Old 04-21-2012, 04:49 PM   #1
powerT
Cutting coil springs
Going to lower the 83. Thinking about cutting the front springs ,how many coils to cut off to lower it 2.5-3 in.
powerT is offline   Reply With Quote
Old 04-21-2012, 05:01 PM   #2
fm$ kid
Re: Cutting coil springs
Just start cutting one coil at a time. Its how I did in my lowriders. Cut a coil, install them, and ride around so that they get wore in a lil bit.
89 2dr Blazer - 2 pumps 6 batts on 13" Dayton's - Hit'em till something breaks!
94 Caddy Fleetwood - all stock - Being built from the ground up!
86 C10 Longbed - Bagged F/B - The Beast!
12 Altima - stock and shiny - the wifemobile!
A long time ago an OG once told me a great piece of advice...he said..."if their ain't a lowrider scene where u go....make one"...so I did.
fm$ kid is offline   Reply With Quote
Old 04-21-2012, 05:07 PM   #3
rwhit57
rwhit57's Avatar
one full coil will get you about 2". Anything beyond that and you start having issues with not enough bolt on the upper control arms to reset the camber.
"Whoever said money can't buy happiness has obviously never seen a speed shop!
rwhit57 is offline   Reply With Quote
Old 04-21-2012, 06:53 PM   #4
Square_78
Square_78's Avatar
I had lots of bolt left on mine to adjust my camber. I guess it depends on the truck. Mine came down 5" in the front with cut springs. Rides the same as it did stock. I actually wish it was a little stiffer. But yes 57 is correct. One coil = aprox 2" drop. I put in heavy duty shocks and its a bit better/stiffer now. I might even try heavier 3/4 ton coils and see how they feel. Anymore than 4" and you will have to cut out your front metal bump stop base because you will be bottoming out on them over bumps. I am going to cut off the metal bump stop base and reattach the rubber bump stop to the lower control arm to give me more travel... for now anyways. Hopefully I will bag the front over the winter.
Square_78 is offline   Reply With Quote
Old 04-21-2012, 07:05 PM   #5
cory d
cory d's Avatar
i did 1 1/2 coil and it sat on the bump stop. were is this bolt at to adjust camber?
cory d is offline   Reply With Quote
Old 04-21-2012, 07:16 PM   #6
walka
How is the Ride after Cutting Coils?
walka is offline   Reply With Quote
Old 04-21-2012, 07:48 PM   #7
powerT
How far did 1 1/2 coils take it
Old 04-21-2012, 08:00 PM   #8
cory d
cory d's Avatar
it droped 4" and the ride was like it was before, just a little stiffer which i think is a good thing
Old 04-21-2012, 09:02 PM   #9
rwhit57
rwhit57's Avatar
Hey, I was referring to the bolts that go through the upper control arm shaft. It's where the shims are for alignment/camber. Most often with much more than a coil those bolts aren't long enough to get the camber back straight. I have heard of folks installing longer bolts. I have 3" spindles with one coil cut and I have plenty of adjustment. Before with 2 coils cut and no drop spindles, I didn't have enough adjustment.
Old 04-22-2012, 04:26 AM   #10
Square_78
Square_78's Avatar
Mine rides the same as it did before. I installed the heavy duty front shocks and it rides pretty good now. I have air shocks in the back so the whole thing rides like a Cadillac even with lots of drop.
This is mine the day I lowered it. Excuse the dirt... Ive got smaller tires on the front now so its an inch lower and sits level... Camber isnt too bad, but definately in need of an alignment. I was expecting it to ride rough, but it not rough at all. Its surprisingly good.
This is the camber before alignment... you can see the front doesnt look bad at all, and there is still about an inch of bolt sticking out to add shims too... I havent taken it in yet, but hopefully this week I can get the alignment done when i do my center support carrier bearing and u-joints.
Old 04-22-2012, 10:20 AM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
You do NOT want to cut more than 1.5 coil, and I don't recommend any more than a coil. Depending on the condition of your stock coil you will get about .5" per half coil. If you cut more than 1 coil, you will have limited adjustment for alignment, and your prone to bottoming out.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-22-2012, 01:15 PM   #12
misternash2
so you're saying that 1 coil and 3" spindles won't bottom out very bad? i'm lowering a suburban and i was looking at this in the front and flipping the rear. silly question, maybe, but is a c-notch required with a flip kit?
this pic is what i'm looking for. (i have no idea who's truck this is, but if it's yours, it looks great!). i believe these wheels are 22's, but i'll be running 20's with a taller tire. i'll be somewhere in the same overall tire height area. i may do an air kit this winter, depending on how i like the ride.
1. will an approximate 5/7 (which is what i gather i'm looking at) drop get me where i wanna go?
2. will i be okay to tow my bass boat with this setup without bottoming out?
misternash2 is offline   Reply With Quote
Old 04-22-2012, 04:26 PM   #13
Malo83
Cruzzzn' Vet
Malo83's Avatar
This is my 83 with 2 cut coils and flip kit, with 2 coils cut you will have to run longer bolts and a spacer to get back your alignment, been running this setup for the last 29 years with no problems, rides as good as stock
Uploaded with ImageShack.us
Malo83 is offline   Reply With Quote
Old 04-23-2012, 03:55 AM   #14
Square_78
Square_78's Avatar
Your truck has the perfect stance. You definately dont need to be any lower than this for a daily driver. That suburban above doesnt look like its lowered very much at all. Looks like a 3/4" drop at the most. I could be wrong because I havent looked at many Squares with 22's, but im looking at all the space under the frame and it looks pretty high up.
Old 04-23-2012, 04:41 PM   #15
slam59
Hey Malo your truck sits exactly how I want my 74 to sit. Looks good. I told my friend thats how I wanna lower mine and with funds so tight right now, I dont have the cash for lower springs and spindles. He says they dont ride good with cut coils, but alot of others here say theirs ride just fine. You say yours rides real good huh? You say longer bolts , where are these bolts located and what do they go to? I have never done this and do not know.
slam59 is offline   Reply With Quote
Old 04-23-2012, 05:20 PM   #16
J Knight
J Knight's Avatar
This is the bolt you have to replace, the factory bolt is splined and pressed in like a lug stud and a longer replacement bolt is not. This is the way we did it before drop spindles were available. If you dont tack weld the bolt in you will have to use a back up wrench to get the shims tight(your alignment guy will hate you). Also going this route by cutting 2 or more rounds off of the stock springs, everytime you lift the truck off the ground the spring will move out of its "seat". Personally I do not recommend this type of drop.
If you want to go that low on a budget you can get spindles and a flip kit and an alignment for under $400 done right with only these parts, you dont have to buy the $500 plus kits with all the bells and whistles.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 04-23-2012, 10:26 PM   #17
slam59
What set up did u get on your truck JKnight at under $400?
Old 04-23-2012, 10:42 PM   #18
cory d
cory d's Avatar
if its a half ton burb you might not have to go that far, most i se are already sagging a couple inches
Old 04-24-2012, 12:00 AM   #19
J Knight
J Knight's Avatar
This is what I bought with free shipping, plus cut one round off front springs, remove bumpstops front and rear. If you order this be sure to check your rotor thickness to get the right spindle (same price).
http://www.stylintrucks.com/parts/fr...mcg33154-.aspx
http://www.stylintrucks.com/parts/re...mfk10245-.aspx
John
Old 04-24-2012, 12:19 AM   #20
ivorton74
ivorton74's Avatar
wow!! u see this is what i want my 74 to look like.that is a killer stance. man i just cant wait to drop mine. geeezzz!!
ivorton74 is offline   Reply With Quote
Old 04-24-2012, 12:32 AM   #21
cory d
cory d's Avatar
the licence plate is killer too
