM   #5
terrylgreenjr
Re: Shorty Headers
I'm trying to find a less expensiive header that will work. If it is listed for a different vehicle and not a swap I think it would be cheaper
Old 01-26-2012, 11:51 AM   #6
Shon
Re: Shorty Headers
Cheaper than $550 shipped for a header that fits without ANY modifications.
Once you think you have found a set you want to try let me know, I will be more than happy to send you a quote.
Old 01-27-2012, 01:13 AM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Shorty Headers
lol Shon, you work that Gold Vendor status hard.
terry, if you buy something new he'll get you setup.
If you're trying to keep costs down, you might try some early f-body manifolds. They are the individual tube manifolds and have more clearance than the newer ones, you may still have to modify them a bit. I've seen them run in swaps, but can't confirm they'll be direct fit on your swap.
Old 01-27-2012, 09:15 AM   #8
Shon
Re: Shorty Headers
I do b/c you know its not free and I usually can offer better pricing for the same products b/c I am a one man show that does this on the side.
Old 01-27-2012, 01:54 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Shorty Headers
Doesn't mean I can't break your balls for it.
Old 01-27-2012, 01:58 PM   #10
Shon
Re: Shorty Headers
Old 01-27-2012, 08:39 PM   #11
mooseknuckles
mooseknuckles's Avatar
Re: Shorty Headers
I'd like to get me someof those..
mooseknuckles is offline   Reply With Quote
Old 01-28-2012, 08:43 PM   #12
Shon
Re: Shorty Headers
PM me your full shipping addy and I will send you a quote.
Old 01-29-2012, 09:42 PM   #13
Ranger6202
Re: Shorty Headers
Found these. They look just like hooker's manifolds that should be coming out any day now.
http://www.speedwaymotors.com/Tru-Ra...hed,53711.html
and here's the unpolished ones:
http://www.speedwaymotors.com/Tru-Ra...isplayId=53711
I'm thinking these would be perfect fit.
Ranger6202 is offline   Reply With Quote
Old 01-29-2012, 10:58 PM   #14
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Shorty Headers
for what those cost, you really are better off with the DT headers. Performance for the money would be better, and no questioning the fit.
Old 01-30-2012, 12:19 AM   #15
terrylgreenjr
Re: Shorty Headers
I was looking at the eBay ones because they were under $200 including shipping I haven't seen anyone use them before.
Old 01-30-2012, 01:05 AM   #16
Ranger6202
Re: Shorty Headers
i found some 2010 f-body manifolds here. Looks like it'd be around $250 after shipping.
http://www.gmpartsshop.com/?i=2&make...n=7&type=parts
not sure if that link will pull up the exact parts. Just put in 2010 for the year and all the other good stuff. Should pull them up.
Old 01-30-2012, 08:59 PM   #17
Ranger6202
Re: Shorty Headers
Turns out, i have some f-body manifolds i got off a blown up motor a friend gave before he moved last summer. I just bolted 'em up on my '85 and they fit perfect....tons of room. If you need any measurements off these manifolds let me know. The SN's are: 12611640 and 12611641. I google'd them and it looks like they're about $83-$100 a piece.
I had originally started notching the passenger side frame for the truck manifolds but then stopped when i realized the driver's side was gonna be a lot worse to pipe up due to it sticking outward instead of rear-of-truck-ward. Driver's side frame is not notched in these pics (stock)
Old 01-31-2012, 11:17 AM   #18
terrylgreenjr
Re: Shorty Headers
How close is your engine to the firewall? Did you use just a stock engine mount and a 3/8 to 1/2 inch thick adaptor plate? It looks like the f body exhaust exits more pointed down then the truck exhaust which would give me the room I need
Old 01-31-2012, 01:46 PM   #19
Ranger6202
Re: Shorty Headers
my heads are like 1/4-1/2" off the firewall. Originally i guess this truck had a diesel in it some # of owners ago. Somebody put a 350 in it which was still in it when i bought it. The distributor used to be right against the firewall, so i'm guessing the 350 itself was set a little further back than normal. The adapter plates i bought have the 3 choices for placement, and i had to use the 1" back to get it to mount up with the stock mounts. I'm pretty sure i could go 1" forward over stock and these manifolds would still fit in the gap perfectly. The clever idea i had with the mounts having three options was for when i get a 4l80 put in it, i won't have to change my drive line and can just move the motor forward with the mounts.
Old 01-31-2012, 02:56 PM   #20
Ranger6202
Re: Shorty Headers
Measured the manifolds, the farthest they stick out from the cylinder heads looks to be 3-3.5". And thats not counting the flange, thats just the straightway where all the tubes come in. Both flanges seem to stick out about 5-5.5" at their farthest from the flat flange on the back of the block that bolts to the tranny. The driver's side flange hangs down 6.5-7" and the passenger side hangs down about 7-7.5" from the center of the last manifold to cylinder head bolt.
Old 01-31-2012, 06:17 PM   #21
terrylgreenjr
Re: Shorty Headers
I found these too. I wounder how close they run to where the stock manifolds run
Amazon.com: PaceSetter 70-1350 Shorty Header for ... Amazon.com: PaceSetter 70-1350 Shorty Header for ...
Old 01-31-2012, 10:07 PM   #22
Ranger6202
Re: Shorty Headers
i found that same set on e-bay and was contemplating buying them to try them out. I wish they had some measurements on them.
Old 02-04-2012, 05:30 AM   #23
Mr. 250r
Mr. 250r's Avatar
Re: Shorty Headers
my 6.0 came with edelbrock shorty headers which fit perfect on the drivers side and hit a little on passenger after hitting with a hammer a little bit i massaged it to fit because i refuse to notch my frame and a little dent in the header is fine, my motor is sitting actually all the way against the firewall i have to scoot it forward a tad and the shorties come out... in a perfect location for me also im using dirty dingo ls swap mounts but no ac compressor as that was a problem ill fix later
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 02-04-2012, 09:19 AM   #24
terrylgreenjr
Re: Shorty Headers
Are yours truck or f-body shortys
Old 02-04-2012, 03:53 PM   #25
Mr. 250r
Mr. 250r's Avatar
Re: Shorty Headers
Truck headers I can get pics up later ofthe them
2003 1500 Silverado
