04-27-2012, 05:09 PM | #1 |
Jumping the starter solenoid
If I can jump the starter solenoid with a screw driver, does that eliminate the starter and solenoid as the culprit for the truck not turning over?
Very often my truck will not start. I will turn the key and nothing happens until I give the solenoid a slight "bump" with a screwdriver. Then she fires right up. I have changed the solenoid, but not the starter. I have also changed the ignition switch and pigtail. |
04-27-2012, 05:22 PM | #2 |
Junior Member
Re: Jumping the starter solenoid
Do you have an automatic transmission with the neutral safety switch.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
04-27-2012, 05:24 PM | #3 |
Yes have AT with NSS, which was replaced as well.
04-27-2012, 05:55 PM | #4 |
Active Member
There's probably a flat spot on the starter or a defective drive asm. The bushings get worn and since the clearances are extremely close between the armature and windings it will cause the starter to basically stay in one spot. Usually a few bumps will clear it but it will get worse.
Swap the complete starter/solenoid as a unit. Auto Zone sells them for around $45-$50 and will save you headaches. |
04-27-2012, 06:22 PM | #5 |
Thanks 68 GMSee. Somebody had told me that if I am able to jump the solenoid, then the starter is fine. Guess, he was wrong.
04-27-2012, 09:01 PM | #6 |
Im having the same problem.I replaced the starter and solenoid as a unit and my ignition switch.Im going to replace the pigtail and nss to see if that is the problem.Mine started out like yours then got so bad i just had wire up a push button.
04-27-2012, 09:13 PM | #7 | |
Active Member
It takes about 1 hour to remove and replace the starter. 1½ if you have a cold beer sitting close by. |
04-27-2012, 09:19 PM | #8 |
http://www.dbelectrical.com/
$60 shipped to your door, brand new 3 HP mini(just 7 pounds)with new bolts and a shim...I didn't use the shim. 1 year warranty. |
04-27-2012, 10:14 PM | #9 |
Active Member
A good price for a mini. I'm tempted to get one just to have it for that price.
http://www.dbelectrical.com/p-1319-n...sdr0031-l.aspx |
04-27-2012, 11:48 PM | #10 | |
They have good warranty too. I bought an alternator with a 1 year warranty. 2 years latter the regulator failed. I sent it in to get it fixed. They didn't charge me anything (pun not intended). Great service. |
04-28-2012, 09:39 PM | #11 |
clean all of the ends of the wires that go to the junction box on the passenger fender.
04-29-2012, 01:51 PM | #12 |
Thanks for the help guys. Pardon my ignorance, but what are the benefits of a mini starter?
04-29-2012, 06:29 PM | #13 |
dazed and confused
Man that is great price.
members met: redbaron69, billsbowtie,nc67 |
04-29-2012, 09:35 PM | #14 | |
Junior Member
The min starter is smaller and a high torque model that does not suffer from heat soak.
04-30-2012, 01:02 PM | #15 |
Purchased the mini from debelectric. Worth a shot for $60 to my door. Thanks for the help guys. I'll let you know if this solves my problem.
04-30-2012, 04:16 PM | #16 | |
Restoration Virgin!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
04-30-2012, 04:34 PM | #17 |
Geeeez that is cheap...I paid $250 for the CVR one
Awsome upgrade though...heat soak is a BIG PITA
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
05-05-2012, 04:49 PM | #18 |
On the same note, what if the solenoid does nothing when arced with a screwdriver? My 69 stopped starting this morning. Since the starter dragged anyway, I replaced the starter solenoid and the positive battery cable. The solenoid isn't making any noise when I turn the key or when I try to arc it. I have a good hot battery, and I see a little spark when arcing but the solenoid doesn't even click. Any ideas?
05-05-2012, 06:08 PM | #19 |
I built it
sounds like a dead battery. does it do the same thing when jump starting it?
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
05-05-2012, 06:22 PM | #20 |
Truck does same thing with jump and battery's fully charged. gauges work on the dash, I can see batt gauge draw down when I turn the key.
Posted via Mobile Device |
05-05-2012, 09:25 PM | #21 |
might want to check the ground side from block to the battery
05-05-2012, 10:38 PM | #22 | |
Then make shure the starter is getting 12v
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
05-07-2012, 11:51 AM | #23 |
Update: Installed the mini starter on Saturday. So far so good. Has started every time. Sounds a lot different too.
05-07-2012, 01:03 PM | #24 |
Active Member
05-07-2012, 01:35 PM | #25 |
Yes, it was the HT SDR0031-L. I have a 5.7L TBI from a 90 Chevy 1500.
It's amazing how light these mini starters are. I thought they had sent the wrong part when I felt how light the box was! |
