Old 06-05-2012, 12:15 PM   #1
Bustedknuckle
Late model air
If I decide that I want to modify a late model in dash A/C unit and put it in my 1970 pick-up what model vehicle should I use as the donor? I want the best a/c I can get that will fit under there. And before you suggest the kits, don't bother... I know about them, but I'm looking to save some money. So that is why I am exploring the possibility of a late model setup.
Bustedknuckle is offline   Reply With Quote
Old 06-05-2012, 12:59 PM   #2
Ackattack
Ackattack's Avatar
Re: Late model air
I put an A/C unit from a 90 chevy into my 69. It was A LOT of work, but other than the cost to charge it up and then a new compressor and drier, it was free (so in reality it cost me about $300)
I had to move the firewall out ~2", trim the bottom of the dash, and modify the diverter box to get it to work.
Ackattack is offline   Reply With Quote
Old 06-05-2012, 03:25 PM   #3
dragonwrecker
dragonwrecker's Avatar
Re: Late model air
i have been exploring the same idea for the same reason.i know alot of the late model car units will be able to fit but not sure yet which one is the best to use.
dragonwrecker is offline   Reply With Quote
Old 06-06-2012, 08:01 PM   #4
txriverrat
Re: Late model air
Check this out:
http://67-72chevytrucks.com/vboard/s...19&postcount=4
This is basically the setup that I'd like to copy when it finally comes time to install a working A/C on my truck.
txriverrat is offline   Reply With Quote
Old 06-07-2012, 12:31 PM   #5
Bustedknuckle
Re: Late model air
I need more pictures. I like the digital thermostat. And if there are any pics of the truck with the 1990 A/C I would like to see that too. If you've never taken any please take some. Dragonwrecker and I are not the only people on this forum that would like to know how to do this.
Old 06-07-2012, 02:38 PM   #6
txriverrat
Re: Late model air
You should PM or email RichardJ, the member who actually made the original post. I just bookmarked it for reference when I get around to installing an A/C.
a/c, air, conversion, late, unit
